Problem with a rule for MQ-7 Gas sensor
tparvais
#1 Post by tparvais » 31 Mar 2020, 09:11
[I moved my question from viewtopic.php?f=4&t=7328 here, as problem is not directly related to MQ-7]
I implemented same MQ-7 for CO detection.
I've set a rule for managing heating/measurements/calibration
The idea is to be able to launch the calibration during 48 when pressing the button GPIO4 or to stop it by pressing again.
I use a dummy variable "Calibration_MQ7" that is 1 if calibration is on, and 0 if off...
By pressing the push switch, I shgall inverese the state of this variable
I shall be stupid because it does not work... :-(
( the others timers for heating/measuring are ok)
any idea ?
Thank you
Thomas
on System#Boot do
  timerSet,1,5
  taskvalueset 8,1,0 // état calibration à 0
on [MQ7_Calibration_Start-Stop#etat]=1 do //switch pressed
  if [Calibration_MQ7#etat]=1
    TaskValueSet 8,1,0 // inverse state + stop calibration
    gpio,13,0
    timerSet,4,0
    TaskValueSet 8,1,1 // inverse state + start calibration
    gpio,13,1 //power on heating
    timerSet,2,0
    timerSet,3,0
    timerSet,4,172800  // Calibrate 48h
    gpio,13,0 //stop heating
on Rules#Timer=1 do
 gpio,13,1
 timerSet,2,60
on Rules#Timer=2 do
 gpio,13,0
 timerSet,3,45
on Rules#Timer=3 do
 TaskValueSet 7,1, [Mesure_MQ7_CO#Analog]
 timerSet,1,45
Here are my tasks :
and how I configure the switch to launch calibration (this is a push button, normally closed, between GND & GPIO4):
GravityRZ
Re: Problem with a rule for MQ-7 Gas sensor
#2 Post by GravityRZ » 01 Apr 2020, 14:43
is the problem not that you do a check on an ON statement
i am not an experienced ESPEasy rules guru bu can you try
on MQ7_Calibration_Start-Stop#etat do //switch pressed
TaskValueSet 8,1,[MQ7_Calibration_Start-Stop#etat] set switch pressed setting to Calibration_MQ7#etat
tparvais
#3 Post by tparvais » 02 Apr 2020, 20:13
It does not work.
I simplified it as with the follwoing code, when pressing the button, Q7_Calibration_Start-Stop#etat is inverted properly each time
My problem is that it does not execute the IF test if [MQ7_Calibration_Start-Stop#etat]=0
on System#Boot do
  timerSet,1,5 // wait 5s then start
  taskvalueset 9,1,0 // état calibration à 0
on [MQ7_Calibration_Start-Stop#etat] do //switch pressed
      gpio,13,0 // stop calibration
      timerSet,1,1 // wait 1s then restart normal cycle
    gpio,13,1 //power on heating to calibrate
    timerSet,3,0 // stop timer 3
    timerSet,1,0 // stoptimer 1
    timerSet,2,20  // Calibrate 20s
on Rules#Timer=1 do
 gpio,13,1 //heat before measure
 timerSet,2,5
on Rules#Timer=2 do
 gpio,13,0 // stop heating before measure
 timerSet,3,5
on Rules#Timer=3 do
 timerSet,1,1 //go back to begining
Domosapiens
#4 Post by Domosapiens » 02 Apr 2020, 20:24
the name contains the "-" minus sign.
I can imagine that ...
Try using the "_" underscore instead, in Task and in the rule ??
tparvais
#5 Post by tparvais » 02 Apr 2020, 22:14
good idea, I changed - by _
no effect
when I press the push-switch, the state ofMQ7_Calibration_Start_Stop changes properly in task/device view.
Is there a way to debug ?
I add a tasksetvalue in #8 to a dummy variable as output to check if the IF condition is executed (or ELSE). nada.
I shorten the variable length. nada
on System#Boot do
taskvalueset 8,1,0 //for debugging
on [MQ7#etat]=0 do //switch pressed
      taskvalueset 8,1,0
on [MQ7#etat]=1 do //switch pressed
    taskvalueset 8,1,99
    timerSet,2,60  // Calibrate 48h
on Rules#Timer=1 do
taskvalueset 8,1,1
 timerSet,2,5
on Rules#Timer=2 do
taskvalueset 8,1,2
 timerSet,3,5
on Rules#Timer=3 do
taskvalueset 8,1,3
 timerSet,1,5 //go back to begining
tparvais
#6 Post by tparvais » 02 Apr 2020, 22:36
I found it myself:
there is no need to use [] in on .... do statement...
#7 Post by grovkillen » 03 Apr 2020, 05:42
tparvais wrote: 02 Apr 2020, 22:36 I found it myself:
The brackets turn the name into a value.
tparvais
#8 Post by tparvais » 03 Apr 2020, 11:17
grovkillen wrote: 03 Apr 2020, 05:42 The brackets turn the name into a value.
Worthwhile to add it to the doc :)
btw, is that possible to put a text in a dummy variable/task ? or is this only numbers ?
Thank you
#9 Post by TD-er » 03 Apr 2020, 11:37
Right now we don't have the option to use strings as values.
The support for strings is very preliminary and it is not yet possible to store them in variables or in Dummy plugin.
#10 Post by grovkillen » 03 Apr 2020, 12:19
tparvais wrote: 03 Apr 2020, 11:17
Isn't it already part of the rules examples?
GravityRZ
#11 Post by GravityRZ » 03 Apr 2020, 13:29
or you could have read my advice in which i told you to remove the []
tparvais
#12 Post by tparvais » 03 Apr 2020, 13:59
GravityRZ wrote: 03 Apr 2020, 13:29
you're right, I read your message 5 times, but I didn't noticed the [] removal
Need to change my glasses
so thank you !
GravityRZ
#13 Post by GravityRZ » 03 Apr 2020, 14:07
no problem.
next time i will mention what i changed :-)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 15 guests
