There is a ir receiver device (VS1338B similar TSOP4838) and a ir transmitter led in the nodemcu. I can shutdown my samsung smart tv with sending <esp ip>/control?cmd=IRSEND,SAMSUNG,e0e09966,32 code. e0e09966 is my tv shutdown hex format command. I need to open smart tv web browser with sending hex code but i could not find. If i open the web browser by sending command with my harmony hub(universal remote controller), nodemcu ir receiver show me the 3772816993 value, so how can i transform that value to the hex data to send it with my nodemcu's ir transmitter?
IR Receiver data transformation to IR Sender
- IR_1.png (13.62 KiB) Viewed 7835 times
Re: IR Receiver data transformation to IR Sender
ESPeasy has a string transform function (strtol). But it converts any base value to decimal, not the other way around.so how can i transform that value to the hex data to send it with my nodemcu's ir transmitter?
I suggest using an online decimal-to-hex convertor to determine the equivalent hex value for your IR command. For example: https://www.rapidtables.com/convert/num ... o-hex.html
Ohh thank your reply but it seems no need any transformation. I notice that at the log page esp easy already convert it to the hex code for us. I attach the log page maybe future reference for somebody.ThomasB wrote: ↑03 Nov 2020, 22:43ESPeasy has a string transform function (strtol). But it converts any base value to decimal, not the other way around.so how can i transform that value to the hex data to send it with my nodemcu's ir transmitter?
- IR_2_1.png (52.4 KiB) Viewed 7822 times
@Thomas: See the system variables page: To HEX: %c_2hex%(100000)
And there is even very extensive documentation about it https://espeasy.readthedocs.io/en/lates ... onversions
@asuz: Good to know you found what you needed. BTW, the log message you show is for IR SEND's data, whereas you were asking about converting the data from IR RECV.
@TD-er: Oh, new feature. Appears to be hot and fresh out of the oven. Thanks for adding it (and for documenting it too).
Maybe there is a misunderstanding. I was trying to find the command of opening smart tv web browser ir command. My harmony hub can open the web browser but i want to do it without harmony hub. As i told you i need it is hex code to send it by ir led of ESP Easy . When i send to open web browser command with harmony hub, ir receiver in the ESP Easy box returns with the data of 3772816993 value but i cannot use it because i need hex code then i notice that ESP Easy already convert it to hex code at the log page so i use that hex code at the log page.ThomasB wrote: ↑04 Nov 2020, 00:02 @asuz: Good to know you found what you needed. BTW, the log message you show is for IR SEND's data, whereas you were asking about converting the data from IR RECV.
Users browsing this forum: Google [Bot] and 13 guests
