Latest versions crashes my NodeMCU
Tebogo
#1 Post by Tebogo » 26 May 2021, 15:05
I use already for a long time a NodeMCU with version mega-20181231 (flashed with ESPEasy_mega_20181231_normal_ESP8266_4096.bin)
I tried to update to the latest version, but when I reboot, after a few minutes (less than 5) the NodeMCU becomes inaccessible, and stops working.
Probably latest version is not supported for my NodeMCU? So how do I find the latest supported version with trying all version between 2018 and today.
I just managed to get the systeminfo, this is as follows:
Unit Number: 0
Local Time: 2021-05-26 15:04:06
Uptime: 0 days 0 hours 1 minutes
Load: 29.32% (LC=1853)
CPU Eco Mode: false
Boot: Cold boot (0)
Reset Reason: External System
Last Action before Reboot: Background Task
SW WD count: 0
Memory
Free RAM: 7536 (5968 - sendContentBlocking)
Heap Max Free Block: 6520
Heap Fragmentation: 14%
Free Stack: 3664 (1088 - sendContentBlocking)
Network
IP Config: DHCP
IP / Subnet: 10.187.1.122 / 255.255.255.0
Gateway: 10.187.1.254
Client IP: 10.187.1.214
DNS: 10.187.1.111 / (IP unset)
Allowed IP Range: 10.187.1.0 - 10.187.1.255
Connected: 38 s
Number Reconnects: 0
WiFi ❔
Wifi Connection: 802.11n (RSSI -54 dBm)
SSID: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C)
Channel: 10
Encryption Type: WPA2/PSK
Last Disconnect Reason: (1) Unspecified
Configured SSID1: Linksys Velop WHW03 V2
Configured SSID2:
STA MAC: 60:01:94:5D:38:EA
AP MAC: 62:01:94:5D:38:EA
WiFi Settings
Force WiFi B/G: false
Restart WiFi Lost Conn: false
Force WiFi No Sleep: false
Periodical send Gratuitous ARP: true
Connection Failure Threshold: 0
Max WiFi TX Power: 17.50
Current WiFi TX Power: 5.00
WiFi Sensitivity Margin: 3
Send With Max TX Power: false
Extra WiFi scan loops: 0
Periodical Scan WiFi: true
Firmware
Build:⋄ 20113 - Mega
System Libraries:⋄ ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Git Build:⋄ mega-20210503
Plugin Count:⋄ 47 [Normal]
Build Origin: Travis
Build Time:⋄ May 3 2021 09:23:52
Binary Filename:⋄ ESP_Easy_mega_20210503_normal_ESP8266_4M1M
Build Platform:⋄ Linux-5.4.0-1046-azure-x86_64-with-glibc2.2.5
Git HEAD:⋄ HEAD_aacae49
System Status
Syslog Log Level: None
Serial Log Level: Info
Web Log Level: None
Network Services
Network Connected: ✔
NTP Initialized: ✔
MQTT Client Connected: ✔
ESP Board
ESP Chip ID: 6109418 (0x5D38EA)
ESP Chip Frequency: 80 MHz
ESP Chip Model: ESP8266
ESP Chip Cores: 1
ESP Board Name: PLATFORMIO_ESP12E
Storage
Flash Chip ID: Vendor: 0xC8 Device: 0x4016
Flash Chip Real Size: 4096 kB
Flash IDE Size: 4096 kB
Flash IDE Speed: 40 MHz
Flash IDE Mode: DIO
Flash Writes: 0 daily / 0 boot
Sketch Size: 940 kB (2128 kB free)
Max. OTA Sketch Size: 1019 kB (1044464 bytes)
OTA possible: true
OTA 2-step Needed: false
SPIFFS Size: 934 kB (844 kB free)
Page size: 256
Block size: 8192
Number of blocks: 116
Maximum open files: 5
Maximum path length: 32
Can someone give me a hint? Thank you!
grt. Pieter
Re: Latest versions chashes my NodeMCU
#2 Post by TD-er » 26 May 2021, 15:33
This is a known issue, related to incorrect handling of WiFi events.
Please use the version from Frebruary.
Tebogo
Re: Latest versions crashes my NodeMCU
#3 Post by Tebogo » 26 May 2021, 16:33
Thank you for your quick response! You mean this February? I'll try that one ;)
Update:
I Installed mega-20210223, First I flashed with blank_4MB.bin, than ESP_Easy_mega_20210223_normal_ESP8266_4M1M.bin.
After restart, it took a long time before I could connect to ESP_Easy AP.
Then selected my network, entered my wifi-password.
The NodeMCU never comeback ;-(
Than tried ESP_Easy_mega_20210223_normal_alt_wifi_ESP8266_4M1M.bin
After restart, it took a long time again before I could connect to ESP_Easy AP.
The NodeMCU took a long time, but finally accessible.
Now start config. As soon as I clicked on Tools, the NodeMCU crashed again....
Working down in versions, now ended in ESP_Easy_mega_20210114_normal_ESP8266_4M1M.bin.
The ESP-Easy AP asks me for a password. Which password, not that of my Wifi. Update: password is configesp :)
Working down to the next version..
Tried from browsers Edge, FireFox & Safari.
So any help would be appreciated!
Thanks...
#4 Post by TD-er » 26 May 2021, 17:29
Maybe the power supply isn't stable? (or the USB cable is too thin)
One of the things changed in the last few builds was to make the WiFi use less power, depending on the received signal quality.
Not 100% sure, but I guess this was added around November 2020 or December.
So you could also try latest builds from 2020, to use the "old" behavior of WiFi.
The instability you noticed in the May build, is not present in older builds, so the builds you tried should work just fine... except when the node tries to send using too low TX power.
So this can be tested in those older builds, before I made the TX power dynamic. Sadly in some circumstances the AP does appear way stronger than the ESP's signal is seen by the AP and then the default settings may not be sufficient.
Tebogo
#5 Post by Tebogo » 26 May 2021, 18:28
TD-er wrote: 26 May 2021, 17:29 Maybe the power supply isn't stable? (or the USB cable is too thin)
I use the same power supply and cable which was stable for years with the old version of ESPEasy (never change a working system :D :D )
TD-er wrote: 26 May 2021, 17:29 One of the things changed in the last few builds was to make the WiFi use less power, depending on the received signal quality.
Tried version ESP_Easy_mega_20201227_normal_ESP8266_4M1M.bin, but after reflash and reboot, no connection :|
I'll go further down.... every time, blank flash and ESPEasy flash, till it works...
Update:
ESP_Easy_mega_20201227_normal_ESP8266_4M1M.bin after ESPEasy AP connection, configuration, reboot, no connection...
ESP_Easy_mega_20201130_normal_ESP8266_4M1M.bin after ESPEasy AP connection, configuration, reboot, no connection...
ESP_Easy_mega_20201125_normal_ESP8266_4M1M.bin after ESPEasy AP connection, configuration, reboot, no connection...
ESP_Easy_mega_20201102_normal_ESP8266_4M1M.bin after ESPEasy AP connection, configuration, reboot, no connection...
I try old version again to verify the NodeMCU is still working..
Tried ESP_Easy_mega_20200516_normal_ESP8266_4M1M.bin (latest version ESPEasy_mega-20200515) which have "ESPEasy_mega- without ESP82XX" in the Zip-filename.
ESP_Easy asks for a Wifi-password.... Update password is configesp :)
ESP_Easy_mega-20190607_normal_ESP8266_4M.bin gives ESP_Easy_0 AP, and again asks for a password...
So back on ESP_Easy_mega-20181231_normal_ESP8266_4096.bin, asks for password, which is configesp ;)
Update: all the versions which ask for a password, which is configesp, I manage to reach the AP config page. After selecting my wifi network and entering my password, is doesn't connect, or it seems to connect, but after a few minutes it comes back with "Back to setup". Or I can select the ESP_Easy_AP again.
Even in the old 2018 firmware...
What to do?
Tebogo
#6 Post by Tebogo » 02 Jun 2021, 11:57
Hello TD-er,
I tried all different build, but every time the same problem. After flashing it comes up with ESP_Easy AP. When I configure the wifi it reboots, and never comes back..
I looked in the serial, and found this. Does that help?
INIT : Booting version:  (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
75 : Info   : INIT : Free RAM:33264
76 : Info   : INIT : Warm boot #5 Last Action before Reboot: Background Task Last systime: 7440 - Restart Reason: External System
78 : Info   : FS   : Mounting…
102 : Info   : FS   : Mount successful, used 71284 bytes of 957314
127 : Info   : CRC  : SecuritySettings CRC   …OK
237 : Info   : INIT : Free RAM:29880
239 : Info   : INIT : I2C
239 : Info   : INIT : SPI not enabled
268 : Info   : INFO : Plugins: 20  (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
373 : Info   : WIFI : Set WiFi to STA
476 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 attempt #1
479 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
483 : Info   : Webserver: start
483 : Info   : WIFI : Starting mDNS…
484 : Info   : WIFI : mDNS failed
486 : Info   : Time set to 7440.000 Time adjusted by 7439515.00 msec. Wander: 2066.53 msec/second
487 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
490 : Info   : Local time: 1970-01-01 02:04:00
1893 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 22584 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
3014 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 3 Duration: 2529 ms
3015 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
4842 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1833 ms
4843 : Info   : WIFI  : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
4844 : Info   : firstLoopConnectionsEstablished
13098 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9989 ms
13098 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
13685 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 3 Duration: 13205 ms
13686 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
13997 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 attempt #2
14000 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
15378 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 15375 ms
15379 : Info   : WIFI  : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: DISCONNECTED
15383 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 3
15383 : Info   : WIFI  : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
23954 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9855 ms
23955 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
25164 : Info   : WIFI  : Start network scan
25226 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 attempt #3
25230 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
25331 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 11 s
25332 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
25344 : Info   : WIFI  : Scan finished, found: 2
25345 : Info   : WIFI  : Selected: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:3 (-72dBm) WPA2/PSK
25520 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 3 Duration: 291 ms
25521 : Info   : WIFI  : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
25580 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 58 ms
25581 : Info   : WIFI  : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
31825 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 21264 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
61825 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 20760 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
91825 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 20760 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
What is going wrong, and what can I do?
Thanks, Pieter
#7 Post by TD-er » 02 Jun 2021, 16:28
I can make a new test build (or Ath must beat me to it) later this evening based on the latest sources.
In there I fixed a reconnect issue.
But this may also be something related to not really saving the settings.
Can you (while connected to serial as you did now to get the logs) and type these commands with your credentials replaced:
wifissid,yourWiFiSSID
wifikey,YourWiFiPass
save
You cannot make any typo (or correct it), so better copy/paste the commands from a notepad.
Tebogo
#8 Post by Tebogo » 02 Jun 2021, 19:36
I tried to enter the code as you asked, but no result. (See below, I ***** my password)
INIT : Booting version: mega-20210503 (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
68 : Info   : INIT : Free RAM:33928
69 : Info   : INIT : Warm boot #5 Last Action before Reboot: Background Task Last systime: 3020931596 - Restart Reason: External System
71 : Info   : FS   : Mounting…
93 : Info   : FS   : Mount successful, used 75802 bytes of 957314
111 : Info   : CRC  : SecuritySettings CRC   …OK
114 : Info   : WiFi : Start network scan all channels
217 : Info   : INIT : Free RAM:29144
218 : Info   : INIT : I2C
219 : Info   : INIT : SPI not enabled
301 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
305 : Info   : Webserver: start
306 : Info   : Time set to 3020931596.000
307 : Info   : Current Time Zone: STD time start: 2065-10-25 03:00:00 offset: 0 min
310 : Info   : Local time: 2065-09-23 11:39:56
1648 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 21832 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1649 : Info   : WiFi : Start network scan all channels
2349 : Info   : WiFi : Scan finished, found: 10
2352 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-65dBm) WPA2/PSK
2354 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (RTC) WPA2/PSK attempt #0
2356 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
4530 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 2171 ms
4531 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
4779 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 246 ms
4781 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
4781 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
4784 : Info   : firstLoopConnectionsEstablished
wifissid,Linksys Velop WHW03 V213261 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8634 ms
13262 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
13432 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 11069 ms
13433 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
14161 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-71dBm) WPA2/PSK attempt #1
14164 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
15125 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 19 ms
15226 : Info   : WIFI : Set WiFi to OFF
15539 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 963 ms
15841 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1378 ms
16144 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1680 ms
16446 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1982 ms
16748 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2284 ms
17050 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2586 ms
17352 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2888 ms
17654 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3190 ms
17956 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3492 ms
18258 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3794 ms
18560 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4096 ms
18862 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4398 ms
19164 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4701 ms
19466 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5003 ms
19467 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19477 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19488 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19499 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19509 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19520 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19531 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19541 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19552 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19563 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19573 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19584 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19594 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19605 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19616 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
20165 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-77dBm) WPA2/PSK attempt #2
20268 : Info   : WIFI : Set WiFi to STA
20426 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
21411 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 1241 ms
21411 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
23416 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2006 ms
23418 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
23418 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
31645 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19976 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
32093 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
32094 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
32224 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 12056 ms
32225 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
32993 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:10 (-80dBm) WPA2/PSK attempt #3
32997 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
35567 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2472 ms
35670 : Info   : WIFI : Set WiFi to OFF
35983 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2575 ms
36285 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2990 ms
36587 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3292 ms
36889 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3594 ms
37191 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3896 ms
37494 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4198 ms
37796 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4500 ms
38098 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4802 ms
38400 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5104 ms
38400 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
38411 : Info   : WiFi : Start network scan all channels
40593 : Info   : WiFi : Scan finished, found: 12
40596 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-65dBm) WPA2/PSK
40597 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40608 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40619 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40629 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40640 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40651 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40661 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40672 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40683 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
40694 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (RTC) WPA2/PSK attempt #4
40698 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
41881 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1169 ms
41881 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
42031 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 162 ms
42033 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
42033 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
wifikey,**********
50545 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8569 ms
50546 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
50716 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 10016 ms
50717 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
51434 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:2 (-73dBm) WPA2/PSK attempt #5
51437 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
53489 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1946 ms
53591 : Info   : WIFI : Set WiFi to OFF
53904 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2055 mss
54206 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2469 msa
54508 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2771 msv
54810 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3073 mse
55112 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3375 ms
55414 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3678 ms
55716 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3980 ms
56018 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4282 ms
56321 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4584 ms
56623 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4886 ms
56925 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5188 ms
56925 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
56936 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
56947 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
56957 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
56968 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
56979 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
56989 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
57000 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
57011 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
57021 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
57032 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
57043 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
>save
57055 : Info   : SaveToFile: free stack: 3408
57112 : Info   : FILE : Saved config.dat offset: 0 size: 1296
57112 : Info   : SaveToFile: free stack after: 3408
57113 : Info   : SaveToFile: free stack: 2912
57121 : Info   : FILE : Saved security.dat offset: 1024 size: 128
57122 : Info   : SaveToFile: free stack after: 2912
Ok
57629 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-65dBm) WPA2/PSK
57630 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-69dBm) WPA2/PSK attempt #6
57733 : Info   : WIFI : Set WiFi to STA
57924 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
59097 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1450 ms
59098 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
60931 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1847 ms
60933 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
60933 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
61645 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19240 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
69587 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
69588 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
70496 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:2 (-73dBm) WPA2/PSK attempt #7
70499 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
72639 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2036 ms
72741 : Info   : WIFI : Set WiFi to OFF
73054 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2143 ms
73357 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2558 ms
73659 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2861 ms
73961 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3163 ms
74263 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3465 ms
74565 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3767 ms
74867 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4069 ms
75169 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4371 ms
75471 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4673 ms
75773 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4975 ms
76076 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5277 ms
76076 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76087 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76097 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76108 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76119 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76130 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76140 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76151 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76162 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76172 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76183 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76194 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76783 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-75dBm) WPA2/PSK attempt #8
76886 : Info   : WIFI : Set WiFi to STA
77044 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79094 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 2204 ms
79197 : Info   : WIFI : Set WiFi to OFF
79510 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2311 ms
79812 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2726 ms
80115 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3029 ms
80417 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3331 ms
80719 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3633 ms
81021 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3935 ms
81323 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4237 ms
81625 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4539 ms
81927 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4841 ms
82229 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5143 ms
82230 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82240 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82251 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82262 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82273 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82283 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82294 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82305 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82315 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82326 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82337 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
82937 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-80dBm) WPA2/PSK attempt #9
83040 : Info   : WIFI : Set WiFi to STA
83146 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
84307 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1268 ms
84410 : Info   : WIFI : Set WiFi to OFF
84723 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1370 ms
85025 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1785 ms
85327 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2087 ms
85630 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2389 ms
85932 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2691 ms
86234 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2994 ms
86536 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3296 ms
86838 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3598 ms
87140 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3900 ms
87442 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4202 ms
87744 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4504 ms
88046 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4806 ms
88348 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5108 ms
88349 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88360 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88370 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88381 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88392 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88402 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88413 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88424 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88434 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88445 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88456 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88466 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88477 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
88488 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
89058 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-80dBm) WPA2/PSK attempt #10
89160 : Info   : WIFI : Set WiFi to STA
89266 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
89590 : Info   : WIFI : Set WiFi to AP+STA
90576 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
90680 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 1520 ms
90782 : Info   : WIFI : Set WiFi to OFF
91096 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1622 ms
91398 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2038 ms
91700 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2340 ms
92002 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2642 ms
92304 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2944 ms
92606 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3246 ms
92908 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3548 ms
93211 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3850 ms
93513 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4153 ms
93815 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4455 ms
94117 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4757 ms
94419 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5059 ms
94420 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94431 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94441 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94452 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94463 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94473 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94484 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94495 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94505 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94516 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94527 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94537 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94548 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94604 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 9736 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
95119 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:10 (-84dBm) WPA2/PSK attempt #11
95222 : Info   : WIFI : Set WiFi to STA
95328 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
95645 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 10 Duration: 518 ms
95645 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
97673 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2026 ms
97675 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
97675 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
106334 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
106335 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
106740 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 10 Duration: 11618 ms
106740 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
107234 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-88dBm) WPA2/PSK attempt #12
107238 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
109288 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1948 ms
109391 : Info   : WIFI : Set WiFi to OFF
109704 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2055 ms
110006 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2469 ms
110308 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2772 ms
110610 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3074 ms
110913 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3376 ms
111215 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3678 ms
111517 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3980 ms
111819 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4282 ms
112121 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4584 ms
112423 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4886 ms
112725 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5188 ms
112725 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
112736 : Info   : WiFi : Start network scan all channels
114919 : Info   : WiFi : Scan finished, found: 13
114923 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-69dBm) WPA2/PSK
114924 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
114935 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
114945 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
114956 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
114967 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
114977 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
114988 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
114999 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
115009 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
115020 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
115031 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
115043 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #13
115046 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
116062 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1006 ms
116063 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn
So I hope you can solve it. I'm looking forward for a new flash-version. Glad to test for you!
