I am searching for a way to read the state of GPIO pin.
In the command referencehttps://espeasy.readthedocs.io/en/lates ... mmand.html I see there is a "Monitor" command, which should to just that.
I am using ESPEasy version "mega-20200426", but I get "Unknown or restricted command" and "Command not found".Monitor,<GPIO>
GPIO: 0 … 16
To monitor a GPIO state. By the use of the command you will receive events when the GPIO state of that pin is changed from 1 to 0 and from 0 to 1.
Why the command is not working, or how can I get the GPIO input value otherwise?
Thanks a lot!
