Contactless wakeup for LCD
I'm wondering if someone has a better option than a PIR to trigger the display of a LCD after time out.
Objective is to have a 2004 in the bedroom that can be used as a clock with some messages from domoticz. All of that works for now, the LCD goes off and as soon as the PIR detects a movement, the LCD goes on for the programmed time.
I want a contactless option like I have for other clocks where I just sleepily wave my hand somewhere around the clock turns on. PIR is a bit big...
Any ideas guys ?
Any ideas guys ?
Re: Contactless wakeup for LCD
You can add a tip touch pad, which can be mounted inside the enclosure.
But you still need to touch it.
Other way can be one of those "gesture" chips. These are relatively small.
Or you can try experiment with one of those cheap "radar" sensors.
They are quite small (small PCB with low profile components), but they are a bit tricky to operate as they are sensitive in all directions and may be affected by metal close to the sensor.
But they are really cheap
Cheap and tricky ? That'll remind me of my earliest love life. Any link or examples ?
I've written about my PV Monitor project over here in this forum, a couple of months ago.
It is working, sort of, but the APDS9960 gesture sensor (Chinese clone) is not very responsive, most of the time, and it is influenced by the housing I put around it. I actually had to enlarge the hole it is looking out through, just to unblock the ESP, as the I2C bus is blocked if there is too much material close to the sensor.
I have planned to experiment with both a PIR and a TCRT5000 IR sensor, though that last one hasn't arrived yet. But that one is dirty cheap, ~€0,25 each, shipping to my location is about double of that
I'll have to wait and see if that one does what I want it to do.
For which of the two?
As Google search: rcwl-0516 microwave radar sensor
All right I checked comparison youtube videos and ordered some rcwl-0516. They look great. Only 3 months to wait for them to be delivered...
Thanks guys, @Ath keep me posted when your sensor arrives.
Cheers !
Cheers !
Hi guys, thanks for the tip, those guys are awesome. Now, I googled a lot and search this forum but couldn't find a simple example of a capacitor to add for 1 or 2 or 5 minutes delay to C-.
I got the (1/f)*32768 and the But Engineer school was 30 years ago...
Erm, Did someone tried so I don't have to rely on programming for delay ? 100% error time is totally acceptable by the way...
What exactly do you want to achieve?
Is it going to be a RC timer circuit?
Then you must also know what the charging voltage is and what voltage will be enough to be considered "high" or "low" (depending how you connect it)
Hi, thanks for the quick reaction and your advice about those !
I want to control the backlight of LCD or Led matrix to only lit when there's someone to watch.
Project one is a simple 2004 LCD: wave in front of it and backlight on (I know I'd have to limit the range with a resistor but small steps).
Project two is a 32 ou 64X8 Leds matrix to display message.
Both will be powered by 5V.
Best will be for the module to be able to feed the backlight/Matrix (I imagine the 3v to a transistor to feed 5v). But I'm opened to suggestion.
The idea is to be able to have a module that I can put between the MP & the "lights on" wire. 5V-> rcwl-0516 -> 5V if motion for X min, 0V if not.
Cheers!
Cheers!
Why diving into RC networks for timing (which also needs 2 pins, one for the motion detection, one for the timer), while you can do it all in rules?
For example a motion sensor can trigger a signal on a GPIO pin, which triggers an event in the rules.
This event then sets a timer (each time again if it is triggered) and turns on the backlight.
After the timer fires (meaning no motion for set amount of time) you act on it in the rules to turn off the backlight.
That makes it very versatile and easy to tune the time the backlight needs to auto power off.
I guess I can do it this way. It'll require a bit more programming as I need Domoticz to send and on/off signal to the motion detection mechanism. I also want a radio switch to turn on the light and in this case prevent the off when no motion is detected. I'll need to research how to send a variable to the Esp and use it in the rules then.
You can send (a) value(s) to an ESPEasy unit by sending an event or a TaskValueSet command, something in this line:
http://ip.of.esp.unit/control?cmd=event,setvalues=value1,value2
on SetValues do
TaskValueSet,<tasknr>,<varnr1>,%eventvalue1%
TaskValueSet,<tasknr>,<varnr2>,%eventvalue2%
http://ip.of.esp.unit/control?cmd=taskvalueset,tasknr,varnr,value
I have received the sensors, but haven't gotten to connecting them up
Btw, the TCRT5000 looks useless for this purpose, as it has a range of around 10 millimeters, usable for like tracking a (white) trace on the floor or something (haven't properly investigated though).
The PIR sensor acts like a switch, so should be usable for the intended purpose, just need finish some other stuff before I'll pick that up.
Thanks a lot. The TCRT5000 can be use for waving your hand above a clock for example ?
I'm trying something like this :
It works but it is erratic, sometimes the led stays on longer and sometimes the sensor doesn't pick up movement for a while... Dunno why.
Is it because of my device declaration perhaps ?
on wave#State do
if [wave#state]=1
gpio,2,0
timerSet 1,10
on Rules#Timer=1 do
gpio,2,1
You should use another pin since GPIO-16 doesn't support interrupts.
Will do, thanks again !
Mmm not sure , I changed for D5 and it triggers fine but stops after 10 seconds, even if I dance in front of it while active (fully clothed be reassured). Shouldn't it retrigger the counter to 10 every time it detects a movement ?
Also, when I do that, it seems that it won't re-trigger for a certain time, maybe linked to the time I spend waving while its active ?
Is my button declaration correct for this sensor ?
Cheers !
Cheers !
on wave#State do
if [wave#state]=1
gpio,2,0
timerSet 1,10
endif // Missed this one
on Rules#Timer=1 do
gpio,2,1
It happens to me a lot (also in C++), so it is one of those things I check as one of the first things in debugging.
So maybe it should also be done in the rules parsing to help via the logs to indicate mismatch in if/endif etc.
All right, this is what I got so far. Any advice welcome :
So 2 devices, one for the motion sensor and one for a Led or just variable status. Device one, the sensor : Device two, the variable/Led Rules being :
If I send http://172.19.0.232/control?cmd=event,ForceOn the sensor will not enable gpio2 until it received the ForceOff and end of timer.
So that works but I have two questions :
How can I simply force wave#state to 0 or 1 with a simple command to prevent using device linked to a GPIO and/or, how can I read a GPIO value ?
Thanks !
PS: Yes I can also do an event that'll do the reverse and prevent triggering in case of detection but I don't need this feature.
on wave#State do
if [wave#state]=1
gpio,2,0
timerSet 1,10
on Rules#Timer=1 do
if [D6#State]=0
gpio,2,1
On ForceOn do
gpio,12,1
On ForceOff do
gpio,12,0
Thanks !
To get a pin state, see: https://espeasy.readthedocs.io/en/lates ... red-values
[Plugin#GPIO#Pinstate#N]
By searching through that page for "[plugin" you can find more spots where it is explained (but I cannot link to it directly)
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
