Hi all,
I'm new to ESPEasy and read the whole documentation but didn't see anything about IR receivers, learning codes and retransmitting.
Is there a plugin for this?
What I would like to do is press a button (Gpio) to put the device in "learn mode", store the code (button pressed on the remote within X seconds) in fixed variable which I can call to transmit it with an action, for example.
Could anyone point me to the right direction?
IR receiver learn, store and retransmit
Re: IR receiver learn, store and retransmit
Sorry, I have no experience with the IR plugins, so actually no idea how to "learn" and replay a code and also no idea whether you may need a special build if the IR coding used may be a specific one that must be enabled at build to be decoded.
Users browsing this forum: Semrush [Bot] and 25 guests