Thanks, Pieter
#9 Post by TD-er » 02 Jun 2021, 20:14
Here a build based on the latest 'mega' branch: https://www.dropbox.com/s/tkm1zgzpfdfl2 ... M.bin?dl=0
Tebogo
#10 Post by Tebogo » 02 Jun 2021, 22:22
I'll try that now, thank you!
I also found this link from another answer which you wrote in another thread.
I look quite similar with my case...
Tebogo
#11 Post by Tebogo » 02 Jun 2021, 22:45
I tried your last upload, but did not work ;-(
Here is the logging:
INIT : Booting version: ‘mega_8ce642f’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
48 : Info   : INIT : Free RAM:32248
49 : Info   : INIT : Soft Reboot #7 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 3339208905 - Restart Reason: Software/System restart
51 : Info   : FS   : Mounting…
76 : Info   : FS   : Mount successful, used 75802 bytes of 957314
96 : Info   : CRC  : SecuritySettings CRC   …OK
100 : Info   : WiFi : Start network scan all channels
2290 : Info   : WiFi : Scan finished, found: 16
2293 : Info   : WiFi : Start network scan all channels
2402 : Info   : INIT : Free RAM:26944
2404 : Info   : INIT : I2C
2404 : Info   : INIT : SPI not enabled
2538 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2544 : Info   : Webserver: start
2545 : Info   : Time set to 3339208905.000
2547 : Info   : Current Time Zone: STD time start: 2075-10-27 03:00:00 offset: 0 min
2550 : Info   : Local time: 2075-10-25 06:01:45
3888 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 19512 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4589 : Info   : WiFi : Scan finished, found: 9
4593 : Error  : WIFI : No valid wifi settings
4594 : Info   : WIFI : Set WiFi to AP+STA
5584 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
33891 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 17520 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
35570 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
63890 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 16328 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
64786 : Info   : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
72938 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
94664 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 14712 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
119809 : Info   : SaveToFile: free stack: 3456
119889 : Info   : FILE : Saved config.dat offset: 0 size: 1296
119890 : Info   : SaveToFile: free stack after: 3456
119891 : Info   : SaveToFile: free stack: 3296
119925 : Info   : FILE : Saved security.dat offset: 0 size: 593
119926 : Info   : SaveToFile: free stack after: 3296
119928 : Info   : SaveToFile: free stack: 2960
119939 : Info   : FILE : Saved security.dat offset: 1024 size: 128
119939 : Info   : SaveToFile: free stack after: 2960
119942 : Info   : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
119945 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-59dBm) WPA2/PSK
119946 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-59dBm) WPA2/PSK attempt #0
119952 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
121821 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1195 ms
121822 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
121824 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 69 ms
121827 : Info   : SaveToFile: free stack: 3216
121838 : Info   : FILE : Saved security.dat offset: 1024 size: 128
121839 : Info   : SaveToFile: free stack after: 3216
121842 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
121938 : Info   : firstLoopConnectionsEstablished
123886 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 12976 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
123887 : Error  : WiFi : Scan not needed, good candidate present
130541 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9297 ms
130542 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
130773 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 10821 ms
130774 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
139329 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8459 ms
139330 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
141526 : Info   : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 10 s
141527 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
141816 : Info   : Reset WiFi.
141818 : Info   : WIFI : Set WiFi to OFF
141932 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -68 status: STATION_CONNECTING
141943 : Info   : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
142046 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2 m 21 s
142047 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
142827 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-59dBm) WPA2/PSK
142829 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #1
142933 : Info   : WIFI : Set WiFi to STA
143132 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
144233 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1383 ms
144234 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
153899 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 16864 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
158261 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 14039 ms
158263 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
166670 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 22 s
166671 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
167577 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-62dBm) WPA2/PSK attempt #2
167582 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
167628 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 46 ms
167629 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
169231 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1605 ms
169233 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
177323 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9596 ms
177324 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
178261 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-64dBm) WPA2/PSK attempt #3
178267 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
179321 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 951 ms
179423 : Info   : WIFI : Set WiFi to OFF
179657 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
179658 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
180324 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-68dBm) WPA2/PSK attempt #4
180428 : Info   : WIFI : Set WiFi to STA
180628 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
181786 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 1453 ms
181787 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
181845 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 59 ms
181847 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
183886 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 17176 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
183887 : Error  : WiFi : Scan not needed, good candidate present
190546 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8665 ms
190547 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
191128 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 10796 ms
191129 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
191446 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-72dBm) WPA2/PSK attempt #5
191451 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
193497 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1948 ms
193600 : Info   : WIFI : Set WiFi to OFF
193834 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
193835 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
194510 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-72dBm) WPA2/PSK attempt #6
194614 : Info   : WIFI : Set WiFi to STA
194817 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
195984 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1466 ms
195985 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
197904 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1923 ms
197906 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
206505 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
206506 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
207262 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 12749 ms
207263 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
207405 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:10 (-73dBm) WPA2/PSK attempt #7
207410 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
209458 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1950 ms
209561 : Info   : WIFI : Set WiFi to OFF
209795 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
209796 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
210563 : Info   : WIFI : Set WiFi to STA
210760 : Info   : WiFi : Start network scan all channels
210763 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
212967 : Info   : WiFi : Scan finished, found: 7
212971 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-62dBm) WPA2/PSK
212974 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:2 (RTC) WPA2/PSK attempt #8
212979 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
214088 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 17352 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
214272 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 2 Duration: 1282 ms
214273 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
214353 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 91 ms
214355 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
223057 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8699 ms
223058 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
223333 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 2 Duration: 10355 ms
223334 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
223958 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-65dBm) WPA2/PSK attempt #9
223963 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
226010 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
226113 : Info   : WIFI : Set WiFi to OFF
226347 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
226347 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
227014 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-68dBm) WPA2/PSK attempt #10
227117 : Info   : WIFI : Set WiFi to STA
227317 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
229498 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 2479 ms
229499 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
231354 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1851 ms
231356 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
239758 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
239759 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
240665 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-69dBm) WPA2/PSK attempt #11
240671 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
240782 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 111 ms
240783 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
242343 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1558 ms
242345 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
243886 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 18144 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
243887 : Error  : WiFi : Scan not needed, good candidate present
250899 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
250900 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
251668 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 10997 ms
251669 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
251799 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-72dBm) WPA2/PSK attempt #12
251805 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
253387 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1474 ms
253489 : Info   : WIFI : Set WiFi to OFF
253723 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
253724 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
254399 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-72dBm) WPA2/PSK attempt #13
254503 : Info   : WIFI : Set WiFi to STA
254703 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
256757 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 2247 ms
256860 : Info   : WIFI : Set WiFi to OFF
257094 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
257095 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
257760 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:10 (-73dBm) WPA2/PSK attempt #14
257864 : Info   : WIFI : Set WiFi to STA
257971 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
258253 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 10 Duration: 490 ms
258254 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
258301 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 41 ms
258303 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
267002 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8648 ms
267003 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
267600 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 10 Duration: 9837 ms
267601 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
267901 : Info   : WiFi : Start network scan all channels
267906 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
268008 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 307 ms
268111 : Info   : WIFI : Set WiFi to OFF
268345 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
268346 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
273014 : Info   : WIFI : Set WiFi to STA
273212 : Info   : WiFi : Start network scan all channels
273215 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
273890 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 18224 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
273891 : Info   : WiFi : Start network scan all channels
275416 : Info   : WiFi : Scan finished, found: 8
275420 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:2 (-60dBm) WPA2/PSK
275424 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-65dBm) WPA2/PSK attempt #15
275429 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
276609 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1168 ms
276610 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
278463 : Info   : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1863 ms
278466 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
As you can see, I started in AP mode with ESP_Easy (@ 5584), selected my wifi, entered password (@ 119942), and it connected (@ 121821)
Even got a DHCP address, (@ 121824). But than it starts getting messy... Do you understand?
Tebogo
#12 Post by Tebogo » 02 Jun 2021, 23:17
Last try for today. I manage to get 20190607 working. From there I try to update to your last post-version.
See the logging:
INIT : Booting version: mega-20190607 (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
70 : INIT : Free RAM:29296
71 : INIT : Warm boot #10 - Restart Reason: Software/System restart
74 : FS   : Mounting…
99 : FS   : Mount successful, used 75802 bytes of 957314
451 : CRC  : program checksum       …OK
463 : CRC  : SecuritySettings CRC   …OK
571 : INIT : Free RAM:26496
572 : INIT : I2C
573 : INIT : SPI not enabled
587 : INFO : Plugins: 47 [Normal] (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
590 : WIFI : Set WiFi to STA
623 : WIFI : Connecting Linksys Velop WHW03 V2 attempt #0
625 : WIFI : Not configured in Station Mode!!: Linksys Velop WHW03 V2
1960 : WD   : Uptime 0 ConnectFailures 0 FreeMem 24552 WiFiStatus 0
Update: ESP_Easy_mega_20210602_normal_ESP8266_4M1M.bin
sleep disable
………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………Update Success: 919872
Rebooting…
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
@cp:0
ld
ªU13049 : Info   :
13050 : Info   : INIT : Free RAM:32384
13051 : Info   : INIT : Cold Boot - Restart Reason: Software/System restart
13052 : Info   : FS   : Mounting…
13077 : Info   : FS   : Mount successful, used 75802 bytes of 957314
13158 : Info   : FS   : Success garbage collection
13179 : Info   : CRC  : SecuritySettings CRC   …OK
Build changed!
reboot
>reboot
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU47 : Info   :
49 : Info   : INIT : Soft Reboot #1 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 222 - Restart Reason: Software/System restart
75 : Info   : FS   : Mount successful, used 75802 bytes of 957314
156 : Info   : FS   : Success garbage collection
177 : Info   : CRC  : SecuritySettings CRC   …OK
181 : Info   : WiFi : Start network scan all channels
295 : Info   : INIT : Free RAM:28128
297 : Info   : INIT : I2C
297 : Info   : INIT : SPI not enabled
430 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
436 : Info   : Webserver: start
437 : Info   : Time set to 222.000 Time adjusted by 221563.00 msec. Wander: 61.55 msec/second
439 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
441 : Info   : Local time: 1970-01-01 00:03:42
1782 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 20664 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
2487 : Info   : WiFi : Scan finished, found: 9
2492 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-62dBm) WPA2/PSK
2494 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (RTC) WPA2/PSK attempt #0
2498 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
4757 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 2145 ms
4860 : Info   : WIFI : Set WiFi to OFF
5094 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
Strange isn't it?
Re: Latest versions crashes my NodeMCU
#13 Post by TD-er » 03 Jun 2021, 10:39
This part looks strange to me as that should be dealt with:
I will have a look at it this evening.
It seems as if the WiFi events happen in an unexpected order and perhaps the WiFi disconnect event does happen more than once, on some nodes.
Really strange.
Tebogo
#14 Post by Tebogo » 04 Jun 2021, 17:57
Hello Td,
I tried again with your release, still same problems.
77 : Info   : INIT : Free RAM:32248
79 : Info   : INIT : Manual Reboot #2 Last Action before Reboot: Background Task Last systime: 1607 - Restart Reason: External System
80 : Info   : FS   : Mounting…
105 : Info   : FS   : Mount successful, used 75802 bytes of 957314
126 : Info   : CRC  : SecuritySettings CRC   …OK
130 : Info   : WiFi : Start network scan all channels
244 : Info   : INIT : Free RAM:27704
245 : Info   : INIT : I2C
246 : Info   : INIT : SPI not enabled
377 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
382 : Info   : Webserver: start
384 : Info   : Time set to 1607.000 Time adjusted by 1606617.00 msec. Wander: 446.28 msec/second
386 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
388 : Info   : Local time: 1970-01-01 00:26:47
1735 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 20792 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
2425 : Info   : WiFi : Scan finished, found: 8
2430 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-45dBm) WPA2/PSK
2432 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (RTC) WPA2/PSK attempt #0
2437 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
4731 : Info   : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2195 ms
4834 : Info   : WIFI : Set WiFi to OFF
5067 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
5068 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
5734 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #1
5838 : Info   : WIFI : Set WiFi to STA
5945 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
8299 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 2551 ms
8300 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
10124 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1829 ms
10126 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
10221 : Info   : firstLoopConnectionsEstablished
18826 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
18827 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19012 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 13274 ms
19013 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
19727 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK attempt #2
19731 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
21292 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1448 ms
21394 : Info   : WIFI : Set WiFi to OFF
21628 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
21629 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
22295 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-82dBm) WPA2/PSK attempt #3
22399 : Info   : WIFI : Set WiFi to STA
22603 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
23802 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1499 ms
23803 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
23873 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 71 ms
23874 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
31724 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19712 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
32576 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8678 ms
32576 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
32752 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 10452 ms
32753 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
33476 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (0dBm) Unknown attempt #4
33480 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
33638 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 49 ms
33741 : Info   : WIFI : Set WiFi to OFF
33975 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
33975 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
34753 : Info   : WIFI : Set WiFi to STA
34955 : Info   : WiFi : Start network scan all channels
34957 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
37154 : Info   : WiFi : Scan finished, found: 9
37157 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-28dBm) WPA2/PSK
37161 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-66dBm) WPA2/PSK attempt #5
37166 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
38544 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1364 ms
38545 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
38592 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 56 ms
38593 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
47294 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8666 ms
47295 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
48203 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-67dBm) WPA2/PSK attempt #6
48209 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
49368 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 1148 ms
49369 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
51213 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1859 ms
51214 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
59809 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
59810 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
60717 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-68dBm) WPA2/PSK attempt #7
60723 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
60900 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 76 ms
61002 : Info   : WIFI : Set WiFi to OFF
61236 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
61237 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
61731 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 18280 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
61732 : Info   : WiFi : Start network scan all channels
63936 : Info   : WiFi : Scan finished, found: 8
63940 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-71dBm) WPA2/PSK attempt #8
63945 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
65679 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1722 ms
65680 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
67494 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1823 ms
67495 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
75748 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9983 ms
75749 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
75914 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 11970 ms
75915 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
76648 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-74dBm) WPA2/PSK attempt #9
76653 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76789 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 24 ms
76892 : Info   : WIFI : Set WiFi to OFF
77126 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
77126 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
77793 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (0dBm) Unknown attempt #10
77896 : Info   : WIFI : Set WiFi to STA
78102 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
84432 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 6626 ms
84433 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
84514 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 87 ms
84516 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
91724 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 19192 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
93227 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8695 ms
93228 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
93387 : Info   : Reset WiFi.
93390 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -76 status: STATION_CONNECTING
93503 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1 m 33 s
93504 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
94491 : Info   : WIFI : Set WiFi to STA
94691 : Info   : WiFi : Start network scan all channels
94693 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
96890 : Info   : WiFi : Scan finished, found: 13
96894 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-29dBm) WPA2/PSK
96898 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-67dBm) WPA2/PSK attempt #11
96903 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
98352 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 1435 ms
98353 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
100117 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1780 ms
100118 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
108821 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
108822 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
109729 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-69dBm) WPA2/PSK attempt #12
109735 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
109867 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 130 ms
109868 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
109926 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 59 ms
109928 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
121724 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 17928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
121725 : Error  : WiFi : Scan not needed, good candidate present
151724 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 17928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
151725 : Error  : WiFi : Scan not needed, good candidate present
181723 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 17928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
181725 : Error  : WiFi : Scan not needed, good candidate present
211724 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 17928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
211725 : Error  : WiFi : Scan not needed, good candidate present
241723 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 17928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
241725 : Error  : WiFi : Scan not needed, good candidate present
271724 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 17928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
271725 : Error  : WiFi : Scan not needed, good candidate present
301724 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 17928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
301725 : Error  : WiFi : Scan not needed, good candidate present
331724 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 17928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
331725 : Error  : WiFi : Scan not needed, good candidate present
361724 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 18032 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
361725 : Error  : WiFi : Scan not needed, good candidate present
391723 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 18032 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
391725 : Error  : WiFi : Scan not needed, good candidate present
418570 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 5 m 8 s
418571 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
418959 : Info   : Reset WiFi.
418962 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -70 status: STATION_CONNECTING
419074 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 6 m 58 s
419075 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
419963 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #0
420064 : Info   : WIFI : Set WiFi to STA
420170 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
421766 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 20912 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
422603 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 2536 ms
422706 : Info   : WIFI : Set WiFi to OFF
422940 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
422941 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
423709 : Info   : WIFI : Set WiFi to STA
423812 : Info   : WiFi : Start network scan all channels
423815 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
426010 : Info   : WiFi : Scan finished, found: 8
426013 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-27dBm) WPA2/PSK
426016 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) Unknown attempt #1
426021 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
426195 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 164 ms
426196 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
439969 : Info   : WIFI : Set WiFi to AP+STA
440969 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
441023 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 14836 ms
441024 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
449579 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 23 s
449580 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
450011 : Info   : Reset WiFi.
