Hya,
is there a documentation with examples of MQTT IMPORT plugin?
Thx in advance!
MQTT IMPORT - HOWTO!!!!! WORKING
Re: MQTT IMPORT - howto?
Have you tried clicking the (?) icon near the device name? It will take you to the Wiki documentation, that is a bit outdated, but only in PR#3424 where JSON support, filtering and value mapping will be added, I've updated the ReadTheDocs page. (That page is currently quite empty.)
I haven't added many examples in that new documentation, but the current MQTT Import plugin will only handle a single numeric Value per topic.
You can use rules to react on a changing topic value, as each change there generates an event, or use the value(s) on a display.
Ok, thank you. i will try out and post the doubts, if you don't mind.
Got it:
on HA configuration.yaml
my rules:
for sure i will have to fine tune it, but, it's working.
Thx for pointing the PR#3424
# Kaffeemaschine
binary_sensor km:
- platform: mqtt
unique_id: tc91100
state_topic: "BSTC91100/VACC/status"
# state_topic: "BSTC91100/gpio/4"
payload_on: "1"
payload_off: "0"
availability:
- topic: "BSTC91100/status/LWT"
payload_available: "Online"
payload_not_available: "Offline"
switch km:
- platform: mqtt
# unique_id: tc91100b58
state_topic: "BSTC91100/B58/status"
command_topic: "BSTC91100/B58/status"
payload_on: "1"
payload_off: "0"
- platform: mqtt
# unique_id: tc91100b24
state_topic: "BSTC91100/B24/status"
command_topic: "BSTC91100/B24/status"
payload_on: "1"
payload_off: "0"
- platform: mqtt
# unique_id: tc91100boff
state_topic: "BSTC91100/BOFF/status"
command_topic: "BSTC91100/BOFF/status"
payload_on: "1"
payload_off: "0"
// B58 gpio 14 - D5
// B24 gpio 12 - D6
// BOFF gpio 13 - D7
On System#Boot do
let,1,0
let,2,0
let,3,0
timerSet,1,3
On Rules#Timer=1 do //When Timer1 expires, do
if %v2%=0 and %v3%=0
pulse,2,1,200 // pulse
let,2,1
timerSet,1,1
let,2,0
timerSet,1,2 //Resets the Timer 1 for another X seconds
on MQTT#Connected do
let,3,0
event,publishstatus
on MQTT#Disconnected do
let,3,1
//by http
On B58 do
pulse,14,1,500
pulse,2,0,500
let,1,1
Publish,%sysname%/B58/status,0
On B24 do
pulse,12,1,500
pulse,2,0,500
let,1,1
Publish,%sysname%/B24/status,0
On BOFF do
pulse,13,1,500
pulse,2,0,500
Publish,%sysname%/BOFF/status,0
let,1,2
//by MQTT
on MQTTIN#BOFF do // cancelled
if %eventvalue%=1
logentry,"mqt boff"
pulse,13,1,500
pulse,2,0,500
let,1,2
on MQTTIN#B58 do // brew 5-8
if %eventvalue%=1
logentry,"mqt b58"
pulse,14,1,500
pulse,2,0,500
let,1,1
on MQTTIN#B24 do // brew 2-4
if %eventvalue%=1
logentry,"mqt b24"
pulse,12,1,500
pulse,2,0,500
let,1,1
on VACC#status do
if %eventvalue%=1
if %v1%=1
Publish,%sysname%/Notify/status,1 // working
else // status = 0
if %v1%=1 // status = 0 var1 =1
let,1,0
Publish,%sysname%/Notify/status,0 // finished
if %v1%=2 // status = 0 var1 =2
let,1,0
Publish,%sysname%/Notify/status,2 // cancelled
- hardware.png (155 KiB) Viewed 9335 times
- devices.png (186.08 KiB) Viewed 9335 times
- mqttimport.png (46.63 KiB) Viewed 9335 times
