Rules with sunset sunrise
edstobi
#1 Post by edstobi » 16 Mar 2021, 21:21
HI
I am using ESP8266 with 20112 - Mega.
I do have a relay for output and a switch for input.
I can activate the relay with the Switch on Rules 1.
The switch is for a lamp "on" or "auto" mode.
on System#Boot do
  gpio,4,0
  timerSet,1,10
on Switch#Switch=1 do
  if [Relay#Relay]=1
    gpio,4,0
    gpio,4,1
on Switch#Switch=0 do
  if [Relay#Relay]=0
    gpio,4,1
    gpio,4,0
on Rules 2 I want to do the auto mode:
on Clock#Time=%sunrise% do    //  sunrise.
 event,Off                    // turn off relay
on Clock#Time=%sunset% do    //  sunset...
 event,On                     // turn on relay
on Clock#Time=All,01:00 do    //  01:00 Uhr aus
on Clock#Time=All,05:00 do    //  05:00 Uhr aus
on On do
  gpio,4,1
on Off do
  gpio,4,0
I shooed hear at last a click from the relay or see it in the lock a action of the espeasy.
But ther is no reaction.
where do I do the error of this thinking?
THX
Re: Rules with sunset sunrise
#2 Post by TD-er » 16 Mar 2021, 22:44
The first rules can be simplified as the do the same.
  if [Relay#Relay]=1
    gpio,4,0
    gpio,4,1
  if [Relay#Relay]=0
    gpio,4,1
    gpio,4,0
Apart from the eventvalue both blocks do the same, so you can simplify it to:
on Switch#Switch do
  if [Relay#Relay]=1
    gpio,4,0
    gpio,4,1
And it can be even shorter, as can be seen in the documentation: https://espeasy.readthedocs.io/en/lates ... red-values
on Switch#Switch do
  gpio,4,![Relay#Relay]
... unless it was not intended this was the same in both cases.
edstobi
#3 Post by edstobi » 17 Mar 2021, 12:09
WAU
that is a nice compact way!
May I ask for this code part.
on On do
gpio,4,1
on Off do
gpio,4,0
That is on retaking, the fix time is switching but sunset and sunrise do not trigger the expected result
THX
edstobi
#4 Post by TD-er » 17 Mar 2021, 12:20
Not 100% sure if the parser may accept "On" as an event or misinterprets it as the start of a block.
It should work, but when in doubt you may want to change that name to test if things start working then.
About the clocktime matching, see the example here:
https://espeasy.readthedocs.io/en/lates ... ore-events
on Clock#Time=All,12:00 do //will run once a day at noon
 GPIO,2,1
on Clock#Time=All,**:30 do //will run half past every hour
 GPIO,2,1
on Clock#Time=All,%sunrise% do //will run at sunrise  (%sunset% is also available)
 GPIO,2,1
As you can see, the clock#time event does need to have a specific format, starting with the days of the week and then the time, separated with a comma.
And as extra information about calling the event.
When calling an event like this, it is called immediately, thus calling a new rule parsing instance on top of the current one.
For small event blocks like this that's not a big deal, but for a number of nested events you may run out of resources.
So whenever possible, try to use "asyncevent" instead of "event".
It will append the new event to a queue which is processed later.
edstobi
#5 Post by edstobi » 17 Mar 2021, 22:21
THX to all
The problem is solved.
it was the missing "ALL" for sunrise and sunset
Metatron
#6 Post by Metatron » 20 Mar 2021, 09:42
so far, well understood, thank you.
But what do I do, if I want something to happen, half an hour before sunrise?
Any hint, for a newbie, please?
Propably the easiest way is, to move my coordinates further to the east, right?
Regards, Metatron
#7 Post by Ath » 20 Mar 2021, 10:04
Metatron wrote: 20 Mar 2021, 09:42 But what do I do, if I want something to happen, half an hour before sunrise?
The variables for sunrise and sunset support adding or subtracting minutes or hours, the syntax is like %sunrise-30m% and %sunset+2h% etc. This is only supported for these 2 variables.
Metatron
#8 Post by Metatron » 20 Mar 2021, 10:10
Wow, cool, thanks!
#9 Post by TD-er » 20 Mar 2021, 13:29
See also the system variables page on your ESPEasy node (only present on 'normal' or 'custom' builds) for more ideas.
They are also described here: https://espeasy.readthedocs.io/en/lates ... -variables
Users browsing this forum: Ahrefs [Bot] and 12 guests
