MQTT: transmit several sensor values
jbaben
#1 Post by jbaben » 09 May 2021, 15:45
how can I transfer multiple sensor values (Temperature1, Temperatur2, Humidity, Pressure) ?
For one sensor value:
MQTT:
Controller Subscribe: %sysname%/#
Controller Publish: %sysname%/Temperature1
Kind Regards
Juergen B.
Re: MQTT: transmit several sensor values
#2 Post by Ath » 09 May 2021, 17:12
I would expect that the MQTT server can only receive 1 value per topic, unless you use the publish command to send a combined message, instead of the more regular way of letting a controller handle it. Via the controller all values of the sensor will be sent to their respective topic one after the other.
#3 Post by TD-er » 09 May 2021, 21:04
The default topic for OpenHAB to publish is like this:
%sysname%/%tskname%/%valname%
I guess that's what you need?
jbaben
#4 Post by jbaben » 10 May 2021, 15:05
Many thanks for your help.
With the topic publish:
all sensor values are transmitted.
Kind Regards
Juergen B.
Users browsing this forum: No registered users and 31 guests
