double click and longpress problem
hi all
when i doubleclick or longpress i always receive a normal press event and then i receive the doubleclick (or longpress)
in a double click when i press for the 1st time, i receive a normal event, then i click for the second time and i get the double click event 3
when i double click quickly, i just get 2 normal events but no double click
what could be the problem?
Re: double click and longpress problem
What settings of the switch plugin have you tried?
please see the attached files for my config options
- switch2.JPG (63.92 KiB) Viewed 7131 times
- switch1.JPG (63.3 KiB) Viewed 7131 times
also...
- switch3.JPG (59.07 KiB) Viewed 7130 times
of course i also tried with max interval 1000ms too
Try debounce 100..250 something
Also make sure you enable the doubleclick event.
any solution?
My problem for trying this solution is
if [Switch#State]=3
is not correct?
My Code an my Logfile is here:
https://www.letscontrolit.com/forum/vie ... 951#p43951
if [Switch#State]=3
is not correct?
Users browsing this forum: No registered users and 104 guests
