I can't understand what happens. when the device, is a Sonoff Dual R2, restarts, relays bounce from on to off repeatedly. Sometimes indefinitely for both relays, other times relay 1 stops in the wrong position, other times relay 2.
The reboot is normal if both controllers are disabled.
https://youtu.be/io2Kx7g-xco
this is my rule
on System#Boot do
GPIO,12,0 // Relay 1 OFF
GPIO,5,0 // Relay 2 OFF
let,1,0 // Set variable 1 to 0
on pulsante#stato do
if [pulsante#stato]=1
let,1,[int#1]+1
if [int#1]=1
gpio,12,1
gpio,5,0
elseif [int#1]=2
gpio,12,0
gpio,5,1
elseif [int#1]=3
gpio,12,1
gpio,5,1
elseif [int#1]=4
let,1,0
gpio,12,0
gpio,5,0
