SHT3x - no readings
SHT3x - no readings
Hi, I'm on D1 mini with ESPeasy
Build 20104 - Mega
GIt Build: mega-20191208
Filename: ESP_Easy_mega-20191208_test_ESP8266_4M1M_VCC
There is a SHT30 connected to my D1 mini: Unfortunately, I have never been able to get readings from it.
I'm newbie to ESP and not sure if I connected sensor to D1 correctly.
My connection is:
VIN -> 3.3V power adapter
GND - > ground power adapter
SCL -> GPIO-5
SDA -> GPIO-4
I will be grateful for any advice.
My configuration:
Build 20104 - Mega
My connection is:
SCL -> GPIO-5
SDA -> GPIO-4
My configuration:
Re: SHT3x - no readings
Does the i2c scanner (found under tools) show the sensor?
No I2C devices found.
Then it's up to you to find any hardware errors...?
Thanks for the reply.
My fault: it was cold joint on SDA connector . I noticed only when I used the magnifying glass. I corrected the soldering and now everything works perfectly.
Great!
Can I ask where do you get the version of ESPeasy with SHT30, please ? Or must I create a new post ?
Manubis
Manubis
As you can see here: https://espeasy.readthedocs.io/en/lates ... al-plugins
it is included in the "testing" binary of the nightly builds.
Thanks ! (I forgot there were test firmware in the bin folder :/)
I'm going to test that !
Users browsing this forum: No registered users and 119 guests
