after now 6 month later I updated my ESP's from FW mega-20191208 to mega-20200608.
After Update I could not switch any GPIO as before with a Node Red command like for example: Topic /ESP_Garage_9/gpio/13 Msg will be 0 ore 1
I tried several FW from 2020 with the same result. After downgrade to mega-20191208 I could switch all my GPIO's as before.
Was there an change in FW so I have to make a different approach to switch GPIO's or is there a Bug? Wich I could believe for such a long time.
Thx
ESP Easy FW Dec.2019 Vs. June 2020 FW
Re: ESP Easy FW Dec.2019 Vs. June 2020 FW
With the newer ESPEasy versions, you might want to uncheck the 'Append Unit Number to hostname' option on the Config page.
Thank you, this does the trick.
Users browsing this forum: No registered users and 139 guests