450012 : Info   : WIFI : Set WiFi to OFF
450126 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -70 status: STATION_CONNECTING
450239 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 7 m 30 s
450239 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
451019 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-76dBm) WPA2/PSK attempt #2
451123 : Info   : WIFI : Set WiFi to STA
451328 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
451727 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 20088 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
454168 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 3130 ms
454169 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
454240 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 84 ms
454241 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
462954 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8691 ms
462955 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
463848 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-76dBm) WPA2/PSK attempt #3
463854 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
466178 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 2208 ms
466280 : Info   : WIFI : Set WiFi to OFF
466513 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
466514 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
467282 : Info   : WIFI : Set WiFi to STA
467481 : Info   : WiFi : Start network scan all channels
467485 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
469682 : Info   : WiFi : Scan finished, found: 8
469686 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-27dBm) WPA2/PSK
469689 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-67dBm) WPA2/PSK attempt #4
469695 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
470171 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 480 ms
470172 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
471994 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1822 ms
471995 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
480698 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
480699 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
481105 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 11406 ms
481106 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
481598 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-75dBm) WPA2/PSK attempt #5
481603 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
482621 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 19064 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
483651 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
483753 : Info   : WIFI : Set WiFi to OFF
483987 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
483988 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
484664 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-76dBm) WPA2/PSK attempt #6
484768 : Info   : WIFI : Set WiFi to STA
484972 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
487488 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 2806 ms
487489 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
489408 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1935 ms
489410 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
498111 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
498112 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
498813 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 14140 ms
498814 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
499011 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-76dBm) WPA2/PSK attempt #7
499017 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
501628 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2504 ms
501731 : Info   : WIFI : Set WiFi to OFF
501965 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
501966 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
502734 : Info   : WIFI : Set WiFi to STA
502938 : Info   : WiFi : Start network scan all channels
502942 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
505142 : Info   : WiFi : Scan finished, found: 5
505145 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-28dBm) WPA2/PSK
505149 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-67dBm) WPA2/PSK attempt #8
505154 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
506185 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1034 ms
506186 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
508154 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1969 ms
508156 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
511723 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 18832 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
511725 : Error  : WiFi : Scan not needed, good candidate present
516871 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
516872 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
517260 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 12107 ms
517261 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
517761 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-75dBm) WPA2/PSK attempt #9
517766 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
520058 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 2195 ms
520160 : Info   : WIFI : Set WiFi to OFF
520394 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
520395 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
521071 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-76dBm) WPA2/PSK attempt #10
521175 : Info   : WIFI : Set WiFi to STA
521381 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
525574 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 4388 ms
525677 : Info   : WIFI : Set WiFi to OFF
525911 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
525912 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
526578 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-76dBm) WPA2/PSK attempt #11
526682 : Info   : WIFI : Set WiFi to STA
526789 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
527818 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1224 ms
527819 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
529574 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1761 ms
529576 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
536622 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8717 ms
536623 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
537400 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 10818 ms
537401 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
537522 : Info   : WiFi : Start network scan all channels
537526 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
537628 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 128 ms
537731 : Info   : WIFI : Set WiFi to OFF
537965 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
537966 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
541733 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 18200 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
541734 : Info   : WiFi : Start network scan all channels
543940 : Info   : WiFi : Scan finished, found: 9
543944 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-29dBm) WPA2/PSK
543948 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-66dBm) WPA2/PSK attempt #12
543954 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
545181 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1213 ms
545182 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
547226 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2062 ms
547228 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
555607 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
555608 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
556006 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 12048 ms
556007 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
556508 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-72dBm) WPA2/PSK attempt #13
556513 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
557038 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 427 ms
557141 : Info   : WIFI : Set WiFi to OFF
557375 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
557376 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
558051 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-75dBm) WPA2/PSK attempt #14
558155 : Info   : WIFI : Set WiFi to STA
558358 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
559630 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1560 ms
559631 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
559678 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 62 ms
559679 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
568380 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8666 ms
568381 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
568632 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 10577 ms
568633 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
569280 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-76dBm) WPA2/PSK attempt #15
569284 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
571332 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
571435 : Info   : WIFI : Set WiFi to OFF
571669 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
571670 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
571725 : Info   : WD   : Uptime 10 ConnectFailures 0 FreeMem 17760 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
571727 : Info   : WiFi : Start network scan all channels
573929 : Info   : WiFi : Scan finished, found: 12
573934 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-76dBm) WPA2/PSK
573937 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-69dBm) WPA2/PSK attempt #16
573943 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
574953 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1012 ms
574954 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
575023 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 70 ms
575025 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
601724 : Info   : WD   : Uptime 10 ConnectFailures 0 FreeMem 17904 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
601725 : Error  : WiFi : Scan not needed, good candidate present
631723 : Info   : WD   : Uptime 11 ConnectFailures 0 FreeMem 17904 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
631725 : Error  : WiFi : Scan not needed, good candidate present
661724 : Info   : WD   : Uptime 11 ConnectFailures 0 FreeMem 17904 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
661725 : Error  : WiFi : Scan not needed, good candidate present
691723 : Info   : WD   : Uptime 12 ConnectFailures 0 FreeMem 17904 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
691725 : Error  : WiFi : Scan not needed, good candidate present
721724 : Info   : WD   : Uptime 12 ConnectFailures 0 FreeMem 17904 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
721725 : Error  : WiFi : Scan not needed, good candidate present
751723 : Info   : WD   : Uptime 13 ConnectFailures 0 FreeMem 17904 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
751725 : Error  : WiFi : Scan not needed, good candidate present
781723 : Info   : WD   : Uptime 13 ConnectFailures 0 FreeMem 18056 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
781725 : Error  : WiFi : Scan not needed, good candidate present
811724 : Info   : WD   : Uptime 14 ConnectFailures 0 FreeMem 18120 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
811725 : Error  : WiFi : Scan not needed, good candidate present
841723 : Info   : WD   : Uptime 14 ConnectFailures 0 FreeMem 18272 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
841725 : Error  : WiFi : Scan not needed, good candidate present
871724 : Info   : WD   : Uptime 15 ConnectFailures 0 FreeMem 18272 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
871725 : Error  : WiFi : Scan not needed, good candidate present
883657 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 5 m 8 s
883658 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
884560 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #0
884566 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
886092 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1414 ms
886194 : Info   : WIFI : Set WiFi to OFF
886427 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
886428 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
887206 : Info   : WIFI : Set WiFi to STA
887309 : Info   : WiFi : Start network scan all channels
887312 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
889506 : Info   : WiFi : Scan finished, found: 7
889509 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-28dBm) WPA2/PSK
889512 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) Unknown attempt #1
889517 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
890486 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 954 ms
890487 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
892584 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2108 ms
892586 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
900985 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
900985 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
901382 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 11865 ms
901383 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
901723 : Info   : WD   : Uptime 15 ConnectFailures 0 FreeMem 19952 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
901724 : Info   : WiFi : Start network scan all channels
901830 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 349 ms
901933 : Info   : WIFI : Set WiFi to OFF
902167 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
902167 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
906830 : Info   : WIFI : Set WiFi to STA
907031 : Info   : WiFi : Start network scan all channels
907034 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
909235 : Info   : WiFi : Scan finished, found: 6
909238 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-25dBm) WPA2/PSK
909241 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) Unknown attempt #2
909246 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
910885 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1526 ms
910987 : Info   : WIFI : Set WiFi to OFF
911221 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
911222 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
911999 : Info   : WIFI : Set WiFi to STA
912103 : Info   : WiFi : Start network scan all channels
912106 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
914305 : Info   : WiFi : Scan finished, found: 10
914309 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-25dBm) WPA2/PSK
914313 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) Unknown attempt #3
914317 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
914560 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 229 ms
914561 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
929250 : Info   : WIFI : Set WiFi to AP+STA
929371 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
931724 : Info   : WD   : Uptime 16 ConnectFailures 0 FreeMem 16632 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
934318 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-69dBm) WPA2/PSK attempt #4
934323 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
935401 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 975 ms
935503 : Info   : WIFI : Set WiFi to OFF
935738 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
935739 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
936404 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-76dBm) WPA2/PSK attempt #5
936508 : Info   : WIFI : Set WiFi to STA
936615 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
938698 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 2292 ms
938699 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
938910 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 205 ms
938911 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
947362 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8563 ms
947362 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
948262 : Info   : WiFi : Start network scan all channels
948264 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
950459 : Info   : WiFi : Scan finished, found: 11
950463 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-26dBm) WPA2/PSK
950466 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-67dBm) WPA2/PSK attempt #6
950472 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
951729 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1160 ms
951832 : Info   : WIFI : Set WiFi to OFF
952066 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
952066 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
952742 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-68dBm) WPA2/PSK attempt #7
952846 : Info   : WIFI : Set WiFi to STA
953051 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
953313 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 569 ms
953314 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
955087 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1767 ms
955088 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
961724 : Info   : WD   : Uptime 16 ConnectFailures 0 FreeMem 18928 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
961725 : Error  : WiFi : Scan not needed, good candidate present
963791 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
963792 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
964548 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 11797 ms
964549 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
964691 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-77dBm) WPA2/PSK attempt #8
964697 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
966837 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2042 ms
966940 : Info   : WIFI : Set WiFi to OFF
967174 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
967175 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
967943 : Info   : WIFI : Set WiFi to STA
968142 : Info   : WiFi : Start network scan all channels
968146 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
970348 : Info   : WiFi : Scan finished, found: 13
970353 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-29dBm) WPA2/PSK
970356 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #9
970361 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
975519 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 5156 ms
975520 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
984700 : Info   : WIFI : Set WiFi to AP+STA
984810 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
989501 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 13979 ms
989502 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
991723 : Info   : WD   : Uptime 17 ConnectFailures 0 FreeMem 15952 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
991725 : Error  : WiFi : Scan not needed, good candidate present
998055 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 22 s
998056 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
998479 : Info   : Reset WiFi.
998480 : Info   : WIFI : Set WiFi to OFF
998594 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -71 status: STATION_CONNECTING
998707 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 16 m 38 s
998707 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
999489 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-69dBm) WPA2/PSK attempt #10
999593 : Info   : WIFI : Set WiFi to STA
999800 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1001349 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1854 ms
1001350 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1001420 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 67 ms
1001421 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1009987 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8541 ms
1009988 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1010732 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 11235 ms
1010733 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1010887 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-73dBm) WPA2/PSK attempt #11
1010892 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1012939 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1948 ms
1013042 : Info   : WIFI : Set WiFi to OFF
1013275 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1013276 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1013952 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-79dBm) WPA2/PSK attempt #12
1014055 : Info   : WIFI : Set WiFi to STA
1014260 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1016554 : Info   : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2499 ms
1016657 : Info   : WIFI : Set WiFi to OFF
1016891 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1016891 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1017669 : Info   : WIFI : Set WiFi to STA
1017772 : Info   : WiFi : Start network scan all channels
1017775 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1019974 : Info   : WiFi : Scan finished, found: 11
1019979 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-26dBm) WPA2/PSK
1019982 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #13
1019987 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1021751 : Info   : WD   : Uptime 17 ConnectFailures 0 FreeMem 18488 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1022421 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 2322 ms
1022524 : Info   : WIFI : Set WiFi to OFF
1022758 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1022759 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1023425 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-69dBm) WPA2/PSK attempt #14
1023528 : Info   : WIFI : Set WiFi to STA
1023636 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1024837 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1392 ms
1024837 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1024885 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 64 ms
1024886 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1033332 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8413 ms
1033333 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1034240 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-73dBm) WPA2/PSK attempt #15
1034246 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1034721 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 465 ms
1034722 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1034758 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 50 ms
1034760 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1043239 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8430 ms
1043240 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1044146 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-82dBm) WPA2/PSK attempt #16
1044152 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1046453 : Info   : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2193 ms
1046556 : Info   : WIFI : Set WiFi to OFF
1046790 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1046791 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1047569 : Info   : WIFI : Set WiFi to STA
1047768 : Info   : WiFi : Start network scan all channels
1047771 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1049972 : Info   : WiFi : Scan finished, found: 9
1049977 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-26dBm) WPA2/PSK
1049981 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #17
1049985 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1051749 : Info   : WD   : Uptime 18 ConnectFailures 0 FreeMem 18480 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1053264 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 3282 ms
1053265 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1057153 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 3883 ms
1057155 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1065869 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 12 s
1065870 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1066006 : Info   : Reset WiFi.
1066008 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -68 status: STATION_CONNECTING
1066120 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 17 m 46 s
1066121 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1067009 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-69dBm) WPA2/PSK attempt #18
1067110 : Info   : WIFI : Set WiFi to STA
1067311 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1068596 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1585 ms
1068597 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1068667 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 63 ms
1068669 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1077370 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8674 ms
1077371 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1078108 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 11090 ms
1078109 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1078271 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-73dBm) WPA2/PSK attempt #19
1078276 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1080518 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2134 ms
1080621 : Info   : WIFI : Set WiFi to OFF
1080855 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1080856 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1081532 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-79dBm) WPA2/PSK attempt #20
1081636 : Info   : WIFI : Set WiFi to STA
1081837 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1081892 : Info   : WD   : Uptime 18 ConnectFailures 0 FreeMem 18792 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1084130 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 2596 ms
1084131 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1086039 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1909 ms
1086041 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1094741 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
1094742 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1095203 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 13667 ms
1095204 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1095641 : Info   : WiFi : Start network scan all channels
1095645 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
1095747 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 444 ms
1095850 : Info   : WIFI : Set WiFi to OFF
1096084 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1096085 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1100755 : Info   : WIFI : Set WiFi to STA
1100953 : Info   : WiFi : Start network scan all channels
1100957 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1103158 : Info   : WiFi : Scan finished, found: 7
1103162 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-29dBm) WPA2/PSK
1103166 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #21
1103170 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1105234 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1949 ms
1105337 : Info   : WIFI : Set WiFi to OFF
1105571 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1105572 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1106238 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-69dBm) WPA2/PSK attempt #22
1106342 : Info   : WIFI : Set WiFi to STA
1106450 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1107627 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1386 ms
1107628 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1109443 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1810 ms
1109445 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1111725 : Info   : WD   : Uptime 19 ConnectFailures 0 FreeMem 18200 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
1111727 : Error  : WiFi : Scan not needed, good candidate present
1117295 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9569 ms
1117296 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1118039 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 11792 ms
1118040 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1118196 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-73dBm) WPA2/PSK attempt #23
1118201 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1120341 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2041 ms
1120444 : Info   : WIFI : Set WiFi to OFF
1120678 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1120678 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1121345 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:4 (-79dBm) WPA2/PSK attempt #24
1121448 : Info   : WIFI : Set WiFi to STA
1121650 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1122838 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 4 Duration: 1491 ms
1122839 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1124780 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1933 ms
1124781 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
Did you manage to look to the error?:
#15 Post by TD-er » 05 Jun 2021, 09:30
Will try to fix it this weekend.
#16 Post by TD-er » 06 Jun 2021, 12:23
Tebogo wrote: 04 Jun 2021, 17:57 Hello Td,
Can you try the test build I linked with the PR: https://github.com/letscontrolit/ESPEasy/pull/3676
Tebogo
#17 Post by Tebogo » 07 Jun 2021, 13:33
Hereby the logging. Did not solve the problem
Logging includes from bootstart after update.
After boot, I manage to enter the wifi-credentials, and after that I just wait till ping to assigned ip-adress is successfull.
But it never replies on ping...
278 : Info   : INIT : Cold Boot - Restart Reason: External System
279 : Info   : FS   : Mounting…
4190 : Info   : FS   : Mount successful, used 0 bytes of 957314
RESET: Resetting factory defaults… using default settings
RESET: Warm boot, reset count: 0
RESET: formatting…
RESET: formatting done…
14878 : Info   : SaveToFile: free stack: 3504
14943 : Info   : FILE : Saved config.dat offset: 28672 size: 820
14943 : Info   : SaveToFile: free stack after: 3504
14944 : Info   : SaveToFile: free stack: 3568
15023 : Info   : FILE : Saved config.dat offset: 0 size: 1296
15024 : Info   : SaveToFile: free stack after: 3568
15025 : Info   : SaveToFile: free stack: 3408
15061 : Info   : FILE : Saved security.dat offset: 0 size: 593
15062 : Info   : SaveToFile: free stack after: 3408
15064 : Info   : SaveToFile: free stack: 3072
15075 : Info   : FILE : Saved security.dat offset: 1024 size: 128
15076 : Info   : SaveToFile: free stack after: 3072
RESET: Successful, rebooting. (you might need to press the reset button if you’ve just flashed the firmware)
 ets Jan  8 2013,rst cause:2, boot mode:(3,7)
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU47 : Info   :
INIT : Booting version: ‘bugfix/wifi_not_reconnect_f9f86f5’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
48 : Info   : INIT : Free RAM:32232
49 : Info   : INIT : Soft Reboot #1 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 16 - Restart Reason: Software/System restart
51 : Info   : FS   : Mounting…
76 : Info   : FS   : Mount successful, used 75802 bytes of 957314
96 : Info   : CRC  : SecuritySettings CRC   …OK
100 : Info   : WiFi : Start network scan all channels
2289 : Info   : WiFi : Scan finished, found: 15
2292 : Info   : WiFi : Start network scan all channels
2401 : Info   : INIT : Free RAM:26968
2402 : Info   : INIT : I2C
2402 : Info   : INIT : SPI not enabled
2520 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2526 : Info   : Webserver: start
2527 : Info   : Time set to 16.000 Time adjusted by 13473.00 msec. Wander: 3.74 msec/second
2529 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2531 : Info   : Local time: 1970-01-01 00:00:16
3870 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 19752 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4573 : Info   : WiFi : Scan finished, found: 6
4576 : Error  : WIFI : No valid wifi settings
4577 : Info   : WIFI : Set WiFi to AP+STA
5567 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
21314 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
21663 : Info   : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
21966 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33875 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 14960 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
63047 : Info   : SaveToFile: free stack: 3456
63129 : Info   : FILE : Saved config.dat offset: 0 size: 1296
63130 : Info   : SaveToFile: free stack after: 3456
63131 : Info   : SaveToFile: free stack: 3296
63169 : Info   : FILE : Saved security.dat offset: 0 size: 593
63170 : Info   : SaveToFile: free stack after: 3296
63172 : Info   : SaveToFile: free stack: 2960
63183 : Info   : FILE : Saved security.dat offset: 1024 size: 128
63183 : Info   : SaveToFile: free stack after: 2960
63185 : Info   : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
63189 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-61dBm) WPA2/PSK
63190 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-61dBm) WPA2/PSK attempt #0
63196 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
65471 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 14168 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
66352 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 3141 ms
66353 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
68326 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1986 ms
68329 : Info   : SaveToFile: free stack: 3216
68340 : Info   : FILE : Saved security.dat offset: 1024 size: 128
68340 : Info   : SaveToFile: free stack after: 3216
68343 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
68443 : Info   : firstLoopConnectionsEstablished
77051 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
77052 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
77175 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 13980 ms
77176 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
93866 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 13720 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
93867 : Info   : WiFi : Start network scan all channels
93973 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 16 s
93974 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
96067 : Info   : WiFi : Scan finished, found: 8
123878 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 14104 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
153883 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 14608 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
183886 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 14968 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
213882 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 14968 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
243878 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 14968 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
243879 : Info   : WiFi : Start network scan all channels
246080 : Info   : WiFi : Scan finished, found: 10
273885 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 14904 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
303881 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 14904 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
333886 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 15328 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
363879 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 15328 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
393879 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 15328 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
393880 : Info   : WiFi : Start network scan all channels
396081 : Info   : WiFi : Scan finished, found: 10
405956 : Info   : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
405957 : Info   : WIFI : Set WiFi to STA
