ESP32 Servo + touch
ESP32 Servo + touch
hi,
i need a build with "touch" and "servo" functionality.
i tried custom and test where "touch" works,and normal where "servo" works.
i thought test and custom include everything that normal does.
is there a build where touch and servo on the ESP32 do work?
Re: ESP32 Servo + touch
Currently there isn't. In the limit_build_size builds, like normal and testing, the servo functionality is disabled.
There are 2 solutions: Build your own by using a Custom.h file, or persuade someone to make a customized build for you.
tnx,
i´ll try to build one.
whats the "limit_build_size builds"?
looks like in my "normal" the servo is enabled.
i used "ESP_Easy_mega_20210223_test_ESP32_4M316k.bin"
whats the difference to the ETH version?
To reduce the flash used, some functions are not included in the code during compilation. The #define introduced for that is LIMIT_BUILD_SIZE (I typed it in lowercase as I was using a tablet for that reply). It is applicable for most MINIMAL builds, the TESTING builds and all 1MB and VCC builds.
Ah, correct, the normal builds don't have that #define set.
The ETH builds are for ESP32 boards with (wired) Ethernet controllers (with a limited set of supported controllers, and some pre-configured GPIO settings to support that). If you have to ask, you don't use that type of ESP
An easy way to achieve that is to add #define USES_P097 to the PLUGIN_SET_STABLE section in define_plugin_sets.h file and build the env:normal_ESP32_4M316k configuration (not available in the nightly builds AFAICS)
tnx,
seems to work - even if i dont know what i´m doing^^
is "open the file “pre_extra_script.py” and add or remove the plugins and controllers you need. "
obsolete? i couldnt find that file.
I think that a bit old, as I do see pre_custom_esp32.py and pre_custom_esp82xx.py but probably the doc's weren't updated when the file was split for ESP32 and ESP82xx definitions.
There you would have to add (including the quotes and the comma, really close to any of the other -D lines) on a separate line and build the env:custom_ESP32_4M316k configuration.
Edit: Be sure to remove/rename your Custom.h file (if any), as that will take preference over the settings in this script.
"-DUSE_SERVO",
Those pre_....py files have moved a while ago to tools/PIO folder
Maybe some documentation is outdated ?
Users browsing this forum: Google [Bot] and 32 guests
