RPIEasy
Moderators: grovkillen, Stuntteam, TD-er, enesbcs
2stimpy
Re: RPIEasy
#301 Post by 2stimpy » 14 Oct 2020, 20:34
If I check that box, after I press submit, it automatically unchecks.
Probably because I use output(high), I use this, because this is the only setting to make sure the relay does not switch at startup.
And that probably has something to do with the fact that when the relay is low, the state is 1. And when the relay is activated the state is 0.
I have tried output when the box will check. I still can't switch while publishing to the set topic.
I first have to toggle in the interface.
Maybe there is a rule to send the current state to the state topic on rpi start.
enesbcs
Re: RPIEasy
#302 Post by enesbcs » 14 Oct 2020, 21:33
2stimpy wrote: 14 Oct 2020, 20:34 Maybe there is a rule to send the current state to the state topic on rpi start.
RPIEasy updated.
Please add debug log lines next time, when you have questions about how RPIEasy works.
2stimpy
Re: RPIEasy
#303 Post by 2stimpy » 15 Oct 2020, 18:43
18:31:35 Event: gpio2#HekStatus=0
18:31:35 Event: gpio3#Deurbel=0
18:31:35 Event: gpio4#Brievenbus=0
18:31:35 State preserving is disabled
18:31:35 Event: gpio14#Doorgang=0
18:31:35 Event: GenMQTT#Disconnected
18:31:35 MQTT controller: xxx.0.0.xxx:xxxx connection failed [Errno 101] Network is unreachable
18:31:35 Event: System#Boot
18:31:35 Webserver starting at port 80
18:31:35 Event: Clock#Time=Thu,18:31
18:31:35 Event: Network#Disconnected
18:32:00 Event: Clock#Time=Thu,18:32
18:33:00 Event: Clock#Time=Thu,18:33
18:34:00 Event: Clock#Time=Thu,18:34
18:35:00 Event: Clock#Time=Thu,18:35
18:35:58 Event: relais#hek=0
18:35:58 CMD: timerSet,1,2
18:35:58 MQTT not connected, sending failed.
18:35:58 Event: GenMQTT#Connected
18:36:00 Event: Rules#Timer=1
18:36:00 CMD: gpio,15,1
18:36:00 Event: relais#hek=1
18:36:00 Event: Clock#Time=Thu,18:36
18:36:51 Event: relais#hek=0
18:36:51 CMD: timerSet,1,2
18:36:53 Event: Rules#Timer=1
18:36:53 CMD: gpio,15,1
18:36:53 Event: relais#hek=1
18:37:00 Event: Clock#Time=Thu,18:37
18:37:14 Event: relais#hek=0
18:37:14 CMD: timerSet,1,2
18:37:16 Event: Rules#Timer=1
18:37:16 CMD: gpio,15,1
18:37:16 Event: relais#hek=1
18:38:00 Event: Clock#Time=Thu,18:38
18:38:21 Event: relais#hek=0
18:38:21 CMD: timerSet,1,2
18:38:23 Event: Rules#Timer=1
18:38:23 CMD: gpio,15,1
18:38:23 Event: relais#hek=1
18:39:00 Event: Clock#Time=Thu,18:39
18:40:00 Event: Clock#Time=Thu,18:40
18:41:00 Event: Clock#Time=Thu,18:41
18:42:00 Event: Clock#Time=Thu,18:42
18:43:00 Event: Clock#Time=Thu,18:43
18:43:48 Event: GenMQTT#Disconnected
18:43:48 Event: GenMQTT#Connected
18:44:00 Event: Clock#Time=Thu,18:44
18:45:00 Event: Clock#Time=Thu,18:45
18:46:00 Event: Clock#Time=Thu,18:46
18:47:00 Event: Clock#Time=Thu,18:47
18:48:00 Event: Clock#Time=Thu,18:48
18:49:00 Event: Clock#Time=Thu,18:49
18:50:00 Event: Clock#Time=Thu,18:50
18:51:00 Event: Clock#Time=Thu,18:51
18:52:00 Event: Clock#Time=Thu,18:52
18:53:00 Event: Clock#Time=Thu,18:53
18:54:00 Event: Clock#Time=Thu,18:54
18:55:00 Event: Clock#Time=Thu,18:55
18:56:00 Event: Clock#Time=Thu,18:56
Here is a log after a restart. MQTT is not connected at first, only after pushing the toggle it will connect.