406168 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-63dBm) WPA2/PSK
406170 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #1
406175 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
408417 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 2134 ms
408520 : Info   : WIFI : Set WiFi to OFF
408754 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
408754 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
409423 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK attempt #2
409527 : Info   : WIFI : Set WiFi to STA
409634 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
409648 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-77dBm) WPA2/PSK attempt #3
409653 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
411008 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1346 ms
411009 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
412858 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1859 ms
412859 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
420872 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9775 ms
420873 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
421777 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-78dBm) WPA2/PSK attempt #4
421782 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
423399 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1506 ms
423501 : Info   : WIFI : Set WiFi to OFF
423735 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
423735 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
423878 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 18176 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
423879 : Info   : WiFi : Start network scan all channels
426079 : Info   : WiFi : Scan finished, found: 9
426082 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-62dBm) WPA2/PSK
426086 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (RTC) WPA2/PSK attempt #5
426091 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
428138 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1949 ms
428241 : Info   : WIFI : Set WiFi to OFF
428475 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
428476 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
429143 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK attempt #6
429247 : Info   : WIFI : Set WiFi to STA
429462 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
429477 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-77dBm) WPA2/PSK attempt #7
429481 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
432625 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 5 Duration: 3130 ms
432626 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
432860 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 149 ms
432963 : Info   : WIFI : Set WiFi to OFF
433197 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
433197 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
433866 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-81dBm) WPA2/PSK attempt #8
433970 : Info   : WIFI : Set WiFi to STA
434077 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
434092 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-62dBm) WPA2/PSK
434094 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (RTC) WPA2/PSK attempt #9
434098 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
436435 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 2334 ms
436436 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
436529 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 93 ms
436530 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
444836 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8306 ms
444837 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
445747 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK attempt #10
445753 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
446784 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1029 ms
446785 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
448766 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1986 ms
448767 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
453866 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 18912 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
453868 : Error  : WiFi : Scan not needed, good candidate present
457337 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
457338 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
457777 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 12021 ms
457778 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
458237 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-77dBm) WPA2/PSK attempt #11
458242 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
458741 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 391 ms
458844 : Info   : WIFI : Set WiFi to OFF
459078 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
459079 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
459748 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-81dBm) WPA2/PSK attempt #12
459852 : Info   : WIFI : Set WiFi to STA
460062 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
460077 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-62dBm) WPA2/PSK
460079 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (RTC) WPA2/PSK attempt #13
460083 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
461911 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1828 ms
461912 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
463655 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1740 ms
463657 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
472360 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
472361 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
473129 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 13041 ms
473130 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
473260 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK attempt #14
473265 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
475313 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
475416 : Info   : WIFI : Set WiFi to OFF
475650 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
475650 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
476318 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-77dBm) WPA2/PSK attempt #15
476421 : Info   : WIFI : Set WiFi to STA
476637 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
476652 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-81dBm) WPA2/PSK attempt #16
476656 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
477802 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1131 ms
477803 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
479685 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1898 ms
479687 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
483867 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 19120 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
488393 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
488394 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
489300 : Info   : WiFi : Start network scan all channels
489304 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
489418 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 11 s
489418 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
491503 : Info   : WiFi : Scan finished, found: 8
491506 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-61dBm) WPA2/PSK
491509 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (RTC) WPA2/PSK attempt #17
491514 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
492715 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1190 ms
492716 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
492818 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 111 ms
492819 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
501254 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8452 ms
501255 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
502158 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK attempt #18
502163 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
504211 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
504314 : Info   : WIFI : Set WiFi to OFF
504548 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
504548 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
505216 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-73dBm) WPA2/PSK attempt #19
505320 : Info   : WIFI : Set WiFi to STA
505537 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
505551 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-78dBm) WPA2/PSK attempt #20
505555 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
506817 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1252 ms
506818 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
508690 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1879 ms
508691 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
513867 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 18912 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
513868 : Error  : WiFi : Scan not needed, good candidate present
516893 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9985 ms
516893 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
517802 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 12248 ms
517803 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
517805 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-84dBm) WPA2/PSK attempt #21
517811 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
520053 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2135 ms
520156 : Info   : WIFI : Set WiFi to OFF
520390 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
520391 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
521162 : Info   : WIFI : Set WiFi to STA
521374 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
521388 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-61dBm) WPA2/PSK
521390 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (RTC) WPA2/PSK attempt #22
521395 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
523078 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1680 ms
523079 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
524920 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1843 ms
524922 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
533629 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
533630 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
533971 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 12572 ms
533972 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
534529 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK attempt #23
534534 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
536583 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1950 ms
536686 : Info   : WIFI : Set WiFi to OFF
536920 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
536921 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
537588 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-73dBm) WPA2/PSK attempt #24
537692 : Info   : WIFI : Set WiFi to STA
537906 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
537921 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-78dBm) WPA2/PSK attempt #25
537925 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
539413 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1472 ms
539414 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
541242 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1844 ms
541243 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
543866 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 18912 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
543868 : Error  : WiFi : Scan not needed, good candidate present
549947 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
549948 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
550853 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-84dBm) WPA2/PSK attempt #26
550858 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
552999 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2042 ms
553102 : Info   : WIFI : Set WiFi to OFF
553335 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
553336 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
554106 : Info   : WIFI : Set WiFi to STA
554313 : Info   : WiFi : Start network scan all channels
554317 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
556514 : Info   : WiFi : Scan finished, found: 8
556518 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-61dBm) WPA2/PSK
556521 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (RTC) WPA2/PSK attempt #27
556526 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
558740 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 2202 ms
558741 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
558821 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 94 ms
558823 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
567530 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8704 ms
567531 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
567872 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 11344 ms
567873 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
568430 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-71dBm) WPA2/PSK attempt #28
568436 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
570385 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1846 ms
570486 : Info   : WIFI : Set WiFi to OFF
570720 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
570721 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
571389 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-73dBm) WPA2/PSK attempt #29
571493 : Info   : WIFI : Set WiFi to STA
571706 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
571720 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-78dBm) WPA2/PSK attempt #30
571724 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
572892 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1170 ms
572893 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
573875 : Info   : WD   : Uptime 10 ConnectFailures 0 FreeMem 18848 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
574859 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1961 ms
574860 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
583576 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
583577 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
584311 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 12585 ms
584312 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
584465 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-83dBm) WPA2/PSK attempt #31
584470 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
586712 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2135 ms
586816 : Info   : WIFI : Set WiFi to OFF
587049 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
587050 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
587821 : Info   : WIFI : Set WiFi to STA
588029 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
588044 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-61dBm) WPA2/PSK
588046 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (RTC) WPA2/PSK attempt #32
588051 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
589324 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1264 ms
589325 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
591241 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1928 ms
591243 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
599949 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
599950 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
600850 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-71dBm) WPA2/PSK attempt #33
600856 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
601865 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 994 ms
601866 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
601936 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 88 ms
601938 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
603866 : Info   : WD   : Uptime 10 ConnectFailures 0 FreeMem 18640 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
603868 : Error  : WiFi : Scan not needed, good candidate present
633867 : Info   : WD   : Uptime 11 ConnectFailures 0 FreeMem 18136 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
633868 : Error  : WiFi : Scan not needed, good candidate present
663867 : Info   : WD   : Uptime 11 ConnectFailures 0 FreeMem 18136 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
663868 : Error  : WiFi : Scan not needed, good candidate present
693866 : Info   : WD   : Uptime 12 ConnectFailures 0 FreeMem 18136 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
693868 : Error  : WiFi : Scan not needed, good candidate present
723867 : Info   : WD   : Uptime 12 ConnectFailures 0 FreeMem 18136 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
723868 : Error  : WiFi : Scan not needed, good candidate present
753866 : Info   : WD   : Uptime 13 ConnectFailures 0 FreeMem 18136 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
753868 : Error  : WiFi : Scan not needed, good candidate present
783867 : Info   : WD   : Uptime 13 ConnectFailures 0 FreeMem 18328 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
783868 : Error  : WiFi : Scan not needed, good candidate present
813866 : Info   : WD   : Uptime 14 ConnectFailures 0 FreeMem 18328 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
813868 : Error  : WiFi : Scan not needed, good candidate present
843867 : Info   : WD   : Uptime 14 ConnectFailures 0 FreeMem 18664 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
843868 : Error  : WiFi : Scan not needed, good candidate present
873867 : Info   : WD   : Uptime 15 ConnectFailures 0 FreeMem 18664 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
873868 : Error  : WiFi : Scan not needed, good candidate present
903867 : Info   : WD   : Uptime 15 ConnectFailures 0 FreeMem 19672 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
903868 : Info   : WiFi : Start network scan all channels
910562 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 5 m 8 s
910563 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
910754 : Info   : Reset WiFi.
910756 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -74 status: STATION_CONNECTING
910869 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 15 m 10 s
910870 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
911764 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #0
911865 : Info   : WIFI : Set WiFi to STA
911971 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
911985 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #1
911990 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
913114 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1126 ms
913115 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
917111 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 3997 ms
917113 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
925821 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 12 s
925822 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
926036 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 14048 ms
926037 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
926721 : Info   : WiFi : Start network scan all channels
926725 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
926827 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 690 ms
926930 : Info   : WIFI : Set WiFi to OFF
927164 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
927165 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
931829 : Info   : WIFI : Set WiFi to STA
932039 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
932054 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #2
932059 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
932321 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 257 ms
932322 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
933879 : Info   : WD   : Uptime 16 ConnectFailures 0 FreeMem 20176 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
934111 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1795 ms
934112 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
942819 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
942820 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
943035 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 10978 ms
943036 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
943719 : Info   : WiFi : Start network scan all channels
943723 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
943825 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 689 ms
943928 : Info   : WIFI : Set WiFi to OFF
944162 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
944163 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
948830 : Info   : WIFI : Set WiFi to STA
949038 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
949052 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #3
949057 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
950288 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1234 ms
950289 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
956115 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 5823 ms
956117 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
963866 : Info   : WD   : Uptime 16 ConnectFailures 0 FreeMem 19672 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
964821 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 14 s
964822 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
964949 : Info   : Reset WiFi.
964951 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -75 status: STATION_CONNECTING
965064 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 16 m 4 s
965065 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
966057 : Info   : WIFI : Set WiFi to STA
966266 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
966281 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #4
966286 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
968720 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 2332 ms
968823 : Info   : WIFI : Set WiFi to OFF
969057 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
969058 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
969829 : Info   : WIFI : Set WiFi to STA
969933 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
969947 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #5
969952 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
971219 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1158 ms
971322 : Info   : WIFI : Set WiFi to OFF
971556 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
971556 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
972326 : Info   : WIFI : Set WiFi to STA
972430 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
972444 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #6
972449 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
973617 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1066 ms
973720 : Info   : WIFI : Set WiFi to OFF
973953 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
973954 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
974724 : Info   : WIFI : Set WiFi to STA
974828 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
974842 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #7
974847 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
976123 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 1175 ms
976226 : Info   : WIFI : Set WiFi to OFF
976460 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
976461 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
977230 : Info   : WIFI : Set WiFi to STA
977334 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
977348 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (0dBm) Unknown attempt #8
977353 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
977976 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 610 ms
977977 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
978089 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 122 ms
978091 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
986798 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8737 ms
986799 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
987698 : Info   : WiFi : Start network scan all channels
987701 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
989896 : Info   : WiFi : Scan finished, found: 6
989898 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK
989902 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (RTC) WPA2/PSK attempt #9
989906 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
991996 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1989 ms
992099 : Info   : WIFI : Set WiFi to OFF
992333 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
992333 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
993103 : Info   : WIFI : Set WiFi to STA
993310 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
993324 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK
993326 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (RTC) WPA2/PSK attempt #10
993331 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
993893 : Info   : WD   : Uptime 17 ConnectFailures 0 FreeMem 20072 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
994501 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1066 ms
994604 : Info   : WIFI : Set WiFi to OFF
994838 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
994839 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
995609 : Info   : WIFI : Set WiFi to STA
995714 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
995728 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK
995729 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (RTC) WPA2/PSK attempt #11
995734 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
996924 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 1074 ms
997027 : Info   : WIFI : Set WiFi to OFF
997260 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
997261 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
998032 : Info   : WIFI : Set WiFi to STA
998135 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
998149 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-72dBm) WPA2/PSK
998151 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (RTC) WPA2/PSK attempt #12
998156 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1000644 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 10 Duration: 2472 ms
1000645 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1009911 : Info   : WIFI : Set WiFi to AP+STA
1010902 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
1015503 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 14874 ms
1015505 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1023866 : Info   : WD   : Uptime 17 ConnectFailures 0 FreeMem 17304 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
1024019 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 23 s
1024020 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1024909 : Info   : WiFi : Start network scan all channels
1024912 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1027105 : Info   : WiFi : Scan finished, found: 8
1027108 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-64dBm) WPA2/PSK
1027111 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #13
1027116 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1029408 : Info   : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2191 ms
1029511 : Info   : WIFI : Set WiFi to OFF
1029745 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1029746 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1030414 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:4 (-74dBm) WPA2/PSK attempt #14
1030518 : Info   : WIFI : Set WiFi to STA
1030732 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1030746 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-80dBm) WPA2/PSK attempt #15
1030751 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1032576 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1812 ms
1032577 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1032690 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 122 ms
1032691 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1041393 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8732 ms
1041394 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1042295 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-84dBm) WPA2/PSK attempt #16
1042300 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1043953 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 10 Duration: 1645 ms
1043954 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1044046 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 101 ms
1044048 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1052473 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8430 ms
1052474 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1053374 : Info   : WiFi : Start network scan all channels
1053378 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1053491 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 9436 ms
1053492 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1053878 : Info   : WD   : Uptime 18 ConnectFailures 0 FreeMem 19192 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1053880 : Info   : WiFi : Start network scan all channels
1055573 : Info   : WiFi : Scan finished, found: 9
1055576 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-66dBm) WPA2/PSK
1055580 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #17
1055585 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1057632 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1949 ms
1057735 : Info   : WIFI : Set WiFi to OFF
1057969 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1057970 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1058637 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:4 (-73dBm) WPA2/PSK attempt #18
1058741 : Info   : WIFI : Set WiFi to STA
1058954 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1058969 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-74dBm) WPA2/PSK attempt #19
1058973 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1060108 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1131 ms
1060109 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1062091 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1988 ms
1062093 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1070807 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
1070808 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1070954 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 11977 ms
1070955 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1071696 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-77dBm) WPA2/PSK attempt #20
1071701 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1073261 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1463 ms
1073363 : Info   : WIFI : Set WiFi to OFF
1073597 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1073598 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1074266 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-80dBm) WPA2/PSK attempt #21
1074370 : Info   : WIFI : Set WiFi to STA
1074581 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1074596 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-84dBm) WPA2/PSK attempt #22
1074600 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1075756 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 10 Duration: 1158 ms
1075757 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1075840 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 83 ms
1075842 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1083866 : Info   : WD   : Uptime 18 ConnectFailures 0 FreeMem 18912 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
1084549 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8692 ms
1084550 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1084869 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 10 Duration: 10264 ms
1084870 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1085449 : Info   : WiFi : Start network scan all channels
1085453 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
1085555 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 592 ms
1085658 : Info   : WIFI : Set WiFi to OFF
1085892 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1085893 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1090559 : Info   : WIFI : Set WiFi to STA
1090769 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1090784 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-66dBm) WPA2/PSK
1090785 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (RTC) WPA2/PSK attempt #23
1090790 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1094129 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 3330 ms
1094130 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1110788 : Info   : WIFI : Set WiFi to AP+STA
1110909 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
1110911 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:4 (-73dBm) WPA2/PSK attempt #24
1110916 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1112965 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
1113068 : Info   : WIFI : Set WiFi to OFF
1113303 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1113304 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1113884 : Info   : WD   : Uptime 19 ConnectFailures 0 FreeMem 16416 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1113885 : Info   : WiFi : Start network scan all channels
1116083 : Info   : WiFi : Scan finished, found: 8
1116088 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-74dBm) WPA2/PSK attempt #25
1116094 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1117252 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1145 ms
1117253 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1119111 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1866 ms
1119112 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
1127702 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
1127703 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1127893 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 11798 ms
1127894 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
1128602 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-77dBm) WPA2/PSK attempt #26
1128606 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
1130166 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1451 ms
1130268 : Info   : WIFI : Set WiFi to OFF
1130502 : Error  : WiFi : Scan not allowed, unprocessed WiFi events:  disconn
1130503 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
Re: Latest versions crashes my NodeMCU
#18 Post by Ath » 07 Jun 2021, 16:39
Have you tried:
- A build with 'alt_wifi' in the name? (Uses a different Arduino Wifi setup)
- A build with 'beta' in the name? (Uses a beta release of the Arduino libraries)
And a few more questions:
- Has your Wifi password any special characters, not in the ascii range 32 to 127?
- Are the spaces in the AP name actual spaces or ascii 255?
#19 Post by TD-er » 07 Jun 2021, 17:22
The WiFi gets disconnected quite often, so I will make a new test build ASAP... (working on it right now).
#20 Post by TD-er » 07 Jun 2021, 19:24
New test build: https://www.dropbox.com/s/8guisppj0ygtg ... M.bin?dl=0
Please let me know how well this one behaves...
Tebogo
#21 Post by Tebogo » 07 Jun 2021, 23:05
Thanks, errors disappeared, but result is the same.
The esp gets a Ip-adress and than connection is lost. It's never ping-able on it ip-adress.
It gets a Ip-adress from my DHCP server. but then is stops, and starts reconnecting..
Ath wrote: 07 Jun 2021, 16:39 And a few more questions:
It's get a connection with my wifi, so SSID and Wifi-key are correct. And I tried with other SSID and wifikey. Same result.
