Solved: Tristate wrong commands and not reacting - Fixed
I have few of these cheap switch that are recognized as Tristate switch. First issue, commands learned are reverted, the ON command is learned as OFF and the opposite for the OFF command. But the main issue is that the learned commands have no effect on the switch, ON or OFF no reaction at all.
Here is the debug output
On Command on remote
20;9B;DEBUG;Pulses=511;Pulses(uSec)=120,450,390,90,60,450,30,450,60,450,390,90,60,450,390,90,30,450,30,450,60,450,390,90,60,450,390,90,60,450,390
,90,60,450,60,450,390,90,390,90,60,450,60,450,390,90,390,120,60,5250,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,120,30,450,60,450,60,45
0,390,90,60,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,60,450,60,450,390,90,390,90,60,5250,30,450,390,90,30,450,60,450,60,450,390,90,60
,450,390,90,30,450,60,420,60,450,390,90,60,450,390,90,30,450,390,90,60,450,60,450,390,90,390,90,30,450,60,450,390,90,390,90,60,5250,60,450,390,90
,60,450,30,450,60,450,390,90,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,390,90,30,450,60,450,390,90,390,90,60,450,60,450,390,
90,390,90,60,5250,60,450,390,120,60,450,60,450,60,450,390,90,60,450,390,90,30,450,60,450,60,450,390,90,60,450,390,90,30,450,390,90,60,450,30,450,
390,90,390,90,60,450,60,450,390,90,390,90,60,5250,60,450,390,90,60,450,30,450,60,450,390,90,30,450,390,90,60,450,60,450,60,450,390,90,60,450,390,
90,60,450,390,90,60,450,60,450,390,90,390,90,60,450,60,450,390,90,390,90,60,5250,60,450,390,90,60,450,30,450,60,450,390,90,60,450,390,90,60,450,6
0,450,60,450,390,90,60,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,30,450,60,450,390,90,390,90,60,5250,30,450,390,90,60,450,30,450,60,45
0,390,90,30,450,390,90,60,450,30,450,60,450,390,90,30,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,60,450,30,450,390,90,390,90,60,5250,60
,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,60,450,
60,450,390,90,390,90,60,5250,60,450,390,90,60,450,60,450,60,450,390,90,30,450,390,90,60,450,30,450,60,450,390,90,30,450,390,90,60,450,390,90,60,4
50,60,450,390,90,390,90,60,450,30,450,390,90,390,90,30,5250,60,450,390,90,60,450,60,450,30,450,390;
20;9C;TriState;ID=88a2a1;SWITCH=2;CMD=OFF;
Off command on remote
20;B1;DEBUG;Pulses=511;Pulses(uSec)=120,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,30,450,60,450,60,450,390,90,60,450,390,90,30,450,390
,90,60,450,30,450,390,90,390,90,390,90,390,90,60,450,60,450,60,5250,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,60,450,60,450,
390,90,60,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,390,90,390,90,60,450,60,450,60,5250,60,450,390,90,60,450,60,450,60,450,390,120,30,
450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,390,90,60,450,30,450,390,90,390,90,390,90,390,90,60,450,60,450,60,5250,30,450,390,90,
60,450,60,450,60,450,390,90,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,390,90,390,90,60,45
0,60,450,60,5250,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,390,90,60,450,60,450,39
0,90,390,90,390,90,390,90,60,450,60,450,60,5250,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,30,450,60,420,390,90,60,450,390,90
,60,450,390,90,60,450,60,450,390,90,390,90,390,90,390,90,60,450,60,450,60,5250,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,60,
450,60,450,390,90,60,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,390,90,390,90,60,450,30,450,60,5250,30,450,390,90,60,450,60,450,60,450,
390,90,60,450,390,90,60,450,30,450,60,450,390,90,30,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,390,90,390,90,60,450,60,450,60,5250,60,4
50,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,390,90,60,450,60,450,390,90,390,90,390,90,39
0,90,60,450,60,450,60,5250,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,60,450,60,450,390,90,60,450,390,90,60,450,390,90,60,450
,60,450,390,90,390,90,390,90,390,90,60,450,60,450,60,5250,60,450,390,90,60,450,60,450,60,450,390;
20;B2;TriState;ID=88a2a1;SWITCH=2;CMD=ON;
I also saw a discussion on domoticz where it seems that this issue has already been fixed few months ago, is it back? I am on R37.
https://www.domoticz.com/forum/viewtopi ... =49&t=8516
Thanks for your help
Re: Tristate wrong commands and not reacting
Any idea of the brand/model of your set?
Yes it's an Etekcity Zap like this one
http://www.amazon.ca/gp/product/B00DQ2K ... ge_o01_s00
I have a similar problem. Sockets respond to commands but the other way around.
Below are video and photos of power sockets.
https://www.youtube.com/watch?v=cnHscWd9lyM
http://imgur.com/a/SxZvO
How can I fix this?
How can I fix this?
I have a problem with a plug 433 with tristate protocol.
RFLINK recognizes commands well, but always send off to sockets, but in the log was sent ON.
Do the socket commands sent by Rflink work? In my case they do not work, socket do not react to commands..
Thank you for the fix,
Everything works flawlessly
Re: Tristate wrong commands and not reacting - Fixed
Thank you for the fix, now tristate works ok.
