Help with rules
Sasch600xt
Help with rules
#1 Post by Sasch600xt » 22 Nov 2019, 18:12
Hello all,
i want to send an MQTT message to an ESP (works already)
and if i send once a "1" or "true" i want to publish a sensor value every 10 seconds.
if i send once a "0" or "false" i want to disable the timer or if thats not possible set it t a long period.
This is my start so far:
on MQTT_INPUT#TimerAmpere=1 do
 timerSet,1,10
on MQTT_INPUT#TimerAmpere=0 do
 timerSet,1,0
On Rules#Timer=1 do
publish,"%sysname%/status/Ip_Adresse","%ip%"
// here i should retrigger the timer depents on TimerAmpere is 1 or 0 i guess ?
Can someone help ?
Would be awesome :)
Have a great day
Re: Help with rules
#2 Post by TD-er » 22 Nov 2019, 18:31
Why not use variables to store the state?
Then you can set that value to 0 or 1 depending on the MQTT messages.
In the timer call, you just check for the value of the variable and only then do your stuff.
Sasch600xt
Re: Help with rules
#3 Post by Sasch600xt » 22 Nov 2019, 18:34
sounds great,
do you have an little example ?
i am right now not sure about the syntax.
are you talking about this for example: %v1% ?
Re: Help with rules
#4 Post by TD-er » 22 Nov 2019, 19:18
Sasch600xt wrote: 22 Nov 2019, 18:34 i am right now not sure about the syntax.
Well, neither am I, that's when I ask Jimmy for the rules :)
Sasch600xt
Re: Help with rules
#5 Post by Sasch600xt » 22 Nov 2019, 19:25
i found a snippet at the forum, but it is not working right now.
The variable changes from 0 to 1 by sending a MQTT message, so this works.
But the part with publish will not work..
Do you see the problem ?
 let,1,1
 let,1,0
On Rules#Timer=1 do
if %v1%=1
publish,"%sysname%/status/Uptime",%uptime%
Sasch600xt
Re: Help with rules
#6 Post by Sasch600xt » 22 Nov 2019, 19:36
ok....as usally...my fault.
i forgot to set the timer again....
so this works now like expected :
 let,1,1
 let,1,0
On Rules#Timer=1 do
if %v1%=1
timerSet,1,10
Re: Help with rules
#7 Post by TD-er » 22 Nov 2019, 19:47
Looks good :)
 let,1,1
 let,1,0
I think (hope) it could be made shorter (although not completely the same as it allows other values too):
on MQTT_INPUT#TimerAmpere do
 let,1,[MQTT_INPUT#TimerAmpere]
Sasch600xt
Re: Help with rules
#8 Post by Sasch600xt » 22 Nov 2019, 19:52
works perfect :)
