HTTP GPIO Monitor
vampo
HTTP GPIO Monitor
#1 Post by vampo » 06 May 2020, 18:28
Hi.
I am searching for a way to read the state of GPIO pin.
In the command referencehttps://espeasy.readthedocs.io/en/lates ... mmand.html I see there is a "Monitor" command, which should to just that.
Monitor,<GPIO>
GPIO: 0 … 16
To monitor a GPIO state. By the use of the command you will receive events when the GPIO state of that pin is changed from 1 to 0 and from 0 to 1.
I am using ESPEasy version "mega-20200426", but I get "Unknown or restricted command" and "Command not found".
Why the command is not working, or how can I get the GPIO input value otherwise?
Thanks a lot!
Re: HTTP GPIO Monitor
#2 Post by grovkillen » 06 May 2020, 18:57
How do you use the command?
Monitor,GPIO,14
When the GPIO state change is detected you get this event:
On GPIO#14 Do
  //%eventvalue% will have the state 1 or 0
EndOn
8-)
vampo
#3 Post by vampo » 08 May 2020, 17:38
Thanks!!!
I was trying like that:
Monitor,14
Maybe the documentation is old?
#4 Post by grovkillen » 08 May 2020, 17:54
Yes it seems to be incorrect. Thanks for that.
Users browsing this forum: No registered users and 105 guests