INIT : Booting version: ‘bugfix/wifi_not_reconnect_360b339’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
278 : Info   : INIT : Free RAM:32200
279 : Info   : INIT : Cold Boot - Restart Reason: External System
280 : Info   : FS   : Mounting…
4175 : Info   : FS   : Mount successful, used 0 bytes of 957314
RESET: formatting…
14823 : Info   : SaveToFile: free stack: 3504
14886 : Info   : FILE : Saved config.dat offset: 28672 size: 820
14887 : Info   : SaveToFile: free stack after: 3504
14888 : Info   : SaveToFile: free stack: 3568
14965 : Info   : FILE : Saved config.dat offset: 0 size: 1296
14965 : Info   : SaveToFile: free stack after: 3568
14966 : Info   : SaveToFile: free stack: 3408
15001 : Info   : FILE : Saved security.dat offset: 0 size: 593
15002 : Info   : SaveToFile: free stack after: 3408
15004 : Info   : SaveToFile: free stack: 3072
15015 : Info   : FILE : Saved security.dat offset: 1024 size: 128
15016 : Info   : SaveToFile: free stack after: 3072
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU77 : Info   :
80 : Info   : INIT : Soft Reboot #1 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 16 - Restart Reason: Software/System restart
81 : Info   : FS   : Mounting…
106 : Info   : FS   : Mount successful, used 75802 bytes of 957314
127 : Info   : CRC  : SecuritySettings CRC   …OK
131 : Info   : WiFi : Start network scan all channels
2319 : Info   : WiFi : Scan finished, found: 12
2322 : Info   : WiFi : Start network scan all channels
2431 : Info   : INIT : Free RAM:27192
2432 : Info   : INIT : I2C
2433 : Info   : INIT : SPI not enabled
2556 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2562 : Info   : Webserver: start
2563 : Info   : Time set to 16.000 Time adjusted by 13437.00 msec. Wander: 3.73 msec/second
2565 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2567 : Info   : Local time: 1970-01-01 00:00:16
3905 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 19976 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4611 : Info   : WiFi : Scan finished, found: 6
4614 : Error  : WIFI : No valid wifi settings
4614 : Info   : WIFI : Set WiFi to AP+STA
5604 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
33912 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 17824 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
63906 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 17824 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
63907 : Info   : WiFi : Start network scan all channels
66104 : Info   : WiFi : Scan finished, found: 7
80168 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
93908 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 15168 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
107810 : Info   : SaveToFile: free stack: 3456
107888 : Info   : FILE : Saved config.dat offset: 0 size: 1296
107889 : Info   : SaveToFile: free stack after: 3456
107890 : Info   : SaveToFile: free stack: 3296
107925 : Info   : FILE : Saved security.dat offset: 0 size: 593
107926 : Info   : SaveToFile: free stack after: 3296
107928 : Info   : SaveToFile: free stack: 2960
107938 : Info   : FILE : Saved security.dat offset: 1024 size: 128
107939 : Info   : SaveToFile: free stack after: 2960
107941 : Info   : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
107944 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK
107946 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK attempt #0
107951 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
111532 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 2140 ms
111533 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
111939 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1848 ms
111942 : Info   : SaveToFile: free stack: 3216
111953 : Info   : FILE : Saved security.dat offset: 1024 size: 128
111954 : Info   : SaveToFile: free stack after: 3216
111957 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
112055 : Info   : firstLoopConnectionsEstablished
120662 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
120663 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
121355 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 13404 ms
121356 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
123902 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 13976 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
123903 : Info   : WiFi : Start network scan all channels
124009 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2556 ms
124112 : Info   : WIFI : Set WiFi to OFF
124327 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
124330 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK
124331 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK attempt #1
124435 : Info   : WIFI : Set WiFi to STA
124649 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
124662 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-65dBm) WPA2/PSK attempt #2
124668 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
125678 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1002 ms
125679 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
127673 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2000 ms
127675 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
136390 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
136391 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
137281 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-67dBm) WPA2/PSK attempt #3
137287 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
138341 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 951 ms
138443 : Info   : WIFI : Set WiFi to OFF
138657 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
138659 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-72dBm) WPA2/PSK attempt #4
138762 : Info   : WIFI : Set WiFi to STA
138972 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
138985 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-72dBm) WPA2/PSK attempt #5
138990 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
140148 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1160 ms
140149 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
142030 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1875 ms
142032 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
150744 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
150745 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
150922 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 11926 ms
150923 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
151633 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #6
151638 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
154197 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 17968 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
155231 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 3480 ms
155334 : Info   : WIFI : Set WiFi to OFF
155548 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
155550 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-84dBm) WPA2/PSK attempt #7
155654 : Info   : WIFI : Set WiFi to STA
155863 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
155877 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK
155879 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK attempt #8
155882 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
157228 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1232 ms
157331 : Info   : WIFI : Set WiFi to OFF
157546 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
157548 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-65dBm) WPA2/PSK attempt #9
157651 : Info   : WIFI : Set WiFi to STA
157759 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
157772 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-67dBm) WPA2/PSK attempt #10
157778 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
158788 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 997 ms
158789 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
160774 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1997 ms
160776 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
169479 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
169480 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
169964 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 12189 ms
169965 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
170379 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-72dBm) WPA2/PSK attempt #11
170384 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
172436 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1950 ms
172539 : Info   : WIFI : Set WiFi to OFF
172754 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
172755 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-72dBm) WPA2/PSK attempt #12
172859 : Info   : WIFI : Set WiFi to STA
173073 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
173087 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #13
173091 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
175227 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 3 Duration: 2123 ms
175228 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
175309 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 91 ms
175310 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
183902 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 17968 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
183904 : Error  : WiFi : Scan not needed, good candidate present
184014 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8700 ms
184015 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
184924 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-84dBm) WPA2/PSK attempt #14
184930 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
186203 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1263 ms
186204 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
188068 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1876 ms
188070 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
195881 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9581 ms
195882 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
196773 : Info   : WiFi : Start network scan all channels
196775 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
196888 : Info   : WIFI : Disconnected! Reason: ‘(203) Assoc fail’ Connected for 10 s
196889 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
198973 : Info   : WiFi : Scan finished, found: 7
198977 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK
198979 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK attempt #15
198983 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
201213 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 2215 ms
201214 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
201272 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 67 ms
201274 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
209599 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8302 ms
209600 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
210356 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 11373 ms
210357 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
210499 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-63dBm) WPA2/PSK attempt #16
210505 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
212650 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2043 ms
212753 : Info   : WIFI : Set WiFi to OFF
212967 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
212969 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-68dBm) WPA2/PSK attempt #17
213072 : Info   : WIFI : Set WiFi to STA
213284 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
213297 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #18
213301 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
214517 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 17952 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
214659 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1360 ms
214660 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
216603 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1935 ms
216604 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
225317 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
225318 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
225496 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 12194 ms
225497 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
226206 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-72dBm) WPA2/PSK attempt #19
226211 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
227850 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1530 ms
227953 : Info   : WIFI : Set WiFi to OFF
228167 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
228169 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #20
228272 : Info   : WIFI : Set WiFi to STA
228483 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
228497 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-84dBm) WPA2/PSK attempt #21
228501 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
229702 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1185 ms
229703 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
231552 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1868 ms
231554 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
240268 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
240269 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
240437 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 11932 ms
240438 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
241157 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-89dBm) WPA2/PSK attempt #22
241162 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
242804 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1529 ms
242906 : Info   : WIFI : Set WiFi to OFF
243120 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
243123 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK
243124 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-52dBm) WPA2/PSK attempt #23
243228 : Info   : WIFI : Set WiFi to STA
243438 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
243451 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-63dBm) WPA2/PSK attempt #24
243457 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
244559 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 1099 ms
244560 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
244561 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 17800 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
244652 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 95 ms
244654 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
253357 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8704 ms
253358 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
254043 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 10588 ms
254044 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
254257 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-68dBm) WPA2/PSK attempt #25
254262 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
256315 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
256418 : Info   : WIFI : Set WiFi to OFF
256632 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
256634 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #26
256737 : Info   : WIFI : Set WiFi to STA
256948 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
256962 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-72dBm) WPA2/PSK attempt #27
256966 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
259384 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 2407 ms
259385 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
265355 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 5984 ms
265357 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
273903 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 18032 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
273904 : Error  : WiFi : Scan not needed, good candidate present
274071 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 14 s
274072 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
274393 : Info   : Reset WiFi.
274396 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -83 status: STATION_CONNECTING
274508 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4 m 34 s
274509 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
275396 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #28
275497 : Info   : WIFI : Set WiFi to STA
275708 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
275722 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-84dBm) WPA2/PSK attempt #29
275727 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
276886 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1162 ms
276887 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
276968 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 78 ms
276969 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
285465 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8478 ms
285466 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
286370 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-89dBm) WPA2/PSK attempt #30
286376 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
287800 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1324 ms
287902 : Info   : WIFI : Set WiFi to OFF
288116 : Info   : WiFi : Start network scan all channels
290303 : Info   : WiFi : Scan finished, found: 9
290307 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-55dBm) WPA2/PSK
290308 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
290309 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-55dBm) WPA2/PSK attempt #31
290314 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
291546 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1221 ms
291547 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
293315 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1777 ms
293317 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
301754 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
301755 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
302544 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 12228 ms
302545 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
302654 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-67dBm) WPA2/PSK attempt #32
302660 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
303933 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 18224 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
304714 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1951 ms
304817 : Info   : WIFI : Set WiFi to OFF
305031 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
305033 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #33
305137 : Info   : WIFI : Set WiFi to STA
305348 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
305361 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-69dBm) WPA2/PSK attempt #34
305365 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
306375 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1000 ms
306376 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
308371 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2000 ms
308373 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
317086 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
317087 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
317977 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:7 (-72dBm) WPA2/PSK attempt #35
317983 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
319278 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 7 Duration: 1287 ms
319278 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
319382 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 110 ms
319383 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
327892 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8525 ms
327893 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
328795 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-77dBm) WPA2/PSK attempt #36
328801 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
329000 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 83 ms
329102 : Info   : WIFI : Set WiFi to OFF
329316 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
329318 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-78dBm) WPA2/PSK attempt #37
329421 : Info   : WIFI : Set WiFi to STA
329628 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
329642 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-84dBm) WPA2/PSK attempt #38
329646 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
331958 : Info   : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2196 ms
332060 : Info   : WIFI : Set WiFi to OFF
332274 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
332276 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-55dBm) WPA2/PSK
332278 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-55dBm) WPA2/PSK attempt #39
332382 : Info   : WIFI : Set WiFi to STA
332489 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
332503 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-67dBm) WPA2/PSK attempt #40
332509 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
334243 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 1737 ms
334244 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
334258 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 18520 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
336244 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1994 ms
336245 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
344960 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
344961 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
345177 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:57:BB) Ch: 9 Duration: 12664 ms
345178 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
345849 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #41
345855 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
347554 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 760 ms
347656 : Info   : WIFI : Set WiFi to OFF
347870 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
347872 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-69dBm) WPA2/PSK attempt #42
347976 : Info   : WIFI : Set WiFi to STA
348185 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
348198 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-77dBm) WPA2/PSK attempt #43
348203 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
349384 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 3 Duration: 1182 ms
349385 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
349454 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 70 ms
349456 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
358160 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8676 ms
358161 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
359064 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-78dBm) WPA2/PSK attempt #44
359070 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
360217 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1044 ms
360319 : Info   : WIFI : Set WiFi to OFF
360533 : Info   : WiFi : Start network scan all channels
362720 : Info   : WiFi : Scan finished, found: 9
362724 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK
362725 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
362727 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK attempt #45
362732 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
363931 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 18480 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
363944 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1209 ms
363944 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
364025 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 82 ms
364026 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
372406 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8368 ms
372407 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
373307 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-64dBm) WPA2/PSK attempt #46
373312 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
375365 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
375468 : Info   : WIFI : Set WiFi to OFF
375682 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
375684 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-66dBm) WPA2/PSK attempt #47
375787 : Info   : WIFI : Set WiFi to STA
376002 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
376015 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #48
376021 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
377157 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1137 ms
377158 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
377226 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 70 ms
377228 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
385928 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8674 ms
385929 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386116 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 10096 ms
386117 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
386829 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #49
386833 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
388765 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1821 ms
388867 : Info   : WIFI : Set WiFi to OFF
389081 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
389083 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-75dBm) WPA2/PSK attempt #50
389187 : Info   : WIFI : Set WiFi to STA
389398 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
389412 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-84dBm) WPA2/PSK attempt #51
389416 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
390596 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 1168 ms
390597 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
392439 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1853 ms
392440 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
393903 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 19144 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
400864 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
400865 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
401063 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 1 Duration: 11646 ms
401064 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
401764 : Info   : WiFi : Start network scan all channels
401766 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
401868 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 707 ms
401971 : Info   : WIFI : Set WiFi to OFF
402185 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
402188 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK
402189 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK attempt #52
402293 : Info   : WIFI : Set WiFi to STA
402508 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
402522 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-64dBm) WPA2/PSK attempt #53
402527 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
403515 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 991 ms
403516 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
405512 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1996 ms
405513 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
414215 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
414216 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
414602 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 12077 ms
414603 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
415115 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-66dBm) WPA2/PSK attempt #54
415120 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
417172 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
417275 : Info   : WIFI : Set WiFi to OFF
417489 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
417491 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #55
417594 : Info   : WIFI : Set WiFi to STA
417807 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
417821 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #56
417825 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
419098 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 3 Duration: 1268 ms
419099 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
420927 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1829 ms
420929 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
423902 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 19040 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
423904 : Error  : WiFi : Scan not needed, good candidate present
429633 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
429634 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
430538 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-75dBm) WPA2/PSK attempt #57
430544 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
432595 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
432699 : Info   : WIFI : Set WiFi to OFF
432913 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
432916 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK
432917 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK attempt #58
433021 : Info   : WIFI : Set WiFi to STA
433232 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
433246 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-64dBm) WPA2/PSK attempt #59
433252 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
434926 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1667 ms
434927 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
436931 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2012 ms
436932 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
445366 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
445367 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
445788 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 12536 ms
445789 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
446266 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-66dBm) WPA2/PSK attempt #60
446271 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
448324 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1950 ms
448427 : Info   : WIFI : Set WiFi to OFF
448641 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
448643 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #61
448746 : Info   : WIFI : Set WiFi to STA
448958 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
448971 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #62
448975 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
450176 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 3 Duration: 1203 ms
450177 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
450269 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 92 ms
450271 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
453902 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 19040 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
453904 : Error  : WiFi : Scan not needed, good candidate present
458986 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8698 ms
458987 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
459286 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 3 Duration: 10310 ms
459287 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
459875 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-75dBm) WPA2/PSK attempt #63
459880 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
460189 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 210 ms
460292 : Info   : WIFI : Set WiFi to OFF
460506 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
460509 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK
460510 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK attempt #64
460614 : Info   : WIFI : Set WiFi to STA
460823 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
460836 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-64dBm) WPA2/PSK attempt #65
460842 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
461874 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 1019 ms
461875 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
463849 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1990 ms
463850 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
472553 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
472554 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
472964 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 5 Duration: 12119 ms
472965 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
473452 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-66dBm) WPA2/PSK attempt #66
473457 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
475509 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1950 ms
475613 : Info   : WIFI : Set WiFi to OFF
475827 : Info   : WiFi : Start network scan all channels
478013 : Info   : WiFi : Scan finished, found: 9
478017 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK
478018 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
478019 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-60dBm) WPA2/PSK attempt #67
478024 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
479585 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1546 ms
479586 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
481474 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1904 ms
481475 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
483902 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 18352 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
483904 : Error  : WiFi : Scan not needed, good candidate present
490057 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
490058 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
490872 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 12849 ms
490873 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
490957 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-64dBm) WPA2/PSK attempt #68
490962 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
493107 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2042 ms
493210 : Info   : WIFI : Set WiFi to OFF
493425 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
493427 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-66dBm) WPA2/PSK attempt #69
493530 : Info   : WIFI : Set WiFi to STA
493743 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
493757 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #70
493763 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
495139 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1363 ms
495140 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
495232 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 103 ms
495233 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
503936 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8712 ms
503937 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
504125 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 10361 ms
504126 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
504835 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:1 (-73dBm) WPA2/PSK attempt #71
504840 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
506892 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1948 ms
506994 : Info   : WIFI : Set WiFi to OFF
507209 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
507210 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #72
507314 : Info   : WIFI : Set WiFi to STA
507525 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
507538 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:10 (-74dBm) WPA2/PSK attempt #73
507543 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
510011 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 10 Duration: 2468 ms
510012 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
510170 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 155 ms
510172 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
513902 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 19232 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
518671 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8562 ms
518672 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
519574 : Info   : WiFi : Start network scan all channels
519578 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
519691 : Info   : WIFI : Disconnected! Reason: ‘(203) Assoc fail’ Connected for 9570 ms
519691 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
521774 : Info   : WiFi : Scan finished, found: 10
521778 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-62dBm) WPA2/PSK
521781 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:42:80 Ch:7 (-62dBm) WPA2/PSK attempt #74
521786 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
523632 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 1836 ms
523633 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
525443 : Info   : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1818 ms
525445 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
533780 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
533781 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
534530 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:42:80) Ch: 7 Duration: 12747 ms
534531 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
534680 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:5 (-63dBm) WPA2/PSK attempt #75
534685 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
536737 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 ms
536840 : Info   : WIFI : Set WiFi to OFF
537054 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
537056 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:57:BB Ch:9 (-66dBm) WPA2/PSK attempt #76
537160 : Info   : WIFI : Set WiFi to STA
537372 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
537386 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:E7 Ch:3 (-73dBm) WPA2/PSK attempt #77
537392 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
538808 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:E7) Ch: 3 Duration: 1403 ms
538809 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
Different reasons for disconnecting. What else can we do?
#22 Post by TD-er » 08 Jun 2021, 00:12
Can you power cycle the access point too? (and the ESP just for good measure)
The handshake timeout is funky as it suggests one side is not responding fast enough.
This can of course be some process that's running wild. (or buffers full, etc.)
Or either one (ESP or AP) does not hear the other one.
This does sound like WiFi TX power issues, or just power stability issues as the RF calibration at boot does require quite a high current peak and the calibration is based on measured voltage....
But I guess I may have to dive into this tomorrow. Although I will be away for most of the day, so that will be after dinner for sure.
Can you also test using a completely different ESP? and/or test with the ESP at a completely different location related to the access point. (rotate it, move it closer or further away from the AP, etc)
Tebogo
#23 Post by Tebogo » 08 Jun 2021, 08:49
Morning TD,
I power cycled all my AP's. Just let them al of, except 2. The rest can wait.
