EspEasy IR - hold button code
There is a TV and an audio receiver, I need to adjust the volume of the receiver with the TV remote control. I am using esp easy IR, but how do I track and broadcast the code for the volume button being held down? One press of the button - I get the code, but if you hold the button - first comes the button code, then endlessly the repeat code. I want to receive the code of the pressed button and transmit the volume up code as well.
Re: EspEasy IR - hold button code
Up.
still waiting for an answer. IR TRANSMIT module
I would also be interested in an answer to this.
The Switch/Button plugin (included in the base ESPEasy code), currently doesn't have a repeat feature. And that's required to be able to use this kind of behavior.
It seems quite complex to implement, on first glance, so that's probably the reason it hasn't been added yet.
Users browsing this forum: No registered users and 37 guests
