Lolin Motor 2.0 + D1 mini
Clem2105
#1 Post by Clem2105 » 21 Apr 2021, 10:33
Hello everybody!
I bought a Wemos D1 mini and a Motor Shield V2.0.0 (Lolin)
Aliexpress link: https://nl.aliexpress.com/item/32700182142.html
I flashed the Wemos with EspEasy, but in my I2C search I can't find any devices.
When I add a devices with the base address 0x30 nothing works.
With you ever had the problem?
And do you have a solution to solve the problem?
My shield is placed directly on the Wemos (Welded).
Thank you!
Re: Lolin Motor 2.0 + D1 mini
#2 Post by Ath » 21 Apr 2021, 10:53
A few questions:
- What .bin file did you install?
- What does the I2C scan say, a list with just an address, without a description, or that no I2C devices are found?
- Did you leave the I2C configuration on its default settings?
- Did you do the soldering yourself? Are all pins properly soldered, & checked with a multimeter?
Clem2105
#3 Post by Clem2105 » 21 Apr 2021, 11:30
I used this file: ESP_Easy_mega_20210223_normal_ESP8266_4M1M.bin
No I2C device is found
Yes I left everything by default
Yes the welds are ok, I tested the GND, 3.3V, 5V and it's ok. For SDA AND SCL how to check them with a multimeter?
#4 Post by Ath » 21 Apr 2021, 11:37
Clem2105 wrote: 21 Apr 2021, 11:30 - Did you do the soldering yourself? Are all pins properly soldered, & checked with a multimeter?
You could check if the GPIO pins involved are actually connected from 1 board to the other. Best to do that would be when the unit is not powered, and use the connection-test or ohms measurement of the meter (the low voltage used there is IMHO harmless).
#5 Post by TD-er » 21 Apr 2021, 15:13
Maybe also add either another I2C board to it to see if that one can be found and those boards often have internal pull-up resistors present.
If you have them laying around, try adding 2 resistors of 10k between:
- 3v3 and SDA
- 3v3 and SCL
Value is not that critical. Somewhere between 3k3 and 12k would work I guess.
Also double check to see which pins are set to be used for I2C in the ESPEasy configuration (Hardware tab in web config page of the ESP)
Clem2105
Re : Moteur Lolin 2.0 + D1 mini
#6 Post by Clem2105 » 21 Apr 2021, 18:45
Thanks for your quick responses,
I checked all my welds and redone them, I had a fault in the connectors, there was a bad contact.
I think it's ok, I'm doing tests with an engine I'll keep you informed!
Thank you so much!
Users browsing this forum: No registered users and 28 guests
