my ESP is rebooting roughly once a day with the below error:
Reset Reason: Hardware Watchdog
Last Action before Reboot: Const Interval: TIMER_100MSEC
I write this here in the Software Topic because i have my own Plugin Build in.
Plugin is build with ESPSerial and provides a SoftwareSerial because i read in two smart meters and needed a second serial server.
The Plugin uses the PLUGIN_TEN_PER_SECOND.
I think the error has to do with that?
Is there a better way to do the loop?
My Plugin Code can be found here:
https://github.com/StefanRu1/SoftwareSe ... _SSSRV.ino
P.S.: The ESPSerial is workig fine but i also get messages like "Ser2N: serial buffer full!" in the log. Any Idea what might cause this? Would be perfect if there is an alternative to PLUGIN_TEN_PER_SECOND.
P.P.S: Here my Firmware Information:
Firmware
Build:⋄ 20111 - Mega
System Libraries:⋄ ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Git Build:⋄
Plugin Count:⋄ 47 [Normal]
Build Origin: Self built
Build Time:⋄ Dec 12 2020 11:48:29
Binary Filename:⋄ ESP_Easy_mega_20201212_normal_ESP8266_4M1M
Build Platform:⋄ Windows-10-10.0.18362-SP0
Git HEAD:⋄ pygit2_not_installed
Stefan
