Hi all,
I would know if I can use this hardware:
https://www.sparkfun.com/products/11574
It seems to me that with Easpeasy I can only read the analogical input every 1 sec. It's a large time to capture the peak level.
So I don't understand how I can capture the peak level and the time distance between two peaks.
Thanks in advance for every answer.
Graziano
Pulse sensor
Re: Pulse sensor
To use that sensor (without additional hardware) would require that you write a custom plugin for it.
If you don't mind adding more hardware you might be able to use the pulse counter plugin to make simple BPM measurements. This would require a comparator chip to condition the analog output into a 3V logic level that triggers the counter plugin on each signal rise.
