Publish. Where am I going wrong?
uxhamby
#1 Post by uxhamby » 28 Nov 2019, 20:12
ESPEASY version is as follows:
mega-20180809
Has been working for quite a while but now I am trying to add an MQTT publish to the rule set as follows:
on FurnaceBurner#Flame=1 do
sendTo 10,relay,0,1
sendTo 12,TaskValueSet,1,1,1
SendToHTTP 192.168.55.152,80,/cm?cmnd=Power1%200
Publish FurnBurn, "Flame: On"
endOn
on FurnaceBurner#Flame=0 do
sendTo 10,relay,0,0
sendTo 12,TaskValueSet,1,1,0
Publish FurnBurn, "Flame: Off"
SendToHTTP 192.168.55.152,80,/cm?cmnd=Power1%201
endOn
I have the following mosquitto_pub /_sub verification that my MQTT connections are workking:
bjh@laptop2:~$ mosquitto_pub -h broker.hivemq.com -p 1883 -t EnzoStuff/FurnBurn -m "Hello"
bjh@laptop2:~$ mosquitto_pub -h broker.hivemq.com -p 1883 -t EnzoStuff/FurnBurn -m "WTF?"
bjh@laptop2:~$
bjh@laptop2:~$ mosquitto_sub -h broker.hivemq.com -p 1883 -t EnzoStuff/FurnBurn
WTF?
I have my controller setup as follows:
Screenshot from 2019-11-28 14-07-37.png (67.68 KiB) Viewed 9499 times
No publishing is going on that I can see, where am I going wrong?
Thanks, Brian H.
Re: Publish. Where am I going wrong?
#2 Post by grovkillen » 28 Nov 2019, 20:19
Do you have a space after the comma?
#3 Post by ThomasB » 28 Nov 2019, 21:09
I see that the rule's publish command has an incomplete topic name. See this example:
Publish EnzoStuff/FurnBurn,"Flame: Off"
uxhamby
#4 Post by uxhamby » 28 Nov 2019, 23:51
CODE: SELECT ALL
Is that not covered by the "EnzoStuff/" in the Publish field of the controller setup panel?
uxhamby
#5 Post by uxhamby » 29 Nov 2019, 00:02
Yes there is.
BJH
#6 Post by grovkillen » 29 Nov 2019, 02:46
uxhamby wrote: 29 Nov 2019, 00:02
Yes there is.
BJH
Please remove it.
#7 Post by TD-er » 29 Nov 2019, 09:21
Just to clearify a bit (or make it more confusing... I never know)
See the "Parameter Parsing" here: https://espeasy.readthedocs.io/en/lates ... er-parsing
(Also to Jimmy)
Have you tried the suggestion made by TomasB ? viewtopic.php?p=41029#p41029
#8 Post by grovkillen » 29 Nov 2019, 13:22
TD-er wrote: 29 Nov 2019, 09:21 Just to clearify a bit (or make it more confusing... I never know)
(Also to Jimmy)
Thanks for clearing that to me :)
uxhamby
#9 Post by uxhamby » 29 Nov 2019, 16:26
I think so. Please see:
viewtopic.php?f=4&t=7256#p41037
uxhamby
#10 Post by uxhamby » 29 Nov 2019, 16:52
I am now configured as follows:
Screenshot from 2019-11-29 10-40-24.png (76.04 KiB) Viewed 9408 times
No spaces after comma.
file1
file1
Screenshot from 2019-11-29 10-40-46.png (68.02 KiB) Viewed 9408 times
I have done a reset of the esp.
I see no difference in behaviour so far.
BJH
uxhamby
#11 Post by uxhamby » 29 Nov 2019, 20:53
From the log on my ESP surrounding an event that should (or I want to) "Publish".
2379963: EVENT: H2OBurner#WFlame=0.00
2382365: SW : Switch state 1 Output value 0
2382369: EVENT: FurnaceBurner#Flame=0.00
2382379: ACT : sendTo 10,relay,0,0
2382392: ACT : sendTo 12,TaskValueSet,1,1,0
2382403: ACT : Publish,EnzoStuff/FurnBurn,'Flame: Off'
2382416: ACT : SendToHTTP 192.168.55.152,80,/cm?cmnd=Power1%201
2382439: Command: sendto
2382508: Command: sendto
2382576: Command: publish
2382579: Command: sendtohttp
2384963: SW : State 0.00
2384966: EVENT: H2OBurner#WFlame=0.00
2389961: SW : State 0.00
2389964: EVENT: H2OBurner#WFlame=0.00
2394961: SW : State 0.00
2394964: EVENT: H2OBurner#WFlame=0.00
2395859: EVENT: Clock#Time=Fri,14:40
uxhamby
#12 Post by uxhamby » 29 Nov 2019, 21:01
I randomly tried giving the ESP an MQTT topic to subscribe to, (in the controllers panel) from other work I am doing.
Screenshot from 2019-11-29 15-02-19.png (71.41 KiB) Viewed 9378 times
This seems to have made a difference. I now seem to be "Publishing"
WTF?
WTF2?
test
"Flame: Off"
"Flame: On"
"Flame: Off"
"Flame: On"
"Flame: Off"
"Flame: On"
Not sure what it means but I feel like I've made some progress. I'll keep you posted.
Cheers,
BJH
#13 Post by TD-er » 29 Nov 2019, 21:48
Just a few remarks based on the screenshots you showed here: viewtopic.php?p=41056#p41056
sendTo is sending a command, so the last part should be considered as a single parameter.
sendto 10,"relay,0,0"
sendto 12,"taskvalueset,1,1,1"
Your sendtohttp command. Is that one sending to another ESPEasy node?
If so, then the url must be more like ...,/tools?cmd=...
Just as a test, can you add something like this:
on starttest do
logentry "starttest publish"
publish "EnzoStuff/FurnBurn","Flame: On"
Then trigger this event via the command text box on the Tools tab:
event,starttest
uxhamby
#14 Post by uxhamby » 30 Nov 2019, 00:30
No, it is not. It sends to a non 'ESPEASY' device. This is working just fine for my purposes as is.
Users browsing this forum: Bing [Bot], Google [Bot] and 49 guests