Strange, have to dig into that.
enesbcs
Re: RPIEasy
#304 Post by enesbcs » 15 Oct 2020, 19:36
2stimpy wrote: 15 Oct 2020, 18:43
18:31:35 MQTT controller: xx.0.0.xxx:xxxx:1883 connection failed [Errno 101] Network is unreachable
Not just the MQTT, the whole TCP/IP network is disconnected. Wifi or Ethernet? Did you try with a larger power supply or separating the relay to another power supply - with common ground?
2stimpy
Re: RPIEasy
#305 Post by 2stimpy » 15 Oct 2020, 19:43
Even with the relay disconnected this message appears.
The power supply is an original pi one.
below is a log without anything connected.
19:39:48 Event: gpio2#HekStatus=0
19:39:48 Event: gpio3#Deurbel=0
19:39:48 Event: gpio4#Brievenbus=0
19:39:48 State preserving is disabled
19:39:48 Event: gpio14#Doorgang=0
19:39:48 Event: GenMQTT#Disconnected
19:39:48 MQTT controller: xx.0.0.xxx:xxxx connection failed [Errno 101] Network is unreachable
19:39:49 Event: System#Boot
19:39:49 Webserver starting at port 80
19:39:49 Event: Clock#Time=Thu,19:39
19:39:49 Event: Network#Disconnected
19:40:00 Event: Clock#Time=Thu,19:40
19:41:00 Event: Clock#Time=Thu,19:41
19:42:00 Event: Clock#Time=Thu,19:42
19:42:19 Event: relais#hek=0
19:42:19 CMD: timerSet,1,2
19:42:19 MQTT not connected, sending failed.
19:42:19 Event: GenMQTT#Connected
19:42:21 Event: Rules#Timer=1
19:42:21 CMD: gpio,15,1
19:42:21 Event: relais#hek=1
19:42:28 Event: relais#hek=0
19:42:28 CMD: timerSet,1,2
19:42:30 Event: Rules#Timer=1
19:42:30 CMD: gpio,15,1
19:42:30 Event: relais#hek=1
19:42:33 Event: relais#hek=0
19:42:33 CMD: timerSet,1,2
19:42:35 Event: Rules#Timer=1
19:42:35 CMD: gpio,15,1
19:42:35 Event: relais#hek=1
Isn't it strange that it is starting the webserver after it tries to connect to the network?
enesbcs
Re: RPIEasy
#306 Post by enesbcs » 16 Oct 2020, 09:31
2stimpy wrote: 15 Oct 2020, 19:43 Isn't it strange that it is starting the webserver after it tries to connect to the network?
There is nothing strange in the starting of the webserver, as it is unconditional.
Is it wifi connection? Ethernet is connected or not? Which Raspbian release?
2stimpy
Re: RPIEasy
#307 Post by 2stimpy » 16 Oct 2020, 20:54
I have debian buster installed, maybe thats the problem.
I'll try raspbian this weekend.
2stimpy
Re: RPIEasy
#308 Post by 2stimpy » 18 Oct 2020, 19:28
I did a new fresh install with the desktop and let it update after installation.
After that I installed RpiEasy again and configured it.
I have no idea why this is happening but again my (ethernet) network does not seem to work correct.
19:23:00 Event: gpio2#HekStatus=0
19:23:00 Event: gpio3#Deurbel=0
19:23:00 Event: gpio4#Brievenbus=0
19:23:00 Event: gpio14#Doorgang=0
19:23:00 Event: relais#hek=1
19:23:00 relais: Restoring previous GPIO value 1
19:23:00 State preserving is enabled
19:23:00 Event: GenMQTT#Disconnected
19:23:00 MQTT controller: xx.0.0.xxx:xxxx connection failed [Errno 101] Network is unreachable
19:23:00 Event: System#Boot
19:23:00 Webserver starting at port 80
19:23:00 Event: Clock#Time=Sun,19:23
And when I enable Wifi I get the same error, except later it says network connected.
But still no mgtt message on first attempt. I have to push the toggle button once to get a message, or activate one of the other switches by pressing run.
Otherwise mqtt will not connect.
