Sorry but i didn't find the way to read data from domoticz. I need to get two temperature sensors that have an idx.
It is reachable by http://mydomoticzip/json.htm?type=comma ... value=TEMP
Thank you
Read data from domoticz
Re: Read data from domoticz
Most advised way is to install a MQTT broker next to Domoticz (Mosquitto is often used on the 'default' Domoticz RPi configuration), and use the MQTT Import plugin to fetch the values from Domoticz.
For the solution, to which programming language are you looking?
In other words, what is the script & function you have in mind as destination for this temperature-data?
Good question!
As this is posted in the ESPEasy forum, I'm assuming this is asked to get the temperatures, probably shown on some display connected to an ESP board.
![Knipoog ;)](./images/smilies/icon_e_wink.gif)
