controller publish
controller publish
hello everyone I am a beginner and I installed a PIR sensor HC-SR501 a wemos mini d1 esp32, everything works with espeasy everything works well for the moment, on the other hand to add it to my box domotic jeedom, it is well recognized also with espeasy plugin but in espeasy mega it does not want to register my controller publish command which is: device =% sysname% & taskid =% id% & cmd =% valname% & value =% value%,
when i click on sumit it only keeps: device =% sysname% i don't know why.
Thank you in advance for your help.
Re: controller publish
What version?
The spaces in your command are intentional for the forum? Or are they also in your settings? In that case: remove the extra spaces...
version its esp32 R20100 and no space in the command
Try latest R20106 please.
I can't find this version
I find that this version on google it does not speak of the R20106 version.
https://www.letscontrolit.com/wiki/inde ... =ESPEasy32
someone would have this version R20106 ? I find it nowhere
Ok, I thought you liked referring to the version that way. It's the latest version found on GitHub.
unfortunately I have looked everywhere since yesterday on the net I can't find any solution to this problem it's a shame because everything works however.
And you have tried the latest code? https://github.com/letscontrolit/ESPEasy
i tried to flash these codes but i am on a esp 32s and it does not work the flash with that.
each time I tried flash failed.
I managed to flash only with ESPEasy32_R20100
You probably need to do it from an IDE. We're not 100% ready with the release of ESP32 versions.
See my post here (I'm not going to cut/paste it to say exactly the same twice )
https://www.letscontrolit.com/forum/vie ... 622#p44622
