SendTo ESP32
rol-rider
SendTo ESP32
#1 Post by rol-rider » 15 Feb 2021, 13:24
Hello, I am always impressed by the evolutions of ESPEAsy, I am currently testing an ESP32 (Devices Touch)
I will want to use the sendTo command. does sendTo command work on ESP32?
here are my logs
EVENT: touch#Touch=67
853878: ACT : sendTo 31,event,lampecouloir
853880: Command unknown: sendTo 31,event,lampecouloir
otherwise,
I don't see a lot of DIY project.
one of my DIY projects with ESPEasy.
8 relay and DS18b20 and 8 input (opto) card (esp32 or wemos)
sorry for my English ! i use google translat.
Re: SendTo ESP32
#2 Post by Ath » 15 Feb 2021, 14:50
rol-rider wrote: 15 Feb 2021, 13:24
That SendTo command should be like: (close but no sigar :))
sendTo 31,event=lampecouloir
rol-rider
Re: SendTo ESP32
#3 Post by rol-rider » 15 Feb 2021, 18:50
On BP#BP=1 do
this command works on an S26 socket (esp8266)
but not on ESP32 ?
rol-rider
Re: SendTo ESP32
#4 Post by rol-rider » 15 Feb 2021, 19:01
with sendTo 31, event=lampecouloir
I have no error but it does not work!
638219: EVENT: bp#bp=1
638223: ACT : sendTo 31,event=lampecouloir
648999: EVENT: bp#bp=0
649003: ACT : sendTo 31,event=lampecouloir
Re: SendTo ESP32
#5 Post by Ath » 15 Feb 2021, 19:21
rol-rider wrote: 15 Feb 2021, 18:50
On BP#BP=1 do
but not on ESP32 ?
It can depend on the version of ESPEasy, if that on your Sonoff S26 is dated before November 2019, the argument handling is revamped since then, so the older version will accept/pass on the extra command arguments but the newer version won't. (ESP32 has only been usable/stable since about a year.)
I made a slight mistake in my previous answer, your comma after 'event' is correct but the 2nd argument for 'sendto' needs quotes:
On BP#BP=1 do
sendTo 31,"event,lampecouloir"
The SendTo command takes 2 arguments, 1) a unit number and 2) the command to send. If that command involves comma's or spaces, it must be enclosed in quotes (either " ' or ` can be used, double-, single- or back-quotes)
rol-rider
Re: SendTo ESP32
#6 Post by rol-rider » 15 Feb 2021, 23:14
On BP#BP=1 do
yes, it works thank you ;)
Re: SendTo ESP32
#7 Post by TD-er » 04 Jul 2023, 13:04
drewbinsky wrote: 04 Jul 2023, 11:52
rol-rider wrote: 15 Feb 2021, 23:14
On BP#BP=1 do
The sendTo command is not a built-in command in ESPEasy
Do you have C013 (ESPEasy p2p) controller included in your build?
And do you have one such controller enabled in ESPEasy?
Users browsing this forum: No registered users and 33 guests