After that I used another ESP8266. Results are the same:
287 : Info   : INIT : Free RAM:32200
289 : Info   : INIT : Manual Reboot #2 Last Action before Reboot: 14 timer, id: 83370760 Last systime: 3020930607 - Restart Reason: External System
291 : Info   : FS   : Mounting…
7021 : Info   : FS   : Mount successful, used 0 bytes of 957314
RESET: Resetting factory defaults… using default settings
RESET: Warm boot, reset count: 0
RESET: formatting…
RESET: formatting done…
16673 : Info   : SaveToFile: free stack: 3504
16731 : Info   : FILE : Saved config.dat offset: 28672 size: 820
16732 : Info   : SaveToFile: free stack after: 3504
16733 : Info   : SaveToFile: free stack: 3568
16802 : Info   : FILE : Saved config.dat offset: 0 size: 1296
16803 : Info   : SaveToFile: free stack after: 3568
16804 : Info   : SaveToFile: free stack: 3408
16837 : Info   : FILE : Saved security.dat offset: 0 size: 593
16837 : Info   : SaveToFile: free stack after: 3408
16840 : Info   : SaveToFile: free stack: 3072
16850 : Info   : FILE : Saved security.dat offset: 1024 size: 128
16851 : Info   : SaveToFile: free stack after: 3072
RESET: Successful, rebooting. (you might need to press the reset button if you’ve just flashed the firmware)
17965 : Info   : Time set to 3020930607.000
17967 : Info   : Current Time Zone: STD time start: 2065-10-25 03:00:00 offset: 0 min
17970 : Info   : Local time: 2065-09-23 11:23:2ÿ
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU77 : Info   :
79 : Info   : INIT : Free RAM:32200
80 : Info   : INIT : Soft Reboot #3 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 3020930607 - Restart Reason: Software/System restart
82 : Info   : FS   : Mounting…
107 : Info   : FS   : Mount successful, used 75802 bytes of 957314
2319 : Info   : WiFi : Scan finished, found: 4
2321 : Info   : WiFi : Start network scan all channels
2430 : Info   : INIT : Free RAM:27944
2431 : Info   : INIT : I2C
2431 : Info   : INIT : SPI not enabled
2563 : Info   : Time set to 3020930607.000
2565 : Info   : Current Time Zone: STD time start: 2065-10-25 03:00:00 offset: 0 min
2568 : Info   : Local time: 2065-09-23 11:23:27
3910 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 21128 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4603 : Info   : WiFi : Scan finished, found: 2
4606 : Error  : WIFI : No valid wifi settings
4607 : Info   : WIFI : Set WiFi to AP+STA
5597 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
15237 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33921 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 17496 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
57575 : Info   : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
62723 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
63920 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 16944 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
85738 : Info   : WiFi : Start network scan all channels
87924 : Info   : WiFi : Scan finished, found: 4
93914 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 15936 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
108633 : Info   : SaveToFile: free stack: 3456
108704 : Info   : FILE : Saved config.dat offset: 0 size: 1296
108705 : Info   : SaveToFile: free stack after: 3456
108706 : Info   : SaveToFile: free stack: 3296
108739 : Info   : FILE : Saved security.dat offset: 0 size: 593
108740 : Info   : SaveToFile: free stack after: 3296
108742 : Info   : SaveToFile: free stack: 2960
108752 : Info   : FILE : Saved security.dat offset: 1024 size: 128
108752 : Info   : SaveToFile: free stack after: 2960
108754 : Info   : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
108757 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
108758 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #0
108764 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
110324 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1556 ms
110325 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
112336 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2012 ms
112339 : Info   : SaveToFile: free stack: 3216
112349 : Info   : FILE : Saved security.dat offset: 1024 size: 128
112350 : Info   : SaveToFile: free stack after: 3216
112352 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
112407 : Info   : firstLoopConnectionsEstablished
121012 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
121013 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
121026 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12264 ms
121027 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
123903 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 15368 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
123904 : Info   : WiFi : Start network scan all channels
124008 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2883 ms
124111 : Info   : WIFI : Set WiFi to OFF
124326 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
124329 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
124330 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #1
124433 : Info   : WIFI : Set WiFi to STA
124592 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
124606 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
124607 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #2
124611 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
125620 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 997 ms
125621 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
127615 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2005 ms
127617 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
136277 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
136278 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
136303 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11686 ms
136304 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
137177 : Info   : WiFi : Start network scan all channels
137180 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
137281 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 884 ms
137384 : Info   : WIFI : Set WiFi to OFF
137598 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
137600 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
137601 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #3
137705 : Info   : WIFI : Set WiFi to STA
137863 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
137877 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
137878 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #4
137882 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
139726 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1829 ms
139727 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
141526 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1814 ms
141528 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
150224 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
150225 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
150249 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12350 ms
150249 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
151124 : Info   : WiFi : Start network scan all channels
151126 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
151228 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 896 ms
151331 : Info   : WIFI : Set WiFi to OFF
151545 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
151547 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
151548 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #5
151652 : Info   : WIFI : Set WiFi to STA
151821 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
151835 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
151836 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #6
151840 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
152849 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1000 ms
152850 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
152909 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 63 ms
152911 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
153904 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 18840 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
161571 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8632 ms
161572 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
161585 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 9746 ms
161586 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
162471 : Info   : WiFi : Start network scan all channels
162473 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
162575 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 890 ms
162678 : Info   : WIFI : Set WiFi to OFF
162892 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
162894 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
162895 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #7
162999 : Info   : WIFI : Set WiFi to STA
163158 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
163172 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
163173 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #8
163177 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
164185 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 999 ms
164186 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
164312 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 130 ms
164314 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
172892 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8616 ms
172893 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
172906 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 9724 ms
172907 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
173791 : Info   : WiFi : Start network scan all channels
173793 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
173896 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 895 ms
173999 : Info   : WIFI : Set WiFi to OFF
174213 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
174215 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
174216 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #9
174320 : Info   : WIFI : Set WiFi to STA
174478 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
174492 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
174493 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #10
174497 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
175505 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1009 ms
175506 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
175598 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 89 ms
175600 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
183903 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 18840 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
184260 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8655 ms
184261 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
184286 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 9786 ms
184287 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
185160 : Info   : WiFi : Start network scan all channels
185162 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
185264 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 882 ms
185367 : Info   : WIFI : Set WiFi to OFF
185581 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
185583 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
185584 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #11
185688 : Info   : WIFI : Set WiFi to STA
185846 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
185860 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
185861 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #12
185865 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
187418 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1543 ms
187419 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
189025 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1615 ms
189027 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
197723 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
197724 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
197738 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11871 ms
197738 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
198623 : Info   : WiFi : Start network scan all channels
198625 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
198727 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 892 ms
198830 : Info   : WIFI : Set WiFi to OFF
199044 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
199046 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
199047 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #13
199151 : Info   : WIFI : Set WiFi to STA
199320 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
199334 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
199335 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #14
199339 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
200348 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1011 ms
200349 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
202325 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1975 ms
202327 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
210880 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
210881 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
210895 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11554 ms
210896 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
211780 : Info   : WiFi : Start network scan all channels
211783 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
211885 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 893 ms
211988 : Info   : WIFI : Set WiFi to OFF
212202 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
212204 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
212205 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #15
212309 : Info   : WIFI : Set WiFi to STA
212467 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
212481 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
212482 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #16
212487 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
213495 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 994 ms
213496 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
213916 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 19512 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
215511 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2025 ms
215513 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
224090 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
224091 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
224104 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11618 ms
224105 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
224990 : Info   : WiFi : Start network scan all channels
224992 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
225094 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 891 ms
225197 : Info   : WIFI : Set WiFi to OFF
225411 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
225413 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
225414 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #17
225518 : Info   : WIFI : Set WiFi to STA
225677 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
225691 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
225692 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #18
225696 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
226682 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 988 ms
226683 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
228715 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2031 ms
228717 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
237198 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
237199 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
237212 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11513 ms
237213 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
238097 : Info   : WiFi : Start network scan all channels
238099 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
238201 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 893 ms
238304 : Info   : WIFI : Set WiFi to OFF
238518 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
238520 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
238521 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #19
238625 : Info   : WIFI : Set WiFi to STA
238783 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
238797 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
238798 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #20
238802 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
239832 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1014 ms
239833 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
241822 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2000 ms
241824 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
243904 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 19872 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
250519 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
250520 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
250544 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11743 ms
250545 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
251419 : Info   : WiFi : Start network scan all channels
251422 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
251524 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 880 ms
251627 : Info   : WIFI : Set WiFi to OFF
251841 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
251843 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
251844 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #21
251948 : Info   : WIFI : Set WiFi to STA
252117 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
252130 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
252131 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #22
252135 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
253125 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 991 ms
253126 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
253208 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 77 ms
253210 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
273904 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 19368 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
303904 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 19368 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
333903 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 19368 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
333905 : Info   : WiFi : Start network scan all channels
363904 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 19368 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
I will try with a Wemos D1 as well.
Re: Latest versions crashes my NodeMCU
#24 Post by Ath » 08 Jun 2021, 09:00
Ath wrote: 07 Jun 2021, 16:39 Have you tried:
- A build with 'alt_wifi' in the name? (Uses a different Arduino Wifi setup)
- A build with 'beta' in the name? (Uses a beta release of the Arduino libraries)
Have you tried any of those builds? Especially the 'alt_wifi' I'd expect to have some effect in this area.
Tebogo
#25 Post by Tebogo » 08 Jun 2021, 09:15
Hereby the results flashing on a Wemos D1, same results.
218 : Info   : INIT : Booting version: ‘bugfix/wifi_not_reconnect_360b339’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
219 : Info   : INIT : Free RAM:32200
220 : Info   : INIT : Cold Boot - Restart Reason: External System
222 : Info   : FS   : Mounting…
458 : Info   : FS   : Mount successful, used 0 bytes of 957314
RESET: formatting…
7137 : Info   : SaveToFile: free stack: 3504
7196 : Info   : FILE : Saved config.dat offset: 28672 size: 820
7197 : Info   : SaveToFile: free stack after: 3504
7198 : Info   : SaveToFile: free stack: 3568
7268 : Info   : FILE : Saved config.dat offset: 0 size: 1296
7269 : Info   : SaveToFile: free stack after: 3568
7270 : Info   : SaveToFile: free stack: 3408
7303 : Info   : FILE : Saved security.dat offset: 0 size: 593
7304 : Info   : SaveToFile: free stack after: 3408
7306 : Info   : SaveToFile: free stack: 3072
7316 : Info   : FILE : Saved security.dat offset: 1024 size: 128
7317 : Info   : SaveToFile: free stack after: 3072
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU75 : Info   :
76 : Info   : INIT : Free RAM:32200
78 : Info   : INIT : Soft Reboot #1 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 8 - Restart Reason: Software/System restart
80 : Info   : FS   : Mounting…
104 : Info   : FS   : Mount successful, used 75802 bytes of 957314
125 : Info   : CRC  : SecuritySettings CRC   …OK
129 : Info   : WiFi : Start network scan all channels
2318 : Info   : WiFi : Scan finished, found: 6
2320 : Info   : WiFi : Start network scan all channels
2430 : Info   : INIT : Free RAM:27552
2432 : Info   : INIT : I2C
2432 : Info   : INIT : SPI not enabled
2557 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2564 : Info   : Webserver: start
2565 : Info   : Time set to 8.000 Time adjusted by 5435.00 msec. Wander: 1.51 msec/second
2567 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2569 : Info   : Local time: 1970-01-01 00:00:08
3909 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 20336 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4603 : Info   : WiFi : Scan finished, found: 8
4607 : Error  : WIFI : No valid wifi settings
33912 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 18184 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
36785 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
63912 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 16184 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
93905 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 16184 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
104830 : Info   : SaveToFile: free stack: 3456
104904 : Info   : FILE : Saved config.dat offset: 0 size: 1296
104905 : Info   : SaveToFile: free stack after: 3456
104906 : Info   : SaveToFile: free stack: 3296
104939 : Info   : FILE : Saved security.dat offset: 0 size: 593
104940 : Info   : SaveToFile: free stack after: 3296
104942 : Info   : SaveToFile: free stack: 2960
104952 : Info   : FILE : Saved security.dat offset: 1024 size: 128
104953 : Info   : SaveToFile: free stack after: 2960
104955 : Info   : WIFI : Credentials Changed, retry connection. SSID: FRITZ!Box 7490
104957 : Info   : WiFi : Best AP candidate: FRITZ!Box 7490 08:96:D7:84:7F:81 Ch:8 (-68dBm) WPA2/PSK
104959 : Info   : WIFI : Connecting FRITZ!Box 7490 08:96:D7:84:7F:81 Ch:8 (-68dBm) WPA2/PSK attempt #0
104964 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
105941 : Info   : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
110069 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5002 ms
110070 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
110970 : Info   : WiFi : Start network scan all channels
110974 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
111141 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
113174 : Info   : WiFi : Scan finished, found: 8
113177 : Info   : WiFi : Best AP candidate: FRITZ!Box 7490 08:96:D7:84:7F:81 Ch:8 (-69dBm) WPA2/PSK
123914 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 15560 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
123915 : Info   : WiFi : Start network scan all channels
126120 : Info   : WiFi : Scan finished, found: 7
126123 : Info   : WiFi : Best AP candidate: FRITZ!Box 7490 08:96:D7:84:7F:81 Ch:8 (-69dBm) WPA2/PSK
153910 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 15520 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
183909 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 15856 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
213910 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 15856 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
243908 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 16048 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
273906 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 16048 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
273907 : Info   : WiFi : Start network scan all channels
276106 : Info   : WiFi : Scan finished, found: 8
276109 : Info   : WiFi : Best AP candidate: FRITZ!Box 7490 08:96:D7:84:7F:81 Ch:8 (-68dBm) WPA2/PSK
303906 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 15984 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
333908 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 16072 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
363912 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 16224 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
393906 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 16224 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
423915 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 16224 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
423916 : Info   : WiFi : Start network scan all channels
426114 : Info   : WiFi : Scan finished, found: 8
426117 : Info   : WiFi : Best AP candidate: FRITZ!Box 7490 08:96:D7:84:7F:81 Ch:8 (-68dBm) WPA2/PSK
453914 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 16224 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
483906 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 16376 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
513909 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 16376 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
543906 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 16376 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
573907 : Info   : WD   : Uptime 10 ConnectFailures 0 FreeMem 16376 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
573908 : Info   : WiFi : Start network scan all channels
576106 : Info   : WiFi : Scan finished, found: 7
576109 : Info   : WiFi : Best AP candidate: FRITZ!Box 7490 08:96:D7:84:7F:81 Ch:8 (-68dBm) WPA2/PSK
603907 : Info   : WD   : Uptime 10 ConnectFailures 0 FreeMem 16264 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
633912 : Info   : WD   : Uptime 11 ConnectFailures 0 FreeMem 16264 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
663914 : Info   : WD   : Uptime 11 ConnectFailures 0 FreeMem 16264 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
693912 : Info   : WD   : Uptime 12 ConnectFailures 0 FreeMem 16264 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
Strange thing is, I do not have problems with these ESP's with other flash-firmware or other devices (iPhones, TV's, laptops, thermostats, Ikea hubs etc) on this Wifi.
Only with ESPEasy...
#26 Post by Ath » 08 Jun 2021, 09:37
Tebogo wrote: 08 Jun 2021, 09:15
RESET: formatting…
Why is your unit formatting the storage after each update? Do you flash an empty bin file on it before installing the update? It just seems very inconvenient to do that every time.
Tebogo
#27 Post by Tebogo » 08 Jun 2021, 11:58
Ath wrote: 08 Jun 2021, 09:37
RESET: formatting…
Formatting is normal behaviour at first boot as far a I know after reflashing your ESP. I always flash first with a blank bin file, to be sure nothing stays behind.
Is its inconvenient, but I don't think it will prevent formatting.
@TD, is this correct as I say?
#28 Post by Ath » 08 Jun 2021, 12:59
Well, I've used all kinds of builds, mostly during development, and I hardly ever flash an empty bin file, only if there are issues related to an up- or down-grade or if the partitioning is changed (hardly ever). It would waste quite a lot of testing time for me :?
Tebogo
#29 Post by Tebogo » 08 Jun 2021, 16:23
I flashed again, and without first flashing with blank.bin as Ath sugest.
It still formats, so does not make any difference in that. ;)
But, on the same spot in house as before and nothing changed, just a few hours later, the Wemos D1 works after this last reflash.
Even after reboot from its website: Tools/Reboot or with the rest button on the Wemos.
