Sorry? I believe Google checks this software when publishing it in Play Market.Domosapiens wrote: ↑07 Apr 2020, 10:58So no-one can check on a Trojan Horse?I have public repo - without code
My suggestion: stay away from this software
Android application
Re: Android application
Just curious, do you check the code of all apps on your phone?Domosapiens wrote: ↑07 Apr 2020, 10:58So no-one can check on a Trojan Horse?I have public repo - without code
I don't know what future plans tiomny has with his app.
Maybe it will be open source once, maybe not.
I can imagine having a very pre-alpha version of a project is not very practical to make its source code available immediately for all.
It can hurt dev speed if the code is still very much in flux as you will have users diving into the code, asking for tips on how to build it, or enter issues based on code that's already been replaced.
Now that I think of it, I don't know many open source Android or IOS apps.
It is good to be a bit reluctant on closed source tools and have a good understanding of all the possible risks involved of running a black box.
But advising to stay away from something just because the source is not immediately open, while it is obviously still very much in development is a bit too harsh I think.
"Een beetje te kort door de bocht", for the Dutch among us
I will probably open the source code - at least I want to compensate the publishing expenses and time spent on developing the app: it has already more than 4500 lines of code.
Please do so...
The LetsControlIt platform has a very strong emphasis on Open Source projects.
Our primary mission is to share code and ideas to help each other in DIY projects.
Sharing code is quite difficult if source is unavaible for others
We have a special forum area "Experimental" so even the first alpha version can go there to discover and discuss.
Part of the fun is being involved in the early stages of development.
Just google "google play store trojan"I believe Google checks this software when publishing it in Play Market.
Most Android applications don't scan your network.Just curious, do you check the code of all apps on your phone?
Could be ..."Een beetje te kort door de bocht", for the Dutch among us
But if this application has a hidden connection to the outside world ...
On windows ...I would check the outgoing communication of the firewall.
On an Android phone???
And ... no, I even don't use my phone for payments ... do you?
Sort of, I use DigiD.Domosapiens wrote: ↑07 Apr 2020, 15:24 [...]
That can have a much wider range compared to a bank app.
Before posting a such harsh comment as you did before you should have had a deep look into yout own skills.Domosapiens wrote: ↑07 Apr 2020, 15:24 But if this application has a hidden connection to the outside world ...
A firewall on Android is much more powerful than the firewalls on windows ever would be. Just install "firewall without root" - the by far easiest way, specially for noobs - on your phone and have a look at the protocols. If you ever would have had installed a firewall on your Android phone you would have been be surprised, who, when and with whom your phone communicates.
The protocls surveying IoT Mage show one thing: It scans your network for answers on port :80 - nothing else. And this is exactly what it was designed for and what it is supposed to do.
So, please, don't blame someone whom you don't know with things from which you don't know what you are talking about.
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
@tiomny: Don't let yourself getting discouraged by such a discussion which nobody needs in a community like this one....
pi@raspberrypi:~ $
Thank you for your support - you found the right words and the right instruments to prove that my effort isn't useless. I appreciate it.
Currently I am working on solving strange misbehavior of the Sliver App Bar on the device web page, and it was encouraging to read that the app makes sense for someone apart from me.
I am getting more and more happy with the app. Meanwhile ther are some enhancements, ie the webpages of the devices are pretty responsive and scrollable.
Getting access to deep sleep devices now is easy going, just tap the device in the list, the app will wait for the device to wake up, send a desired command (ie NoSleep) and I have my deep sleep device ready for configuring, updating or whatever.
And I do have an overview of devices which makes it pretty much easier to manage them:
pi@raspberrypi:~ $
Version 1.2.4: removed Google Services.
Tried to make a scan from the phone in tethering (Access Point) mode. It actually would be my primary use of the app, searching for ESPs with those random dhcp addresses in 192.168.43 range. No go though, neither normal scan nor deep. Did you consider using the app that way?
I think that the app should work that way, although I didn't test it.chemmex wrote: ↑17 Apr 2020, 01:08 Tried to make a scan from the phone in tethering (Access Point) mode. It actually would be my primary use of the app, searching for ESPs with those random dhcp addresses in 192.168.43 range. No go though, neither normal scan nor deep. Did you consider using the app that way?
Are the devices connected to the phone AP to the same subnet as the phone's?
Tell me, how did you translate into other languages for your application? Thanks! I am contemplating German localization with TheWordPoint from this review https://pickwriters.com/german-translation-services. What further actions and tools would you recommend to me? This is my first experience, and it is important for me to get a quality result.
Hello, i created a simple and easy to use Android app that you can use to control your ESPEasy devices. For start, it only has a ON/OFF device switch and next thing to do is adding and triggering Rules. You may find it useful.
https://play.google.com/store/apps/deta ... .smarthome
Also, if anyone is interested about the code, feel free to contact me, it's Public project on GitHub and it is following Android Best practices(Kotlin/Dagger Hilt/Retrofit/MVVM).
Great,
Please share the Github url, so we'll be able to look at the source
Yes, sure, here is the link to the repository: https://github.com/antoniodjakov/smart-home
Also, link to the app on PlayStore: https://play.google.com/store/apps/deta ... .smarthome
You know, it's a very useful application.Thank you for sharing these codes too. It would be really helpful for my further university project as we decided to make a Wifi stabilizer application for Android system. It's quite personal for me because I ofter have troubles with wi-fi connection. But honestly, I have never dealt before with Android platform so that would be very challenging for me. I know that I have to read a lot tutorials and guides to understand its capabilities and nuances. My colleague recommended me have a look at what is android system webview and it looks really informative.
Users browsing this forum: Bing [Bot] and 40 guests
