Setting a dummy device value in rule
I'm sure this one is an easy one and I'm just not searching the forum and docs correctly. I need to store a value that can be queried later on from a REST call (like sensorupdate). My idea is to simply store what I need in a dummy device. I cannot find the proper call to set the value of this device in a rule. The dummy device is looking to store a 0 or 1. So basically, when one event fires store a 0 in dummy device and when another event fires store a 1 in dummy device. I'm sure this is easy but I just can't seem to find the call. Thank you
Re: Setting a dummy device value in rule
You can give the event command via HTTP and include a number of eventvalues.
For example the command:
If you enter it from the command field on the Tools page, you'll see the encoded URL:
The "eventname" is a name you can pick yourself and act on it in the rules:
Just be aware that %eventvalue3% for example will not be replaced by its value if less than 3 eventvalues are given. (same for %eventvalue2% etc)
See also https://espeasy.readthedocs.io/en/lates ... skvalueset
Event,eventname=1,2,3,4
http://192.168.10.151/tools?cmd=Event%2Ceventname%3D1%2C2%2C3%2C4
on eventname do
taskvalueset,1,1,%eventvalue1%
taskvalueset,1,2,%eventvalue2%
taskvalueset,1,3,%eventvalue3%
taskvalueset,1,4,%eventvalue4%
Excellent, I'll give this a try. So when setting the value of the device I don't call it like this....
[DummyDevice#value] = someValue
I need to reference the device via the task number and the number of the specific item I want to set within that task. Is this correct? I'm pretty sure that is what you meant by the below but wanted to confirm.
Thank you again!
Thank you again!
Yep, dummy task values must be set using taskvalueset command.
You can "read" them via [taskvaluename#variablename] syntax.
Perfect! Thank you very much!
I just wanted to post my final results just incase someone reads this thread and has the same reqs.
So now I can pass in the blow url to open the vent
http://192.168.86.52/control?cmd=event,controlVent=1
and to close the vent
http://192.168.86.52/control?cmd=event,controlVent=0
and I can get the status of the vent with
http://192.168.86.52/json?view=sensorupdate
I check the value being sent in from the URL. Based on that value I open or close the vent as well as set a dummy device which I can query later. This dummy device acts as a method of allowing me to run a REST call into the ESPEasy and get the vent's status.
Thank you again TD-er for all the help!
on controlVent do
if %eventvalue1%=1
LogEntry, 'Vent Open'
servo,1,14,90
taskvalueset,2,1,%eventvalue1%
LogEntry, 'Vent Closed'
servo,1,14,0
Users browsing this forum: Ahrefs [Bot] and 16 guests
