send value from one OSP to OLED of another ESP
tparvais
#1 Post by tparvais » 07 Feb 2021, 18:42
I'm trying toi send some values from one ESP mesauring temperature etc... to the oled screen of another ESP
The command http://192.168.0.63/control?cmd=OLEDFRAMEDCMD,1,'Hello World'
is working well
now, I want to update temperature from another ESP
I create the following rule
on Temperature#Temperature do
SendToHTTP,192.168.0.63,80,/control?cmd=OLEDFRAMEDCMD,2,Sauna=[Temperature#Temperature]
I suppose that for any change of Temperature, the SentToHTTP will be called to send the temperature. but nothing happen
I tried by using a dummy variable in ESP_OLED and TaskValueSet command
SendTo,13,'TaskValueSet,10,1,Sauna=[Temperature#Temperature]'
My problem is to add a measurement in the command to send
Thomas
Re: send value from one OSP to OLED of another ESP
#2 Post by Ath » 07 Feb 2021, 19:08
You need to quote arguments containing commas or spaces paased to SendToHTTP or SendTo, as it sees those as separators, and won't glue them together itself. Quotes can be ", " or `, just use one pair that is not used in the list of arguments you're quoting.
#3 Post by TD-er » 07 Feb 2021, 20:45
Yep.
SendToHTTP,192.168.0.63,80,"/control?cmd=OLEDFRAMEDCMD,2,Sauna=[Temperature#Temperature]"
See also: https://github.com/letscontrolit/ESPEasy/issues/2724
namxcap
#4 Post by namxcap » 07 May 2021, 00:14
Hello, can someone help me ?
i have this rule, but it doesn't work... where 'fumo' is the device's name.
On [fumo]#State do
If [fumo]#State=0
SendToHTTP,192.168.1.129,80,"/control?cmd=NEXTION,sleep=1"
Else
SendToHTTP,192.168.1.129,80,"/control?cmd=NEXTION,sleep=0"
Endif
Thankyou for your help
namxcap
#5 Post by TD-er » 07 May 2021, 00:36
namxcap wrote: 07 May 2021, 00:14 Hello, can someone help me ?
On [fumo]#State do
If [fumo]#State=0
Else
Endif
namxcap
The syntax should be [taskname#varname], not [taskname]#varname
namxcap
#6 Post by namxcap » 07 May 2021, 07:57
I don't know why but it's no working ...... :shock:
#7 Post by Ath » 07 May 2021, 08:44
namxcap wrote: 07 May 2021, 00:14 i have this rule, but it doesn't work... where 'fumo' is the device's name.
This is the correct syntax:
On fumo#State do
 If [fumo#State]=0
 Else
 Endif
- the line "on fumo#state do" should not have [] included, here it is the event-name to be handled, not a value
- the line "if [fumo#state]=0" should have [] included, now it is the value that needs to be checked; when having these [] it is replaced by the value (if that taskname/value is available)
namxcap
#8 Post by namxcap » 07 May 2021, 17:38
YES !!! Now it works .... i learned one more thing !!!
Thankyou very much
Users browsing this forum: No registered users and 127 guests
