WT32-ETH01
WT32-ETH01
Anyone has any experience with this ESP32 / LAN8720 module ?
Product Page :
http://www.wireless-tag.com/portfolio/wt32-eth01/
Datasheet:
https://tinyurl.com/WT32-ETH01
AliExpress:
https://www.aliexpress.com/item/1005001739834076.html
-D
Product Page :
Datasheet:
AliExpress:
-D
-D
Re: WT32-ETH01
Have you tried the "eth" builds?
Re: WT32-ETH01
Yeah, i have a few Olimex ESP32-POE working stable on the eth builds.
I wish there was support for more Enviroment and switch (MCP23017) devices.
(Not sure how a GPS module is useful to a wired module)
-D
-D
Re: WT32-ETH01
GPS can be useful to get a very accurate time, without any drift.
It is like an atomic clock.
And about the MCP23017 you mentioned...
I ordered it 8 days ago, so I guess it will be here soon.
Re: WT32-ETH01
NTP, DST and Location settings work great for me in terms of time.
MCP23017 has been stable in ESP8266 for a long time now.
-D
-D
-D
Re: WT32-ETH01
MCP23017 is part of P009.
The GPIO related stuff has now moved to be an internal command, so I guess it should now work on ESP32 too in the more recent builds.
Isn't it working?
Isn't it working?
Re: WT32-ETH01
Checking on Tasmota's work in an effort to save me any headache if possible on the WT32-ETH01 (should be coming in soon)
Seems GPIO18 and 23 are common. In the Olimex board I use GPIO12 as "Ethernet Power pin:"
I wonder if it is as simple as choosing GPIO16 as on arendst's code above ?
* {"NAME":"Olimex ESP32-PoE","GPIO":[1,1,1,1,1,1,0,0,5536,1,1,1,1,0,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,1,1,1,0,0,1],"FLAG":0,"BASE":1}
* GPIO12 = ETH POWER
* GPIO18 = ETH MDIO
* GPIO23 = ETH MDC
* #define ETH_TYPE ETH_PHY_LAN8720
* #define ETH_CLKMODE ETH_CLOCK_GPIO17_OUT
* #define ETH_ADDR 0
* {"NAME":"wESP32","GPIO":[0,0,1,0,1,1,0,0,1,1,1,1,5568,5600,1,0,0,0,0,1,0,0,0,0,0,0,0,0,1,1,1,1,1,0,0,1],"FLAG":0,"BASE":1}
* GPIO16 = ETH MDC
* GPIO17 = ETH MDIO
* #define ETH_CLKMODE ETH_CLOCK_GPIO0_IN
* {"NAME":"WT32-ETH01","GPIO":[1,1,1,1,1,1,0,0,1,0,1,1,3840,576,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,0,1,1,0,0,1],"FLAG":0,"BASE":1}
* GPIO16 = Force Hi
* GPIO18 = ETH MDIO
* GPIO23 = ETH MDC
* #define ETH_ADDR 1
-D
Re: WT32-ETH01
Have you tried the ETH builds?
I do have all Olimex ETH boards running here for months and all configurations they use are working very well in ESPEasy.
Re: WT32-ETH01
Seems like you missed the last part of my post below the code.
The eth bins work great on the Olimex ESP32-PoE units I have on hand.
I am now expecting to receive the WT32-ETH01 units and was wondering on the GPIO settings for that, therefore I looked into arendst's code.
-D
Re: WT32-ETH01
Judging the code you posted from Tasmota, it indeed looks like the GPIO16 pin may be connected as power enable pin.
But I wonder why it is marked for the Olimex as "ETH POWER" and on the WT32-ETH01 as "Force Hi".
That sounds like it may be a bit different.
Here it is suggested it is indeed the power pin: https://community.home-assistant.io/t/e ... /110390/65
Re: WT32-ETH01
Im pretty fresh to these iot stuff but I admire it. I have a domoticz setup running but would now like to expand it in areas without wifi or zwave coverage, like a gate and in basement and in my garden to control rgbw led fllood lights. The PoE makes it also very versatile for my needs.
Is there a chance the espeasy would also run onto the wesp32? I read the blog of the creator and it seems for the novice eye perfect for my needs and I would like to support him also using his boards. But ffcourse I am not into programming so as a almost end user I would need to have some feeling how good the ESPEasy firmware would suit this hardware.
https://hackaday.io/project/85389-wesp3 ... et-and-poe
https://wesp32.com/
If not I will need to use the Olimex ISO esp32 board.
thanks in advance
https://wesp32.com/
thanks in advance
Re: WT32-ETH01
Taken from the product brief: https://wesp32.com/files/wESP32-Product-Brief.pdf (page 8)
So based on that I would expect it will work just fine with ESPEasy.• Ethernet PHY type is Microchip LAN8720
• PHY address is 0
• EMAC clock mode is GPIO0 input
• Use PHY power pin is disabled
• SMI MDC pin is 16, SMI MDIO pin is 17
Re: WT32-ETH01
Yes, i have tested with ESP_Easy_mega_20201102_custom_ESP32_4M316k_ETH-factory.bin binary and WT32-ETH01 works fine.iron wrote: ↑28 Nov 2020, 21:45 Checking on Tasmota's work in an effort to save me any headache if possible on the WT32-ETH01 (should be coming in soon)
Seems GPIO18 and 23 are common. In the Olimex board I use GPIO12 as "Ethernet Power pin:"Code: Select all
* {"NAME":"WT32-ETH01","GPIO":[1,1,1,1,1,1,0,0,1,0,1,1,3840,576,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,0,1,1,0,0,1],"FLAG":0,"BASE":1} * GPIO16 = Force Hi * GPIO18 = ETH MDIO * GPIO23 = ETH MDC * #define ETH_TYPE ETH_PHY_LAN8720 * #define ETH_CLKMODE ETH_CLOCK_GPIO0_IN * #define ETH_ADDR 1 * \*********************************************************************************************/
Preferred network: Ethernet
Ethernet PHY type: LAN8710
Ethernet PHY Address: 1
GPIO MDC: GPIO-23
GPIO MIO: GPIO-18
GPIO POWER: GPIO-16
Ethernet Clock: External crystal oscillator
Users browsing this forum: Bing [Bot] and 11 guests
