Hya,
for an application i'm building, i have a push button but want to trigger with long press only, to avoid and triggering by touching by mistake.
Is there a way to "disable" to short press?
Some samples for the following?
Long press event: If enabled the unit will detect a long press of a button. There’s three different behaviors of the long press:
Active only on low: this means that the unit will only be triggering the long press event if the signal is low. Two different event values are used, 10 if the state goes from 0 to 1 (Switch#State=10), and 11 if the state goes from 1 to 0 (Switch#State=11).
Active only on high: same as above but only triggered on high signal.
Active on high & low: the long press will be triggered both on high and low signals.
Thanks in advance!
Plugin 01 (Switch ) Push Button Longpress
Re: Plugin 01 (Switch ) Push Button Longpress
Simply don't assign any action to it.
I say that theorically, longpress or double never worked for me so far.
i was confused, as the docs are mostly not very friendly. Anyway, i spent about one hour testing, digging and found out the it works like a charm....
And doubleclick also works..
on PB#status do
if %eventvalue%=11 // pb#status 11 - long press and v1 = 0 -> turn ON
if %v1%=0
gpio,13,1
let,1,1
else // pb#status 11 - long press and v1 = 1 -> turn off
gpio,13,0
let,1,0
And as i'm a very lazy dog, i memorize almost nothing, i just learn, but don't memorize syntaxes, etc... i do it and save for later reference.
Glad you managed, I'll try again and share my experience with you if you don't mind.
Talk to you soon,
Talk to you soon,
Users browsing this forum: Ahrefs [Bot] and 30 guests
