Turn on a GPIO every minute for 5 seconds. what am I doing wrong
leachimtrebron
#1 Post by leachimtrebron » 23 Dec 2019, 17:21
Hello everybody,
Task:
Is installed:
ESP_Easy_mega-20191208_normal_ESP8266_4M1M.bin
Built ruls:
On start-gpio14 do
    Long Pulse, 14,1,5
on Clock#Time = All,**:1 do
       start-gpio14
Problem:
The GPIO is not switched
Can you give me a tip?
Thank you
Re: Turn on a GPIO every minute for 5 seconds. what am I doing wrong
#2 Post by grovkillen » 23 Dec 2019, 19:05
Event is needed. And no spaces in the command
HomeJCL
#3 Post by HomeJCL » 23 Dec 2019, 20:33
Havé you declared the switch in Devices ?
leachimtrebron
#4 Post by leachimtrebron » 24 Dec 2019, 12:27
yes they are declared otherwise the http version would not work
leachimtrebron
#5 Post by leachimtrebron » 24 Dec 2019, 12:32
@homejcl: Thank you very much, could you please show me an example of what such an event should look like?
#6 Post by grovkillen » 24 Dec 2019, 18:26
On start-gpio14 do
    LongPulse,14,1,5
on Clock#Time=All,**:*1 do
       Event,start-gpio14
leachimtrebron
#7 Post by leachimtrebron » 25 Dec 2019, 15:07
@grovkillen :
I have taken the source code into my Ruls
On startgpio14 do
LongPulse,14,1,5
Event,startgpio14
and rebooted esp No response on GPIO13
I use the image:
#8 Post by grovkillen » 25 Dec 2019, 15:08
You're very confusing, GPIO 13 or 14?
leachimtrebron
#9 Post by leachimtrebron » 25 Dec 2019, 18:14
sorry its gpio14
Event,startgpio14
doesn't seem to work for me
#10 Post by grovkillen » 25 Dec 2019, 18:38
That syntax will be triggered at every hour at minut 01, 11, 21....51
Not every minute.
leachimtrebron
#11 Post by leachimtrebron » 26 Dec 2019, 15:03
@grovkillen
Wie ist die Syntax mit dem ich jede Minute einen Event auslösen kann?
#12 Post by grovkillen » 26 Dec 2019, 16:45
Either use a timer or use the syntax **:** which will trigger every minute.
leachimtrebron
#13 Post by leachimtrebron » 26 Dec 2019, 18:16
Thanks for the hint.
what does it look like if you want to trigger an event every 3 or every 8 minutes
Could you put some examples in the wiki? This could also help other users.
THANKS for your help
Clock # Time =
All, **: ** ==> every minute
All, **: ** ==> 1 1,11,21,31,41,51 minute
All, **: * 5 ==> 5,15,25,35,45,55 minute
All, **: 30 ==> 00 and 30 minutes
Mon, 7:30 p.m. ==> every Monday at 7:30 p.m.
All,% sunrise% ==> sunrise (*)
All,% sunset% ==> sunset (*)
(*) write under Tools / Advanced Settings / Location Settings
I have not yet understood the following:
What does it look like if you only want to trigger an event every 14 days on Monday?
or an event every 4 weeks on the first Monday?
Are there other options?
#14 Post by grovkillen » 26 Dec 2019, 19:00
You would use dummy variables. And you can use clock together with timers. So it's really up to you what your plans look like. You have the week day number that you can use and for each Monday you add one to the dummy. When it's = 4 you execute the code. Next Monday you reset it to 1.
Users browsing this forum: Bing [Bot] and 1 guest
