But there is one error while building custom_ESP8266_4M1M which I can't solve and google hasn't an answer for me.
I don't know if this is the right place for this question, but I would like to write a custom plugin (and maybe contribute it).
Without a working Build of the stock ESPeasy code I cannot start
Sorry for bothering you because it's likely a setup problem and not a code problem.
Compiling .pio/build/custom_ESP8266_4M1M/liba9a/ArduinoOTA_ID6178/WiFiOTA.cpp.o
/home/MYUSER/.platformio/lib/ArduinoOTA_ID6178/src/InternalStorageESP.cpp: In member function 'virtual int InternalStorageESPClass::open(int, uint8_t)':
/home/MYUSER/.platformio/lib/ArduinoOTA_ID6178/src/InternalStorageESP.cpp:35:56: error: 'U_SPIFFS' was not declared in this scope
return Update.begin(length, command == 0 ? U_FLASH : U_SPIFFS);
/home/MYUSER/.platformio/lib/ArduinoOTA_ID6178/src/InternalStorageESP.cpp:36:1: warning: control reaches end of non-void function [-Wreturn-type]
*** [.pio/build/custom_ESP8266_4M1M/liba9a/ArduinoOTA_ID6178/InternalStorageESP.cpp.o] Error 1
