Dear all,
I would like to implement the equivalent of this library as a plugin, do you think it's possible for a beginner?
https://github.com/Locoduino/SlowMotionServo
THank you in advance!
SlowMotionServo
Re: SlowMotionServo
I didn't see anything obvious in the library that would cause problems for ESPEasy. That is to say, no blocking calls or hard delays.I would like to implement the equivalent of this library as a plugin ...
As far as a beginner writing a ESPEasy plugin, I think success will be up to the "beginner." If you're a ESPEasy newbie but have plenty of C++ coding experience then it should be a pleasant experience. But if this is your first coding rodeo then hang on tight, the ride might get bumpy.
Re: SlowMotionServo
First thank you for your replies!
I spend hours compiling and reading pages like this... but still too time consuming and difficult for me I will write directly some lines for what I want, sorry for people who find this post :S
Even ESP"Easy" not so easy behind ! beautifull work by the way !
https://diyprojects.io/esp-easy-develop-plugins/#.
Users browsing this forum: Ahrefs [Bot] and 29 guests
