Error message plugin 119 BME680 -SENSOR_TYPE_QUAD' was not declared in this scope
I wanted to install the plugin 119 for the BME680 with the Arduino IDE.
When compiling the editor in plug-in 119 gets stuck with the following error message:
'SENSOR_TYPE_QUAD' was not declared in this scope
The line in the plugin is:
Device [deviceCount] .VType = SENSOR_TYPE_QUAD;
I didn't find anything really right in google, does anyone have an idea?
Greetings Dondolo
Greetings Dondolo
Re: Error message plugin 119 BME680 -SENSOR_TYPE_QUAD' was not declared in this scope
Add this prefix:
Sensor_VType::
Also don't forget to use this include at the beginning:
and if the #ifdef isn't there in the current file, make sure to add
at the end.
Sensor_VType::
Device [deviceCount] .VType = Sensor_VType::SENSOR_TYPE_QUAD;
#include "_Plugin_Helper.h"
#ifdef USES_P119
#endif
Hi TD-er,TD-er wrote: ↑22 Nov 2020, 17:10 Add this prefix:
Sensor_VType::
Also don't forget to use this include at the beginning:Code: Select all
and if the #ifdef isn't there in the current file, make sure to addCode: Select all
#include "_Plugin_Helper.h" #ifdef USES_P119
at the end.Code: Select all
#endif
Thanks for the super fast response.
I added the four lines in the plugin 119 file and
I just get the following error message:
In file included from E:\arduino-1.8.13-windows\examples\ESPeasy\ESPEasy.ino:13:0:
ESPEasy_common.h:52:45: fatal error: src/CustomBuild/ESPEasyDefaults.h: No such file or directory
#include "src/CustomBuild/ESPEasyDefaults.h"
compilation terminated.
exit status 1
Did you put the _P119...ino file in the src subdirectory of ESPEasy? (next to all the other _Pxxx .ino files, in the playground they are in the root of the project, but in the mega build they need to be in the src directory)
Looks like you may have an incomplete set of sources?
If you don't set the USES_P119, can you build the sources in your build setup?
If I understood the question correctly, then yes.
I can use the version: mega-20201102
compile without errors.
Can you have a look at the files for this PR I just made?
https://github.com/letscontrolit/ESPEasy/pull/3386
N.B. I also added this library: https://github.com/adafruit/Adafruit_BME680
I renamed the plugin ID to P106
Hi, I really don't know what to do. I tried the modified library and plugin 106 and it doesn't work.
I gave it up for now. Maybe the BME680 sensor is there somewhere.
Thanks for the support and until then.
Dondolo
Dondolo
What kind of build do you need?
4M flash?
ESP8266?
4M flash?
ESP8266?
this version would have been heard
ESP_Easy_mega_20201022_normal_ESP8266_4M1M
Dondolo
Dondolo
Hi TD-er,TD-er wrote: ↑24 Nov 2020, 21:21I made a complete test build for the PR:
https://www.dropbox.com/s/ho9s2khkqnx21 ... 6.zip?dl=0
https://www.dropbox.com/s/5wounjmf8z58x ... 6.zip?dl=0
Thanks for the great support, unfortunately I cannot install the version with the Aduino IDE either.
The following error message stops the compilation:
G:\ESPEasy_ESP82xx_mega-20201102-115-PR_3386\source\src\ESPEasy\ESPEasy.ino:13:28: fatal error: ESPEasy_common.h: No such file or directory
#include "ESPEasy_common.h"
I've used the flasher in the past and it works great.
I can't get any further with the IDE.
Kannst Du vielleicht eine Datei (ESP_Easy_mega_20201124_normal_ESP8266_4M1M.bin) zur Verfügung stellen in der dem BME680 implentiert ist?
Please excuse my ignorance
Greetings Dondolo
The link to the download of a test-build is in the part you quoted...Dondolo wrote: ↑25 Nov 2020, 19:21...TD-er wrote: ↑24 Nov 2020, 21:21 I made a complete test build for the PR:
You will need an ESP_Ease_mega...test...ESP8266_4M1M.bin file to get the BME680 plugin, it works like the 'normal' build, though it might use a bit more memory because of the ~40 extra plugins available. Fully compatible to upgrade a current installation, using the 'Firmware update' button on the Tools tab.
Hi, yes wonderful, I actually got it to run without any problems, thank you very much.Ath wrote: ↑25 Nov 2020, 20:07The link to the download of a test-build is in the part you quoted...Dondolo wrote: ↑25 Nov 2020, 19:21...TD-er wrote: ↑24 Nov 2020, 21:21 I made a complete test build for the PR:
I hadn't flashed the "Test.Version".
Thanks again and let's see how the BME680 continues.
Greetings Dondolo
Users browsing this forum: Bing [Bot] and 43 guests
