Hi to all,
Is there any way to send shutdown command to raspberry with espeasy?
send shutdown command for raspberry
Re: send shutdown command for raspberry
If you mean you don't want to add a wired connected to the RPi (GPIO shutdown), then that leaves you with a SendToHTTP rule. I Found this discussion that explains how to enable it on the RPi: https://www.raspberrypi.org/forums/view ... hp?t=58802
ThomasB wrote: ↑16 May 2020, 19:17 If you mean you don't want to add a wired connected to the RPi (GPIO shutdown), then that leaves you with a SendToHTTP rule. I Found this discussion that explains how to enable it on the RPi: https://www.raspberrypi.org/forums/view ... hp?t=58802
Thanks for that interesting solution. I will try it.
