Somfy RTS inverted control
GibsonLP
#1 Post by GibsonLP » 16 Sep 2019, 23:29
Hello.
Following my issues with the tilt motor I decided to get the other curtains working until this gets sorted.
For some reason - one of my blinds is reversed, up is down and down is up, the other ones (one of them is the same model) are fine.
Is there a way to inverse it a specific device? is that a pairinig issue and trying again should solve it?
hoeby
Re: Somfy RTS inverted control
#2 Post by hoeby » 20 Oct 2019, 08:11
You need to follow the manual from somfy for this.
With a somfy remote you can change the direction of the motor. That up will be the same direction as your other blinds
I have 2 blinds and 2 curtains.
Had the same problem, with the remote i changed the direction.
GibsonLP
#3 Post by GibsonLP » 30 Nov 2019, 06:46
The somfy control was fine, the problem was with RFlink.
I ended up solving it by upgrading home assistant and adding "inverted" to the configuration of the blind.
Users browsing this forum: gremlin and 2 guests
