Send cmd via mqtt from Home assistant
Patou
#1 Post by Patou » 16 Nov 2020, 23:33
I do not find in the topics of this forum or in the doc the exact way to send mqtt data from home assistant using 'cmd'
On a mqtt tracker I see the messages so mqtt is correctly configured. On Esp1 this is the configuration
When I use the MQTT helper I can receive the message from HA
I tried following without success :
    - service: mqtt.publish
      data_template:
        topic: 'Esp1/cmd'
        retain: true
        payload: 'event:ha_start'
      data_template:
        topic: 'Esp1/cmd'
        retain: true
        payload: 'event,ha_start'
      data_template:
        topic: 'Esp1/control?cmd'
        retain: true
In the Esp1 device :
On ha_start do
 event,publish_data
But on the log of Esp1 I do not see the event ... I do something wrong bur what ??
Thanks in advance for your help
Patou
Patou
Re: Send cmd via mqtt from Home assistant syntax
#2 Post by Patou » 17 Nov 2020, 01:33
Finally found the correct syntax :
Need "xx" and not 'xx' !!
      data_template:
        topic: 'Volet_Living/cmd'
        retain: true
        payload: "event,ha_start"
Patou
#3 Post by Patou » 17 Nov 2020, 02:02
I also discover that firmware 'ESP_Easy_mega-20200426_normal_ESP8266_4M1M.bin' has the problem
but firmwares
- ESP_Easy_mega_20200812_normal_ESP8266_4M1M
- ESP_Easy_mega-20200310_normal_ESP8266_4M1M
have no problem !
