Rules same GPIO and Longpress event
I'm Using on ESP_01 with a PIR on GPIO 2 and a Relay on GPIO 0.
In parallel on the pir, I have a push button.
By the action of the PIR or the push button the relay is activated for 5 seconds (this work).
By pressing the push button for more than 4 sec. I would like to switch on the relay with a delay of 25 seconds.
LongPress detection: GPIO= 2 State=1 Output value=11 is OK.
But the elseif [ESP_01-PIR#STATE]=11.00 is not executed !
I tested also with =11 but it's dosent work too.
Below ma Rule.
Many thanks in advance for your help
Otto
Rules set 1:
on System#Boot do
LongPulse,0,1,5
on ESP_01-PIR#STATE do
if [ESP_01-PIR#STATE]=1 // PIR ou Button
LongPulse,0,0,5 // Relay ON 5s
elseif [ESP_01-PIR#STATE]=11.00 // Button pressé sur plus de 4 sec.
LongPulse,0,0,25 // Relay ON 25s
Log
966879: SW : GPIO=2 State=1 Output value=1
966882: EVENT: ESP_01-PIR#STATE=1.00
966893: ACT : LongPulse,0,0,5
966894: Command: LongPulse
966897: SW : GPIO 0 Pulse set for 5 sec
970879: SW : LongPress: GPIO= 2 State=1 Output value=11
970882: EVENT: ESP_01-PIR#STATE=11.00
970893: ACT : LongPulse,0,0,5
970894: Command: LongPulse
970897: SW : GPIO 0 Pulse set for 5 sec
972080: SW : GPIO=2 State=0 Output value=0
972082: EVENT: ESP_01-PIR#STATE=0.00
Below ma Rule.
Otto
Rules set 1:
on System#Boot do
LongPulse,0,1,5
Log
- LongpressEvent.jpg (39.54 KiB) Viewed 7932 times
Re: Rules same GPIO and Longpress event
What version of ESPEasy do you have installed?
The latest is always available from https://github.com/letscontrolit/ESPEasy/releases
Try this rule set (untested):
on System#Boot do
LongPulse,0,1,5
if ESP_01-PIR#STATE=11 do // This was a 4 Sec Long press. Extend relay time.
LongPulse,0,0,21 // 4 Secs has already elapsed, add another 21 secs.
on ESP_01-PIR#STATE=1 do // Button is pressed.
LongPulse,0,0,5
Hello Thomas,
Many thanks for your help, but do not work.
Line 6: LongPulse,0,0,21 is not executed!
Otto
59189822: SW : GPIO=2 State=1 Output value=1
59189825: EVENT: ESP_01-PIR#STATE=1.00
59189836: ACT : LongPulse,0,0,5
59189838: Command: LongPulse
59189840: SW : GPIO 0 Pulse set for 5 sec
59192272: WD : Uptime 987 ConnectFailures 0 FreeMem 21384 WiFiStatus 3
59193822: SW : LongPress: GPIO= 2 State=1 Output value=11
59193825: EVENT: ESP_01-PIR#STATE=11.00
59195622: SW : GPIO=2 State=0 Output value=0
59195625: EVENT: ESP_01-PIR#STATE=0.00
Otto
I'm using the following version : ESP_Easy_mega-20200426_normal_ESP8266_1M.bin
Just to be sure it isn't causing any issues, can you change the task name to not include a minus sign?
I think the if should be on:
And removing the minus from the name, as TD-er suggested, will also help (should be added as 'unsupported' to the name-check, IMHO).
on ESP_01-PIR#STATE=11 do // This was a 4 Sec Long press. Extend relay time.
I removed the minus and use the sample from Ath, now every thing work very well.
Otto
Otto
Oops. Thanks for catching my typo ("if" should be "on").I think the if should be on:
Hello Thomas,
Yes the if must be "on".
Now I have to complete my script. When I press 4 seconds, it puts a delay of 25 sec.
But if someone moves the PIR it puts the delay back to 5 sec.
Otto
Otto
You can solve that by raising a flag during the extended time:
on System#Boot do
LongPulse,0,1,5
Let 1,0 // Reset flag
on ESP_01PIR#STATE=11 do // This was a 4 Sec Long press. Extend relay time.
Let 1,1 // Raise flag
TimerSet 1,21
on ESP_01PIR#STATE=1 do // Button is pressed.
if %v1%=0 // Only if flag not raised
LongPulse,0,0,5
on Rules#Timer=1 do
Work well.
Otto
Otto
