I’m recycled old,esp-01 to monitor 2 pulse counters and one ds18b20. Programmation firmware last Build is fine
I tried to use gpio 0, 2 and 3
When configuring on gpio 3 the ds18b20 or pulse counter it doesn’t not work
Is there a trick to release this port 3?
Thank’you
Esp-01: easy solution tp use 3 GPIO ?
- budman1758
Re: Esp-01: easy solution tp use 3 GPIO ?
You need to disable the serial port to use GPIO 3. After that it should work.
oh yes, I forgot that ! Thank you
Could be nice to add it ti wiki
Thomas
Thomas
Users browsing this forum: Google [Bot] and 39 guests