223 : Info   : INIT : Free RAM:32200
224 : Info   : INIT : Manual Reboot #3 Last Action before Reboot: Const Interval: TIMER_1SEC Last systime: 2448 - Restart Reason: External System
226 : Info   : FS   : Mounting…
462 : Info   : FS   : Mount successful, used 0 bytes of 957314
RESET: formatting…
7123 : Info   : SaveToFile: free stack: 3504
7182 : Info   : FILE : Saved config.dat offset: 28672 size: 820
7183 : Info   : SaveToFile: free stack after: 3504
7184 : Info   : SaveToFile: free stack: 3568
7254 : Info   : FILE : Saved config.dat offset: 0 size: 1296
7255 : Info   : SaveToFile: free stack after: 3568
7256 : Info   : SaveToFile: free stack: 3408
7289 : Info   : FILE : Saved security.dat offset: 0 size: 593
7290 : Info   : SaveToFile: free stack after: 3408
7292 : Info   : SaveToFile: free stack: 3072
7302 : Info   : FILE : Saved security.dat offset: 1024 size: 128
7303 : Info   : SaveToFile: free stack after: 3072
8417 : Info   : Time set to 2448.000 Time adjusted by 2439584.00 msec. Wander: 677.66 msec/second
8419 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 ÿ
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU75 : Info   :
78 : Info   : INIT : Soft Reboot #4 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 2448 - Restart Reason: Software/System restart
79 : Info   : FS   : Mounting…
2317 : Info   : WiFi : Scan finished, found: 9
2431 : Info   : INIT : Free RAM:27296
2558 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2565 : Info   : Time set to 2448.000 Time adjusted by 2445435.00 msec. Wander: 679.29 msec/second
2569 : Info   : Local time: 1970-01-01 00:40:48
3916 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 20416 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4611 : Info   : WiFi : Scan finished, found: 5
4614 : Error  : WIFI : No valid wifi settings
4615 : Info   : WIFI : Set WiFi to AP+STA
5605 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
24430 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33908 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 16152 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
63914 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 16208 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
84456 : Info   : SaveToFile: free stack: 3456
84528 : Info   : FILE : Saved config.dat offset: 0 size: 1296
84529 : Info   : SaveToFile: free stack after: 3456
84530 : Info   : SaveToFile: free stack: 3296
84562 : Info   : FILE : Saved security.dat offset: 0 size: 593
84563 : Info   : SaveToFile: free stack after: 3296
84565 : Info   : SaveToFile: free stack: 2960
84575 : Info   : FILE : Saved security.dat offset: 1024 size: 128
84575 : Info   : SaveToFile: free stack after: 2960
84577 : Info   : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
84580 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-61dBm) WPA2/PSK
84582 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-61dBm) WPA2/PSK attempt #0
84587 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
86589 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 2005 ms
86590 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
88177 : Info   : WIFI : DHCP IP: 10.187.1.123 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1582 ms
88180 : Info   : SaveToFile: free stack: 3216
88190 : Info   : FILE : Saved security.dat offset: 1024 size: 128
88191 : Info   : SaveToFile: free stack after: 3216
88194 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
88257 : Info   : firstLoopConnectionsEstablished
93904 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 15152 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
93906 : Error  : WiFi : Scan not needed, good candidate present
123904 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 14864 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
123906 : Error  : WiFi : Scan not needed, good candidate present
153905 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 15200 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
153906 : Error  : WiFi : Scan not needed, good candidate present
158384 : Info   :  Webserver args: 0: ‘cmd’ length: 6
158384 : Info   :      : Rebooting…
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU76 : Info   :
77 : Info   : INIT : Free RAM:32200
79 : Info   : INIT : Soft Reboot #5 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 2604 - Restart Reason: Software/System restart
81 : Info   : FS   : Mounting…
105 : Info   : FS   : Mount successful, used 75802 bytes of 957314
126 : Info   : CRC  : SecuritySettings CRC   …OK
130 : Info   : WiFi : Start network scan all channels
246 : Info   : INIT : Free RAM:27600
248 : Info   : INIT : I2C
248 : Info   : INIT : SPI not enabled
374 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
380 : Info   : Webserver: start
382 : Info   : Time set to 2604.000 Time adjusted by 2603619.00 msec. Wander: 723.23 msec/second
383 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
385 : Info   : Local time: 1970-01-01 00:43:24
1726 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 20864 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
2420 : Info   : WiFi : Scan finished, found: 8
2425 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-59dBm) WPA2/PSK
2426 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-59dBm) WPA2/PSK attempt #0
2432 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
3462 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1023 ms
3463 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
5423 : Info   : WIFI : DHCP IP: 10.187.1.123 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1964 ms
5425 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
5427 : Info   : firstLoopConnectionsEstablished
31721 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19184 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
31722 : Error  : WiFi : Scan not needed, good candidate present
61721 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 18344 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
61722 : Error  : WiFi : Scan not needed, good candidate present
85947 : Info   :  Webserver args: 0: ‘cmd’ length: 6
85947 : Info   :      : Rebooting…
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU77 : Info   :
78 : Info   : INIT : Free RAM:32200
79 : Info   : INIT : Soft Reboot #6 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 2689 - Restart Reason: Software/System restart
106 : Info   : FS   : Mount successful, used 75802 bytes of 957314
127 : Info   : CRC  : SecuritySettings CRC   …OK
131 : Info   : WiFi : Start network scan all channels
382 : Info   : Time set to 2689.000 Time adjusted by 2688619.00 msec. Wander: 746.84 msec/second
386 : Info   : Local time: 1970-01-01 00:44:49
2431 : Info   : WiFi : Scan finished, found: 8
2435 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-58dBm) WPA2/PSK
2437 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-58dBm) WPA2/PSK attempt #0
2442 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
3495 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1043 ms
5422 : Info   : WIFI : DHCP IP: 10.187.1.123 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1938 ms
5424 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
5426 : Info   : firstLoopConnectionsEstablished
{l$ܟ|Œlà|Äläc|‚ä›sÛcŒ#Œûgožlo’œãìcpŒ‡ls${l8û’àƒlŒœ#nâ|äl‡Çc„òn’ç$Œd`˜’gd`os“Û’cd`sۛgbd`œc‡“l{“`üƒgœªU78 : Info   :
80 : Info   : INIT : Manual Reboot #7 Last Action before Reboot: Background Task Last systime: 2715 - Restart Reason: External System
128 : Info   : CRC  : SecuritySettings CRC   …OK
247 : Info   : INIT : Free RAM:27688
249 : Info   : INIT : SPI not enabled
375 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
381 : Info   : Webserver: start
383 : Info   : Time set to 2715.000 Time adjusted by 2714618.00 msec. Wander: 754.06 msec/second
384 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
386 : Info   : Local time: 1970-01-01 00:45:15
1727 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 21040 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
2423 : Info   : WiFi : Scan finished, found: 7
2427 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-59dBm) WPA2/PSK
2429 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-59dBm) WPA2/PSK attempt #0
2434 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
3446 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1004 ms
3447 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
5425 : Info   : WIFI : DHCP IP: 10.187.1.123 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1982 ms
5427 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
5429 : Info   : firstLoopConnectionsEstablished
And even after disconnecting power:
5419 : Info   : WIFI : DHCP IP: 10.187.1.123 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1971 ms
5420 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
5422 : Info   : firstLoopConnectionsEstablished
I, will try now, on the same spot the two ESP8266. keep you informed
Tebogo
#30 Post by Tebogo » 08 Jun 2021, 16:53
On the first ESP :(
292 : Info   : INIT : Booting version: ‘bugfix/wifi_not_reconnect_360b339’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
293 : Info   : INIT : Free RAM:32200
295 : Info   : INIT : Manual Reboot #1 Last Action before Reboot: Background Task Last systime: 25 - Restart Reason: External System
296 : Info   : FS   : Mounting…
6943 : Info   : FS   : Mount successful, used 0 bytes of 957314
RESET: formatting…
16540 : Info   : SaveToFile: free stack: 3504
16599 : Info   : FILE : Saved config.dat offset: 28672 size: 820
16600 : Info   : SaveToFile: free stack after: 3504
16601 : Info   : SaveToFile: free stack: 3568
16670 : Info   : FILE : Saved config.dat offset: 0 size: 1296
16671 : Info   : SaveToFile: free stack after: 3568
16672 : Info   : SaveToFile: free stack: 3408
16705 : Info   : FILE : Saved security.dat offset: 0 size: 593
16705 : Info   : SaveToFile: free stack after: 3408
16708 : Info   : SaveToFile: free stack: 3072
16718 : Info   : FILE : Saved security.dat offset: 1024 size: 128
16718 : Info   : SaveToFile: free stack after: 3072
17833 : Info   : Time set to 25.000 Time adjusted by 7168.00 msec. Wander: 1.99 msec/second
17835 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offseÿ
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU75 : Info   :
78 : Info   : INIT : Soft Reboot #2 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 25 - Restart Reason: Software/System restart
2316 : Info   : WiFi : Scan finished, found: 4
2318 : Info   : WiFi : Start network scan all channels
2427 : Info   : INIT : Free RAM:27904
2428 : Info   : INIT : I2C
2429 : Info   : INIT : SPI not enabled
2553 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2559 : Info   : Webserver: start
2560 : Info   : Time set to 25.000 Time adjusted by 22441.00 msec. Wander: 6.23 msec/second
2562 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2564 : Info   : Local time: 1970-01-01 00:00:25
3904 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 21128 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4598 : Info   : WiFi : Scan finished, found: 2
4601 : Error  : WIFI : No valid wifi settings
4602 : Info   : WIFI : Set WiFi to AP+STA
5592 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
20477 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33912 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 16016 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
63908 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 15848 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
87808 : Info   : SaveToFile: free stack: 3456
87882 : Info   : FILE : Saved config.dat offset: 0 size: 1296
87883 : Info   : SaveToFile: free stack after: 3456
87884 : Info   : SaveToFile: free stack: 3296
87916 : Info   : FILE : Saved security.dat offset: 0 size: 593
87917 : Info   : SaveToFile: free stack after: 3296
87918 : Info   : SaveToFile: free stack: 2960
87928 : Info   : FILE : Saved security.dat offset: 1024 size: 128
87929 : Info   : SaveToFile: free stack after: 2960
87931 : Info   : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
87934 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
87935 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #0
87941 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
89590 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1640 ms
89591 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
91153 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1571 ms
91156 : Info   : SaveToFile: free stack: 3216
91166 : Info   : FILE : Saved security.dat offset: 1024 size: 128
91167 : Info   : SaveToFile: free stack after: 3216
91168 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
91220 : Info   : firstLoopConnectionsEstablished
93899 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 15176 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
93901 : Error  : WiFi : Scan not needed, good candidate present
99636 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9958 ms
99637 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
100408 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12466 ms
100409 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
123899 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 15176 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
153899 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 15344 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
153900 : Info   : WiFi : Start network scan all channels
154004 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 53 s
154005 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
156102 : Info   : WiFi : Scan finished, found: 4
156104 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK
183911 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 16528 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
213919 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 16528 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
243917 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 16528 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
273919 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 16528 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
303915 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 16528 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
303916 : Info   : WiFi : Start network scan all channels
306115 : Info   : WiFi : Scan finished, found: 2
306117 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK
333915 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 16616 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
363916 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 16616 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
393914 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 16616 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
404474 : Info   : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
404477 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-68dBm) WPA2/PSK
404478 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-68dBm) WPA2/PSK attempt #1
404483 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
404597 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 117 ms
404598 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
406158 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1556 ms
406159 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
407933 : Info   : WIFI : Set WiFi to STA
416665 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 11 s
416665 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
416679 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12195 ms
416680 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
417564 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-90dBm) WPA2/PSK attempt #2
417569 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
419489 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1813 ms
419591 : Info   : WIFI : Set WiFi to OFF
419805 : Info   : WiFi : Start network scan all channels
421992 : Info   : WiFi : Scan finished, found: 3
421994 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
421995 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
421997 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #3
422003 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
423044 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1026 ms
423045 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
423911 : Info   : WD   : Uptime 7 ConnectFailures 0 FreeMem 19704 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
425021 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1988 ms
425023 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
433457 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
433458 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
433471 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11469 ms
433472 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
434357 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #4
434362 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
437256 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2781 ms
437359 : Info   : WIFI : Set WiFi to OFF
437573 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
437575 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
437576 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #5
437680 : Info   : WIFI : Set WiFi to STA
437839 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
437853 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #6
437857 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
439948 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 2079 ms
439949 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
441806 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1864 ms
441807 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
450468 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
450469 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
450866 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 13008 ms
450867 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
451368 : Info   : WiFi : Start network scan all channels
451372 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
451475 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 509 ms
451578 : Info   : WIFI : Set WiFi to OFF
451792 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
451794 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
451796 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #7
451899 : Info   : WIFI : Set WiFi to STA
452058 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
452072 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #8
452076 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
453961 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 20192 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
454103 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 2011 ms
454104 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
455924 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1833 ms
455925 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
464587 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
464588 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
464854 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 12779 ms
464855 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
465487 : Info   : WiFi : Start network scan all channels
465491 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
465594 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 638 ms
465697 : Info   : WIFI : Set WiFi to OFF
465911 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
465913 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
465914 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #9
466018 : Info   : WIFI : Set WiFi to STA
466177 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
466191 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #10
466195 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
467376 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1184 ms
467377 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
469229 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1850 ms
469231 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
477789 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
477790 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
478699 : Info   : WiFi : Start network scan all channels
478703 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
480893 : Info   : WiFi : Scan finished, found: 2
480896 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
480899 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #11
480905 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
481958 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1047 ms
481959 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
483906 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1952 ms
483908 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
483910 : Info   : WD   : Uptime 8 ConnectFailures 0 FreeMem 19704 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
483911 : Error  : WiFi : Scan not needed, good candidate present
492439 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
492440 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
493333 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12424 ms
493333 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
493339 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-91dBm) WPA2/PSK attempt #12
493344 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
495556 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 2107 ms
495658 : Info   : WIFI : Set WiFi to OFF
495872 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
495874 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
495875 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #13
495979 : Info   : WIFI : Set WiFi to STA
496174 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
496187 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-91dBm) WPA2/PSK attempt #14
496191 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
497329 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1139 ms
497330 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
497398 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 69 ms
497400 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
506071 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8642 ms
506072 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
506372 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 10175 ms
506373 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
506970 : Info   : WiFi : Start network scan all channels
506975 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
507077 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 611 ms
507180 : Info   : WIFI : Set WiFi to OFF
507394 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
507396 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
507397 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #15
507501 : Info   : WIFI : Set WiFi to STA
507660 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
507673 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-91dBm) WPA2/PSK attempt #16
507677 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
509525 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1837 ms
509526 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
511327 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1814 ms
511329 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
513900 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 19808 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
519990 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
519991 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
520292 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 12609 ms
520293 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
520889 : Info   : WiFi : Start network scan all channels
520894 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
520996 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 610 ms
521099 : Info   : WIFI : Set WiFi to OFF
521313 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
521316 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
521317 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #17
521420 : Info   : WIFI : Set WiFi to STA
521579 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
521593 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-91dBm) WPA2/PSK attempt #18
521597 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
522776 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1167 ms
522777 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
524586 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1823 ms
524588 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
533187 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
533188 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
534097 : Info   : WiFi : Start network scan all channels
534101 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
534215 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 11 s
534216 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
536295 : Info   : WiFi : Scan finished, found: 3
536297 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
536300 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #19
536306 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
537337 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1028 ms
537338 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
539295 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1960 ms
539296 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
543900 : Info   : WD   : Uptime 9 ConnectFailures 0 FreeMem 19528 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
543901 : Error  : WiFi : Scan not needed, good candidate present
547837 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
547838 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
547853 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11550 ms
547854 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
548737 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-91dBm) WPA2/PSK attempt #20
548742 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
550547 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1703 ms
550649 : Info   : WIFI : Set WiFi to OFF
550863 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
550865 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
550867 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #21
550970 : Info   : WIFI : Set WiFi to STA
551129 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
551143 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-91dBm) WPA2/PSK attempt #22
551147 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
552674 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1527 ms
552675 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
554520 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1847 ms
554522 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
562882 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
562883 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
563792 : Info   : WiFi : Start network scan all channels
563795 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
565994 : Info   : WiFi : Scan finished, found: 2
565997 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
566000 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #23
566006 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
567121 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1119 ms
567122 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
569029 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1901 ms
569031 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
573901 : Info   : WD   : Uptime 10 ConnectFailures 0 FreeMem 19528 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
573902 : Error  : WiFi : Scan not needed, good candidate present
577543 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
577544 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
577557 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11548 ms
577558 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
578432 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-92dBm) WPA2/PSK attempt #24
578437 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
580265 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1716 ms
580367 : Info   : WIFI : Set WiFi to OFF
580581 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
580583 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
580584 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #25
580688 : Info   : WIFI : Set WiFi to STA
580883 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
580896 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-92dBm) WPA2/PSK attempt #26
580900 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
582122 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1205 ms
582123 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
583924 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1813 ms
583926 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
592598 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
592599 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
593502 : Info   : WiFi : Start network scan all channels
593506 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
593619 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 11 s
593620 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
595700 : Info   : WiFi : Scan finished, found: 5
595702 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK
595705 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK attempt #27
595711 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
596762 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1052 ms
596763 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
598719 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1952 ms
598720 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
603900 : Info   : WD   : Uptime 10 ConnectFailures 0 FreeMem 19440 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
603901 : Error  : WiFi : Scan not needed, good candidate present
607229 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
607230 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
607986 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12272 ms
607987 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
608129 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-89dBm) WPA2/PSK attempt #28
608134 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
610618 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 2371 ms
610720 : Info   : WIFI : Set WiFi to OFF
610934 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
610936 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK
610937 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK attempt #29
611041 : Info   : WIFI : Set WiFi to STA
611199 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
611213 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-89dBm) WPA2/PSK attempt #30
611217 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
612406 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1170 ms
612407 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
618212 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 5819 ms
618214 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
626780 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 14 s
626781 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
627689 : Info   : WiFi : Start network scan all channels
627692 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
629892 : Info   : WiFi : Scan finished, found: 2
629894 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK
629897 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK attempt #31
629903 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
630936 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1025 ms
630936 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
632891 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1967 ms
632893 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
633900 : Info   : WD   : Uptime 11 ConnectFailures 0 FreeMem 19616 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
633901 : Error  : WiFi : Scan not needed, good candidate present
641225 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
641226 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
641261 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11351 ms
641262 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
642125 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-89dBm) WPA2/PSK attempt #32
642130 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
643692 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1451 ms
643794 : Info   : WIFI : Set WiFi to OFF
644008 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
644010 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK
644011 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK attempt #33
644115 : Info   : WIFI : Set WiFi to STA
644273 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
644287 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-89dBm) WPA2/PSK attempt #34
644291 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
645470 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1175 ms
645471 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
647303 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1834 ms
647304 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
655965 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
655966 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
656865 : Info   : WiFi : Start network scan all channels
656868 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
659068 : Info   : WiFi : Scan finished, found: 2
659070 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
659072 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #35
659078 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
660173 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1080 ms
660174 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
662069 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1911 ms
662071 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
663899 : Info   : WD   : Uptime 11 ConnectFailures 0 FreeMem 19264 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
663901 : Error  : WiFi : Scan not needed, good candidate present
670410 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
670410 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
670445 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11353 ms
670446 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
671310 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-89dBm) WPA2/PSK attempt #36
671314 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
674105 : Info   : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2688 ms
674208 : Info   : WIFI : Set WiFi to OFF
674422 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
674424 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
674426 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #37
674529 : Info   : WIFI : Set WiFi to STA
674688 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
674702 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-89dBm) WPA2/PSK attempt #38
674706 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
676775 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 2069 ms
676776 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
678619 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1842 ms
678621 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
687093 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
687094 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
687995 : Info   : WiFi : Start network scan all channels
687999 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
688112 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 11 s
688113 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
690192 : Info   : WiFi : Scan finished, found: 3
690195 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
690198 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #39
690204 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
691350 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1139 ms
691351 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
693296 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1953 ms
693298 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
693900 : Info   : WD   : Uptime 12 ConnectFailures 0 FreeMem 19336 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
693901 : Error  : WiFi : Scan not needed, good candidate present
701743 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
701744 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
702495 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12294 ms
702496 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
702643 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #40
702647 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
704940 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 2189 ms
705042 : Info   : WIFI : Set WiFi to OFF
705256 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
705258 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
705259 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #41
705363 : Info   : WIFI : Set WiFi to STA
705558 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
705571 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #42
705575 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
706797 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1224 ms
706798 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
708565 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1767 ms
708566 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
717237 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
717238 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
717799 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 12223 ms
717800 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
718137 : Info   : WiFi : Start network scan all channels
718141 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
718244 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 345 ms
718347 : Info   : WIFI : Set WiFi to OFF
718561 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
718563 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
718564 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #43
718668 : Info   : WIFI : Set WiFi to STA
718826 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
718840 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #44
718844 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
720089 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1239 ms
720090 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
721863 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1774 ms
721864 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
723900 : Info   : WD   : Uptime 12 ConnectFailures 0 FreeMem 19720 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
730525 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
730526 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
730803 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 11956 ms
730804 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
731425 : Info   : WiFi : Start network scan all channels
731429 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: Conn.
