I've spent a couple of hours on this, now...
(Win10)
I have a chinese eBay "nodeMCU" clone board: ESP8266, WIFI, .91" OLED built in.
I can upload the ssd1306 example sketch using arduino IDE - and it works fine (after changing the reset pin to -1)
I can "tasmotize" the board.
If I use "ESP.Easy.Flasher.exe", it will not find the USB port.
as I say the port is found and is used by tamsmotize and arduino IDE to upload to the board - It will find another ESP8266 connected using same (physical) port + same cable.
I have tried manually changing the port number of the USB port via devmanager - and all the front USB ports (I cant get to the rear without stripping out my desk)
FlashESP8266.eze DOES find the port but the upload fails on something else (I'm running it from within the "BIN" directory):
************** Exception Text **************
System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at FlashESP8266.Form1.bttn_flash_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
FlashESP8266
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///E:/esp/ESPEasy_ESP82xx_mega-20210223/bin/FlashESP8266.exe
Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Easy flasher not finding USB COM port
Re: Easy flasher not finding USB COM port
This is a known issue of the ESPEasy flasher as some 'funky' USB to serial chips do seem to register themselves in some strange places in the Windows registry, in places where ESPEasy flasher is not looking.
You can still use the included Espressif flasher. See: https://espeasy.readthedocs.io/en/lates ... g-software
Thanks for that!
I don't know why, but I thought that the espressif one was just for the ESP32
Too late tonight, but I'll give it a try in the morning.
Thanks again1
Thanks again1
Now working...
Bedside clock/calendar/temp gauge.
Reading time from pool.ntp.org, and temp/humidity via MQTT and wifi from an ESP32 in the garden.
Is there any way to stop the display powering down?
Or a quick pointer on how to power it back up - without having to reset?