19:48:33 Event: gpio2#HekStatus=0
19:48:33 Event: gpio3#Deurbel=0
19:48:33 Event: gpio4#Brievenbus=0
19:48:33 Event: gpio14#Doorgang=0
19:48:33 Event: relais#hek=1
19:48:33 relais: Restoring previous GPIO value 1
19:48:33 State preserving is enabled
19:48:33 Event: GenMQTT#Disconnected
19:48:33 MQTT controller: xx.0.0.xxx:xxxx:1883 connection failed [Errno 101] Network is unreachable
19:48:33 Event: System#Boot
19:48:33 Webserver starting at port 80
19:48:33 Event: Clock#Time=Sun,19:48
19:48:33 Event: Network#Connected
19:49:09 Event: Clock#Time=Sun,19:49
enesbcs
Re: RPIEasy
#309 Post by enesbcs » 18 Oct 2020, 21:12
2stimpy wrote: 18 Oct 2020, 19:28 I have no idea why this is happening but again my (ethernet) network does not seem to work correct.
At least there are no active network connection available when RPIEasy starting. Maybe the dhcp process waiting for a long time, or other boot processes take place first before dhcp. It is not RPIEasy related as RPIEasy did not manage the network layer, but Linux startup sequence related question.
2stimpy wrote: 18 Oct 2020, 19:28 Otherwise mqtt will not connect.
I guess you have no real sensor task in your configuration, as the RPIEasy mqtt controller tries to reconnect automatically when a _sensor_ fails to send information.
But actuators do not send data periodically, so self healing was never triggered, until you click manually as you said...
I've added a new option to "Generic MQTT controller": "Check conn & reconnect if needed at every 30 sec". Please update RPIEasy, restart, then enable it and try again.
2stimpy
Re: RPIEasy
#310 Post by 2stimpy » 18 Oct 2020, 21:42
I do not have dhcp enabled because I like to have a fixed ip, so I know on what address I can reach the pi.
I did te upgrade and this was my log right after that. Strange thing is that mqtt is connecting right away.
21:24:18 .........
21:24:18 Event: GenMQTT#Connected
21:24:18 Event: System#Boot
21:24:18 Webserver starting at port 80
21:24:18 Event: Clock#Time=Sun,21:24
21:24:51 Event: GenMQTT#Disconnected
21:24:51 Event: GenMQTT#Connected
21:24:57 Event: GenMQTT#Disconnected
21:24:57 Event: GenMQTT#Connected
21:25:00 Event: Clock#Time=Sun,21:25
This is the second restart and here is the failed connection back.
But as you can see your added option does the trick.
21:27:23 Event: GenMQTT#Disconnected
21:27:23 MQTT controller: xx.0.0.xxx:xxxx connection failed [Errno 101] Network is unreachable
21:27:23 Event: System#Boot
21:27:23 Webserver starting at port 80
21:27:23 Event: Clock#Time=Sun,21:27
21:27:53 Event: GenMQTT#Connected
21:28:09 Event: Clock#Time=Sun,21:28
21:28:49 Event: relais#hek=0
21:28:49 CMD: timerSet,1,2
21:28:51 Event: Rules#Timer=1
21:28:51 CMD: gpio,15,1
21:28:51 Event: relais#hek=1
My relay is reacting right upon the first switching moment. The switches(sensor) also work right after the mqtt reconnect.
Below is the third restart, again with mqtt connected right away, strange.
21:36:57 ...........
21:36:57 Event: GenMQTT#Disconnected
21:36:57 Event: GenMQTT#Connected
21:36:57 Event: System#Boot
21:36:57 Webserver starting at port 80
21:36:57 Event: Clock#Time=Sun,21:36
It doesn't really mather now, this is working great.
Thank you so much for your help, and most of all your patience.
Greetz Arnold
Re: RPIEasy
#311 Post by Ath » 18 Oct 2020, 22:58
Arnold, there is no need to 'hide' the 10.0.0.x ip-address of your MQTT server, as that ip range is not routable over the internet as it is specially reserved for local intranets (many routers use it for their internal network, similar to the 192.168.x.y range, and a couple more), so nobody can reach it from 'outside'. Just to save you some editing of the logs :D
/Ton
2stimpy
Re: RPIEasy
#312 Post by 2stimpy » 19 Oct 2020, 09:25
Ok, I wasn't sure about the visible ip.
At first I thought it was ok, you can see it in a quote. Later I thought, better safe than sorry. But of course it had no effect because of the quote witch already had my ip in it. :(
enesbcs
Re: RPIEasy
#313 Post by enesbcs » 19 Oct 2020, 09:30
Yep, 10.x.x.x is not routable address range. But if anybody get into your network, for example with a help of a cloud-enabled hacked IP camera, than will have a good idea where is your server... But it is unlikely. :)
