What do i wrong?
This rule is working:
On PIR#Motion do // Motion detected:
if %systime% > 18:48 // After 18:48 Sunset
gpio,12,1 // Lamp on
timerSet 1,60 // start timer
if %systime% < 6:30 // Before 6:30 Sunrise
timerSet 1,60 // start timer//
endOn
On Rules#Timer=1 do
gpio,12,0 // Lamp off
endOn
This is not working:
if %systime% > %Sunset% // After 18:48 Sunset
if %systime% < %Sunrise% // Before 6:30 Sunrise
endOn
On Rules#Timer=1 do
endOn
What do i wrong with this rule
Re: What do i wrong with this rule
You could have placed this in the ESPEasy part of the forum
ESPEasy currently has a limitation that while parsing the IF line, it will only replace 1 % variable at a time, so the %sunrise%/%sunset% values are not inserted where you would expect them.
I made a new request in the correct forum.
