RFID update values when removing tag
sawo
#1 Post by sawo » 26 Mar 2020, 12:33
Hi all,
I would like to apologize in advance if this has already been asked several times before.
My current project is to control a water hose with a RFID token.
Current setup:
- Wemos D1 mini (espeasy)
- RDM6300 RFID
- Relais for magnetic valve
- Homematic (Generic HTTP controller)
- iobroker (rules)
The water should turn on when I place the RFID Tag on reader and should turn off when removing it, but the ESPeasy stores the last RFID ID value . see picture "001.jpg"
even when I remove it.
How can I clear the value when RFID token has been removed?
sawo
Re: RFID update values when removing tag
#2 Post by grovkillen » 26 Mar 2020, 15:32
I would use a timer for it. And clear if after x seconds.
sawo
#3 Post by sawo » 27 Mar 2020, 08:08
hi grovkillen,
thanks for your reply.
Okay I'll give it a try. Never set up a rule in espeasy before :)
thanks
sawo
sawo
#4 Post by sawo » 31 Mar 2020, 12:53
so last night I had time to learn about the rules and I have managed to create the rules.
The value will be set to "0" when token is removed.:-)
But now I have the next issue, the rule causes the wemos to reboot after 24 seconds..... and also the load will be by 100%
Could any one check my 2 rules please, to see if I made something wrong?
Rule 1:
On rfid_tag_water#Tag do
timerSet,1,5
On Rules#Timer=1 do
TaskValueSet,1,1,0
SendToHTTP 192.168.1.10,8181,x.exe?Antwort=dom.GetObject("Tag").State(0)
GPIO,4,0
Rule 2: to switch on the relais when token is available
if [rfid_tag_water#Tag]=3364040
GPIO,4,1
thx so far.
sawo
#5 Post by Ath » 31 Mar 2020, 13:03
On what interval is your rfid reader (device in ESPEasy) set? If that interval is too short, like 1 second, then the load will be (close to) 100%, causing intermittent crashes & reboots.
/Ton
sawo
#6 Post by sawo » 31 Mar 2020, 13:21
attached you´ll find a picture of the device settings.
Nothing to change or setup.
Sawo
sawo
#7 Post by sawo » 31 Mar 2020, 13:24
When I remove the rules and place the rfid token on the reader, it will reboot after 70 seconds.
#8 Post by TD-er » 31 Mar 2020, 13:34
I do see an error you could not post the data to the selected controller.
So maybe you're running out of memory while trying.
Can you set the queue depth of the active controller to 1 as a test?
sawo
#9 Post by sawo » 31 Mar 2020, 13:40
Hi TD-er,
I have removed it, now it will reboot after 44 seconds.
Maybe I´ll some thing different.
Once the rfid token is placed on the reader it will turn on the valve until I place the token again on the reader.
In this case I will not send so much data.
Could any one help me with this rule or give me a hint what to do?
SAWO
sawo
#10 Post by sawo » 31 Mar 2020, 17:34
So now it tested my new rules:
on water_on do
gpio,4,1
on water_off do
gpio,4,0
on rfid_tag_water#Tag do
timerSet,1,2
if [water_pump#On]=1
event,water_off
event,water_on
On Rules#Timer=1 do
TaskValueSet,1,1,0
but when I hold the token on the reader it always switches the relay twince. see attached log file:
I have now idea why.
sawo
#11 Post by grovkillen » 31 Mar 2020, 17:49
Instead of :
TaskValueSet,1,1,0
Try
TaskValueSetAndRun,1,1,0
sawo
#12 Post by sawo » 31 Mar 2020, 18:58
Hi grovkillen,
sorry that makes no difference.
Even when I remove this part of the rule:
On Rules#Timer=1 do
TaskValueSetAndRun,1,1,-3342336
it still switches twince or even more often.
Sawo
#13 Post by grovkillen » 31 Mar 2020, 19:18
Please give me the full rules set, or is it that one above?
sawo
#14 Post by sawo » 31 Mar 2020, 19:27
here you go.
on water_on do
gpio,4,1
on water_off do
gpio,4,0
timerSet,1,2
event,water_off
event,water_on
THX
#15 Post by grovkillen » 31 Mar 2020, 19:31
I would do it like this (without knowing your setup 100%)
on rfid_tag_water#Tag=3364040 do
timerSet,1,2
Let,1,[water_pump#On]
gpio,4,[VAR#1#!Z]
On Rules#Timer=1 do
TaskValueSet,1,1,0
EDIT: updated rules.
#16 Post by grovkillen » 31 Mar 2020, 19:32
You can read up on how to format data: https://espeasy.readthedocs.io/en/lates ... Rules.html
In the section "Formatting refered values"
#17 Post by grovkillen » 31 Mar 2020, 19:40
Or if you want any tag to trigger the rule:
on rfid_tag_water#Tag>0 do
timerSet,1,2
gpio,4,[VAR#1#!Z]
On Rules#Timer=1 do
TaskValueSet,1,1,0
Your rule would trigger when you have set the tag value = 0 which isn't what you wanted.
sawo
#18 Post by sawo » 31 Mar 2020, 19:50
Hi grovkillen,
thanks a lot for helping me.
One question, what does the [VAR1#!Z] stand for, do I need to create a variable or device?
When I copy your rule nothing happends, what do you need to know from my setup?
thx
#19 Post by grovkillen » 31 Mar 2020, 20:09
I had an error in my rule which I have corrected.
Let,1,[task#value] <---- this sets the first internal variable (16 maximum) to what ever value your pump have.
[VAR#1] is now the same value as [pump#state] (or whatever you called your task and value).
[VAR#1#Z] is making a transformation of the value, but we want this transformation to be inverted and thus:
[VAR#1#!Z]
You can read about it in the page I linked to.
sawo
#20 Post by sawo » 31 Mar 2020, 23:49
Hi grovkillen,
thanks a lot for explaining.
But the issue still exists, I think that the interval of the RDM6300 is set to high.
When I quickly put the tag on and off it only swichtes once, but if I old it on for about a 1/1,5 second it will switch 2 or more times.
Is there a possibility to pause the reading of the RDM6300, by rule, for a few seconds or increase the interval?
attached is the log from around 1 second, holding the tag on the reader.
thx
sawo
#21 Post by grovkillen » 01 Apr 2020, 02:05
That sounds like a design flaw. Please open a issue on GitHub and refer to this thread
sawo
#22 Post by sawo » 01 Apr 2020, 09:19
@grovkillen
thanks a lot for helping, I have created an issue.
#23 Post by grovkillen » 01 Apr 2020, 09:50
sawo wrote: 01 Apr 2020, 09:19 @grovkillen
Great! And thank you for reporting this issue.
Users browsing this forum: No registered users and 27 guests
