time relay 2 canal
christianh
time relay 2 canal
#1 Post by christianh » 10 Jan 2020, 17:03
Hi at all!
I hope anybody will help me! First i have to say - i ´m a starter...
I have bought https://www.amazon.de/Relais-ESP8266-Zw ... th=1&psc=1 an thought that i can easily reinstall another software....
That for i searched and found an sample which i thought i flash it on the esp8266 and everybody will be happy.... http://esp8266-server.de/Zeitschaltuhr.html
From this point of my testing I found out that now I have an non working equipment...
So my question is: has anybody software for this hardware or can any advice me how i can run a 2 canal 2 time relay (seconds)?
Re: time relay 2 canal
#2 Post by grovkillen » 10 Jan 2020, 17:15
You're trying to install ESP Easy or what?
christianh
#3 Post by christianh » 10 Jan 2020, 17:19
yes - i will reprogram the esp.
#4 Post by grovkillen » 10 Jan 2020, 18:06
You need to look and see if the memory is 1MB or 512kB
christianh
#5 Post by christianh » 11 Jan 2020, 10:09
1mb
#6 Post by grovkillen » 11 Jan 2020, 13:01
Ok, that's good. Then you need to have a serial adapter to program it.
christianh
#7 Post by christianh » 12 Jan 2020, 00:07
Your are joking Guy..... Whats you thougt have eine at least...,.
#8 Post by grovkillen » 12 Jan 2020, 02:55
christianh wrote:
12 Jan 2020, 00:07
No need for that.
You linked to a firmware which isn't ours... What's the plan? Are you going to use ESP Easy or not?
