I found this library for arduino to read 1-wire counter DS2423 https://github.com/jbechter/arduino-onewire-DS2423
How is it possible to integrate as a new espeasy plugin ?
Thomas
How could it be difficult to integrate 1-wire DS2423 in easpeasy ?
Re: How could it be difficult to integrate 1-wire DS2423 in easpeasy ?
+1
I would love this, too, so I can access my gas counter via network.
I found a guy who implemented MQTT on ESP8266 for Dallas AAG weather station, which is using DS2423...
http://www.sariwating.net/2016/04/10/mq ... r-station/
His code should be investiguated...
Thomas
Thomas
Long overdue, but I finally published the plugin I've been running for some years. I just refactored it, based on latest _P004_Dallas.ino, so it works with the most current release, mega-20200913. I have tested it both on ESP8266 (Wemos D1 mini) and ESP32 (M5Stack Atom Lite).
https://github.com/letscontrolit/ESPEas ... ounter.ino
Thanks, I will include it in the main repo, so it can also be incorporated when the Dallas code gets refactored into a central 1-wire handler.
Yes, I noticed that P004 (Temperature) and P080 (iButton) have almost the same 1-wire low-level code. And now I made the third copy of it.
Is there any reason to not use the standard Arduino OneWire and DallasTemperature libraries?
Absolutely there is a reason for it... but I don't know it ![Lach :)](./images/smilies/icon_e_smile.gif)
Either there wasn't any when the Dallas plugin was written, or it wasn't working right or maybe the only one available back then was using the wrong license.
I simply don't know.
Users browsing this forum: Ahrefs [Bot] and 0 guests