731531 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 631 ms
731634 : Info   : WIFI : Set WiFi to OFF
731848 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
731851 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
731852 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #45
731956 : Info   : WIFI : Set WiFi to STA
732114 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
732128 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #46
732132 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
733333 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1188 ms
733334 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
735158 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1834 ms
735160 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
743719 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
743720 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
744629 : Info   : WiFi : Start network scan all channels
744632 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
746832 : Info   : WiFi : Scan finished, found: 2
746834 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-68dBm) WPA2/PSK
746837 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-68dBm) WPA2/PSK attempt #47
746843 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
747896 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1056 ms
747897 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
749860 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1955 ms
749861 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
753900 : Info   : WD   : Uptime 13 ConnectFailures 0 FreeMem 19440 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
753901 : Error  : WiFi : Scan not needed, good candidate present
758374 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
758375 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
759220 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12380 ms
759221 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
759273 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #48
759278 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
760904 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1528 ms
761006 : Info   : WIFI : Set WiFi to OFF
761221 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
761223 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-68dBm) WPA2/PSK
761224 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-68dBm) WPA2/PSK attempt #49
761328 : Info   : WIFI : Set WiFi to STA
761486 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
761500 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-88dBm) WPA2/PSK attempt #50
761504 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
762685 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1178 ms
762686 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
764507 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1824 ms
764509 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
772903 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
772904 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
773803 : Info   : WiFi : Start network scan all channels
773808 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
773922 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 11 s
773922 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
776006 : Info   : WiFi : Scan finished, found: 3
776008 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
776011 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #51
776017 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
778066 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 2050 ms
778067 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
780009 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1939 ms
780011 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
783899 : Info   : WD   : Uptime 13 ConnectFailures 0 FreeMem 19144 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
783901 : Error  : WiFi : Scan not needed, good candidate present
788475 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
788475 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
788524 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12502 ms
788525 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
789375 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-89dBm) WPA2/PSK attempt #52
789379 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
791186 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1704 ms
791288 : Info   : WIFI : Set WiFi to OFF
791502 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
791504 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
791505 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #53
791609 : Info   : WIFI : Set WiFi to STA
791803 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
791817 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-89dBm) WPA2/PSK attempt #54
791821 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
792958 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1128 ms
792959 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
794836 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1882 ms
794837 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
803417 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
803418 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
804322 : Info   : WiFi : Start network scan all channels
804325 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
804438 : Info   : WIFI : Disconnected! Reason: ‘(203) Assoc fail’ Connected for 11 s
804439 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
806518 : Info   : WiFi : Scan finished, found: 3
806520 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-68dBm) WPA2/PSK
806523 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-68dBm) WPA2/PSK attempt #55
806529 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
807653 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1125 ms
807654 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
809600 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 1949 ms
809602 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
813900 : Info   : WD   : Uptime 14 ConnectFailures 0 FreeMem 19616 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
813901 : Error  : WiFi : Scan not needed, good candidate present
Tebogo
Re: Latest versions crashes my NodeMCU
#31 Post by Tebogo » 08 Jun 2021, 23:04
Second ESP, same result :|
284 : Info   :
286 : Info   : INIT : Free RAM:32200
287 : Info   : INIT : Manual Reboot #3 Last Action before Reboot: Const Interval: TIMER_20MSEC Last systime: 606 - Restart Reason: External System
289 : Info   : FS   : Mounting…
6875 : Info   : FS   : Mount successful, used 0 bytes of 957314
RESET: Resetting factory defaults… using default settings
RESET: Warm boot, reset count: 1
RESET: formatting…
RESET: formatting done…
16408 : Info   : SaveToFile: free stack: 3504
16467 : Info   : FILE : Saved config.dat offset: 28672 size: 820
16467 : Info   : SaveToFile: free stack after: 3504
16468 : Info   : SaveToFile: free stack: 3568
16538 : Info   : FILE : Saved config.dat offset: 0 size: 1296
16539 : Info   : SaveToFile: free stack after: 3568
16540 : Info   : SaveToFile: free stack: 3408
16572 : Info   : FILE : Saved security.dat offset: 0 size: 593
16573 : Info   : SaveToFile: free stack after: 3408
16575 : Info   : SaveToFile: free stack: 3072
16585 : Info   : FILE : Saved security.dat offset: 1024 size: 128
16586 : Info   : SaveToFile: free stack after: 3072
RESET: Successful, rebooting. (you might need to press the reset button if you’ve just flashed the firmware)
17700 : Info   : Time set to 606.000 Time adjusted by 588300.00 msec. Wander: 163.42 msec/second
17702 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 ÿ
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU77 : Info   :
79 : Info   : INIT : Soft Reboot #4 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 606 - Restart Reason: Software/System restart
2318 : Info   : WiFi : Scan finished, found: 3
2320 : Info   : WiFi : Start network scan all channels
2429 : Info   : INIT : Free RAM:27992
2431 : Info   : INIT : I2C
2431 : Info   : INIT : SPI not enabled
2554 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2561 : Info   : Time set to 606.000 Time adjusted by 603440.00 msec. Wander: 167.62 msec/second
2565 : Info   : Local time: 1970-01-01 00:10:06
3905 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 21128 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4600 : Info   : WiFi : Scan finished, found: 3
4603 : Error  : WIFI : No valid wifi settings
4603 : Info   : WIFI : Set WiFi to AP+STA
5593 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
26105 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33906 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 16032 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
49171 : Info   : SaveToFile: free stack: 3456
49242 : Info   : FILE : Saved config.dat offset: 0 size: 1296
49243 : Info   : SaveToFile: free stack after: 3456
49244 : Info   : SaveToFile: free stack: 3296
49276 : Info   : FILE : Saved security.dat offset: 0 size: 593
49277 : Info   : SaveToFile: free stack after: 3296
49279 : Info   : SaveToFile: free stack: 2960
49289 : Info   : FILE : Saved security.dat offset: 1024 size: 128
49289 : Info   : SaveToFile: free stack after: 2960
49291 : Info   : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
49294 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
49295 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #0
49301 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
51281 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1085 ms
51282 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
52396 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2006 ms
52399 : Info   : SaveToFile: free stack: 3216
52409 : Info   : FILE : Saved security.dat offset: 1024 size: 128
52410 : Info   : SaveToFile: free stack after: 3216
52412 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
52474 : Info   : firstLoopConnectionsEstablished
61079 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
61080 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
61093 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11793 ms
61094 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
63900 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 15360 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
63901 : Info   : WiFi : Start network scan all channels
64005 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2814 ms
64108 : Info   : WIFI : Set WiFi to OFF
64323 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
64326 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
64327 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #1
64431 : Info   : WIFI : Set WiFi to STA
64587 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
64600 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-84dBm) WPA2/PSK attempt #2
64605 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
65740 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1135 ms
65741 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
65821 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 79 ms
65822 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
74226 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8388 ms
74227 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
75135 : Info   : WiFi : Start network scan all channels
75138 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
75251 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 9401 ms
75252 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
77330 : Info   : WiFi : Scan finished, found: 4
77332 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
77335 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #3
77341 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79079 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1736 ms
79080 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
81086 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2012 ms
81088 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
89531 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
89532 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
90291 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12953 ms
90292 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
90431 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-86dBm) WPA2/PSK attempt #4
90436 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
92175 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1641 ms
92277 : Info   : WIFI : Set WiFi to OFF
92491 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
92493 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
92494 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #5
92598 : Info   : WIFI : Set WiFi to STA
92755 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
92769 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-86dBm) WPA2/PSK attempt #6
92773 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
93919 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 19088 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
93974 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1199 ms
93975 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
97771 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 3798 ms
97773 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
106277 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 12 s
106278 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
107184 : Info   : WiFi : Start network scan all channels
107187 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
109386 : Info   : WiFi : Scan finished, found: 4
109388 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
109391 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #7
109397 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
110406 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1006 ms
110407 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
112410 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2004 ms
112412 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
120967 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
120968 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
120982 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11584 ms
120982 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
121867 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-85dBm) WPA2/PSK attempt #8
121872 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
123527 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1545 ms
123629 : Info   : WIFI : Set WiFi to OFF
123843 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
123845 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
123846 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #9
123950 : Info   : WIFI : Set WiFi to STA
124107 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
124121 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-85dBm) WPA2/PSK attempt #10
124125 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
124180 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 19088 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
125304 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1175 ms
125305 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
129140 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 3834 ms
129142 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
137612 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 12 s
137613 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
138511 : Info   : WiFi : Start network scan all channels
138516 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
138629 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 13 s
138630 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
140705 : Info   : WiFi : Scan finished, found: 3
140707 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
140710 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #11
140716 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
143010 : Info   : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2196 ms
143112 : Info   : WIFI : Set WiFi to OFF
143326 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
143328 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-86dBm) WPA2/PSK attempt #12
143431 : Info   : WIFI : Set WiFi to STA
143624 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
143637 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
143639 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #13
143643 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
144652 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1009 ms
144653 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
146657 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 2001 ms
146659 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
153901 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 18768 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
153902 : Error  : WiFi : Scan not needed, good candidate present
155328 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
155329 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
155342 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11696 ms
155343 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
156226 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-86dBm) WPA2/PSK attempt #14
156231 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
157955 : Info   : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1606 ms
158057 : Info   : WIFI : Set WiFi to OFF
158271 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
158273 : Info   : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
158274 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #15
158378 : Info   : WIFI : Set WiFi to STA
158535 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
158548 : Info   : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-86dBm) WPA2/PSK attempt #16
158553 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
159688 : Info   : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1135 ms
159689 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
159748 : Info   : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0   duration: 56 ms
159749 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
183901 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 19232 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
I'll try another place in the house....
Same problem :|
Pulling my hair out...
#32 Post by TD-er » 09 Jun 2021, 00:04
Do you have several APs with the same SSID?
The TP-link Omada units I have here also react very strange on ESPs for example.
If I connect to "the other" one with the same SSID, it may take sometimes upto 10 seconds before it can actually send data after connecting.
Also the Omada unit may disconnect a unit if it receives notice from the other one that the other AP does also see the same unit but with a stronger signal.
I think we might need some more info here.
Can you also try to lower the TX power of the ESP node (if you get connected long enough)
https://espeasy.readthedocs.io/en/lates ... i-tx-power
Tebogo
#33 Post by Tebogo » 09 Jun 2021, 09:31
Yes, I do have a mesh of 8 x Linksys Velop multiroom Intelligent Mesh Wi-Fi-systeem, tri-band.
I'm very happy with that, never problems with al kind of devices, only ESP8266 with ESPEasy...
I'd like to change the TX. Can it be done over the serial connection? Which command?
In the web-interface I can access that, when it's in AP mode.
I use the link http://192.168.4.1/advanced
I tried lowering to 15 dBm, no result. Have to reflash again to do go in steps of 2,5 dBm lower.
Keep you informed!
#34 Post by TD-er » 09 Jun 2021, 10:08
You don't need to reflash it, you can also turn on AP via the serial command or just erase the wifi credentials via the serial command.
If you set the wifissid to "ssid" it will be considered as non-existing and then start the AP mode automatically.
Tebogo
#35 Post by Tebogo » 09 Jun 2021, 12:31
TD-er wrote: 09 Jun 2021, 10:08 You don't need to reflash it, you can also turn on AP via the serial command or just erase the wifi credentials via the serial command.
Thanks, that a lot easier!!
Now on 5 dBm, still no progress.
Update: on 0,5 dBm, no change. How low should I go?
#36 Post by TD-er » 09 Jun 2021, 12:54
The idea is to make the range of WiFi smaller, so other mesh nodes may not detect it.
I have the feeling the AP actively kicks off the ESP from it for a reason yet unknown to me.
A few reasons that I can come up with:
- Part of the 'mesh' algorithm to make sure the device reconnects to the strongest AP.
- May be related to received RSSI of the clients. Kick them to force them to reconnect.
- Maybe the AP does have some threshold in packet retransmits???
Either way, the current algorithm ESPEasy is using on when to reconnect looks to be completely counter-productive to whatever this mesh layer is trying to do.
Right now, I do create a number of potential APs to connect to.
Each time a client gets disconnected, I move to the next one.
On previous builds (before the last test build) I retried first to connect to the last one that was tried.
As I don't know what the reason behind this forced disconnecting is, I can only guess.
Do you have a separate AP to test, which does not have some mesh layer activated?
Just to make sure the WiFi part of the ESP is stable. (both hardware and ESPEasy)
Tebogo
#37 Post by Tebogo » 09 Jun 2021, 12:57
TD-er wrote: 09 Jun 2021, 12:54 Do you have a separate AP to test, which does not have some mesh layer activated?
No problem, I'll try that. I'm glad to help to solve this.
Tebogo
#38 Post by Tebogo » 09 Jun 2021, 15:09
Nope, same problem... only less logging, not continually switching between mesh-AP's
I think it got to do something with IP.
I have setup a Fritz-box, no mesh.
The ESP connects, gets a ip-adress, but never responds on ip-ping,
The Fritz-box has in the log the ESP has connected.
logging on the ESP:
76 : Info   : INIT : Booting version: ‘bugfix/wifi_not_reconnect_360b339’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
77 : Info   : INIT : Free RAM:32200
79 : Info   : INIT : External Watchdog #6 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 650 - Restart Reason: Hardware Watchdog
80 : Info   : FS   : Mounting…
105 : Info   : FS   : Mount successful, used 75802 bytes of 957314
126 : Info   : CRC  : SecuritySettings CRC   …OK
130 : Info   : WiFi : Start network scan all channels
2318 : Info   : WiFi : Scan finished, found: 7
2429 : Info   : INIT : Free RAM:27664
2430 : Info   : INIT : I2C
2430 : Info   : INIT : SPI not enabled
2555 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2561 : Info   : Webserver: start
2562 : Info   : Time set to 650.000 Time adjusted by 647438.00 msec. Wander: 179.84 msec/second
2564 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2566 : Info   : Local time: 1970-01-01 00:10:50
3913 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 20536 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4606 : Info   : WiFi : Scan finished, found: 5
4609 : Error  : WIFI : No valid wifi settings
4610 : Info   : WIFI : Set WiFi to AP+STA
5600 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
13463 : Info   : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33917 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 12648 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
67155 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 15472 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
93905 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 15472 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
95789 : Info   :  Webserver args: 0: ‘name’ length: 8 1: ‘unit’ length: 1 2: ‘appendunittohostname’ length: 2 3: ‘password’ length: 0 4: ‘ssid’ length: 14 5: ‘key’ length: 10 6: ‘ssid2’ length: 0 7: ‘key2’ length: 0 8: ‘apkey’ length: 5 9: ‘ipblocklevel’ length: 1 10: ‘iprangelow’ length: 0 11: ‘iprangehigh’ length: 0 12: ‘espip’ length: 0 13: ‘espgateway’ length: 0 14: ‘espsubnet’ length: 0 15: ‘espdns’ length: 0 16: ‘awaketime’ length: 1 17: ‘delay’ length: 2 18: ‘plain’ length: 213
95792 : Info   : SaveToFile: free stack: 3424
95872 : Info   : FILE : Saved config.dat offset: 0 size: 1296
95873 : Info   : SaveToFile: free stack after: 3424
95874 : Info   : SaveToFile: free stack: 3264
95910 : Info   : FILE : Saved security.dat offset: 0 size: 593
95911 : Info   : SaveToFile: free stack after: 3264
95913 : Info   : SaveToFile: free stack: 2928
95924 : Info   : FILE : Saved security.dat offset: 1024 size: 128
95925 : Info   : SaveToFile: free stack after: 2928
98705 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK
98707 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK attempt #0
98713 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
99667 : Info   : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
100741 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 2029 ms
100742 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
100921 : Info   : WIFI : DHCP IP: 192.168.1.23 (ESP-Easy) GW: 192.168.1.254 SN: 255.255.255.0   duration: 176 ms
100924 : Info   : SaveToFile: free stack: 3216
100934 : Info   : FILE : Saved security.dat offset: 1024 size: 128
100935 : Info   : SaveToFile: free stack after: 3216
100937 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
101032 : Info   : firstLoopConnectionsEstablished
109640 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8800 ms
109641 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
109767 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 11057 ms
109768 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
110539 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK
110540 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK attempt #1
110545 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
111734 : Info   : WIFI : DHCP IP: 192.168.1.23 (ESP-Easy) GW: 192.168.1.254 SN: 255.255.255.0
111735 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: IP
111738 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 0
111739 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
120266 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9624 ms
120267 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
121945 : Info   : WiFi : Start network scan all channels
121948 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
122061 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 11 s
122062 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
123913 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 14896 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
123915 : Info   : WiFi : Start network scan all channels
124143 : Info   : WiFi : Scan finished, found: 5
124146 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-69dBm) WPA2/PSK
124149 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-69dBm) WPA2/PSK attempt #2
124155 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
126121 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 1958 ms
126122 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
126158 : Info   : WIFI : DHCP IP: 192.168.1.23 (ESP-Easy) GW: 192.168.1.254 SN: 255.255.255.0   duration: 43 ms
126160 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
153902 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 14864 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
183902 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 14864 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
213902 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 15872 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
213903 : Info   : WiFi : Start network scan all channels
243902 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 15872 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
273902 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 15872 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
303901 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 15872 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
303903 : Info   : WiFi : Start network scan all channels
333902 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 15872 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
363902 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 16152 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
363903 : Info   : WiFi : Start network scan all channels
On the Fritzbox:
09.06.21 14:56:03 Netwerkapparaat naam: ESP-Easy, MAC: 60:01:94:5D:38:EA heeft verbinding gemaakt met de FRITZ!Box.
#39 Post by TD-er » 09 Jun 2021, 15:18
Hmm how is the Fritzbox configured?
Is it a 'repeater' like the 1750?
Or is it a router?
The simplest way should be to have it setup as a transparent bridge, not a router.
Can you make a simple sketch (or description) on how the subnets are setup?
Also what is the gateway (192.168.1.254 according to the ESP log) ?
Does your entire network have the same subnet?
If so, can you ping another device like your phone, connected to the Fritzbox?
Can 2 devices on the Fritzbox' WiFi ping each other? (Guest network of a Fritzbox often does not allow guests to ping to each other)
Tebogo
#40 Post by Tebogo » 09 Jun 2021, 16:49
The Fritz-box is my router to the internet. Normally I don't use the Wifi of the Fritz-box. Only switched on for these test results.
Hereby a schematic drawing of my network. In the Mesh-network is where all my devices live, normally also the ESP...
After setting the wifissid to ssid, I restarted the esp, set the wifissid in the terminal to FRITZ-BOX-5631 (password I didn't wiped, so no new setting)
See hereby the logging. At the end, the ESP get's a IP-adress, never responses on a ping. (ping started as soon as I set "save"in terminal
78 : Info   : INIT : Manual Reboot #9 Last Action before Reboot: Background Task Last systime: 6198 - Restart Reason: External System
104 : Info   : FS   : Mount successful, used 75802 bytes of 957314
185 : Info   : FS   : Success garbage collection
207 : Info   : CRC  : SecuritySettings CRC   …OK
211 : Info   : WiFi : Start network scan all channels
2398 : Info   : WiFi : Scan finished, found: 7
2400 : Info   : WiFi : Start network scan all channels
2509 : Info   : INIT : Free RAM:27592
2510 : Info   : INIT : I2C
2510 : Info   : INIT : SPI not enabled
2637 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2642 : Info   : Webserver: start
2644 : Info   : Time set to 6198.000 Time adjusted by 6195357.00 msec. Wander: 1720.93 msec/second
2645 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2648 : Info   : Local time: 1970-01-01 01:43:18
3985 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 20680 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4691 : Info   : WiFi : Scan finished, found: 3
4694 : Error  : WIFI : No valid wifi settings
4694 : Info   : WIFI : Set WiFi to AP+STA
5782 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
wifissid,FRITZ-Box-5631
Wifi SSID:FRITZ-Box-5631
Ok
save
>save
23623 : Info   : SaveToFile: free stack: 3392
23701 : Info   : FILE : Saved config.dat offset: 0 size: 1296
23702 : Info   : SaveToFile: free stack after: 3392
23703 : Info   : SaveToFile: free stack: 3232
23738 : Info   : FILE : Saved security.dat offset: 0 size: 593
23739 : Info   : SaveToFile: free stack after: 3232
23766 : Info   : SaveToFile: free stack: 2896
23777 : Info   : FILE : Saved security.dat offset: 1024 size: 128
23777 : Info   : SaveToFile: free stack after: 2896
Ok
23782 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK
23783 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK attempt #0
23789 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
26088 : Info   : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2194 ms
26190 : Info   : WIFI : Set WiFi to OFF
26405 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
26407 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK
26408 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK attempt #1
26512 : Info   : WIFI : Set WiFi to STA
26619 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
27631 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 1220 ms
27632 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
33983 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19840 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
43784 : Info   : WIFI : Set WiFi to AP+STA
43890 : Info   : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
restart52462 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 24 s
52463 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
53372 : Info   : WiFi : Start network scan all channels
53375 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
53488 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 25 s
53489 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
55566 : Info   : WiFi : Scan finished, found: 4
55569 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-73dBm) WPA2/PSK
55571 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-73dBm) WPA2/PSK attempt #2
55577 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
59830 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 4146 ms
59932 : Info   : WIFI : Set WiFi to OFF
60147 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
60149 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-73dBm) WPA2/PSK
60150 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-73dBm) WPA2/PSK attempt #3
60254 : Info   : WIFI : Set WiFi to STA
60362 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
60587 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 427 ms
60588 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
63983 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19840 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
>restart
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU
75 : Info   : INIT : Booting version: ‘bugfix/wifi_not_reconnect_360b339’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
76 : Info   : INIT : Free RAM:32200
77 : Info   : INIT : Soft Reboot #10 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 6259 - Restart Reason: Software/System restart
79 : Info   : FS   : Mounting…
324 : Info   : INIT : Free RAM:28216
326 : Info   : INIT : I2C
326 : Info   : INIT : SPI not enabled
453 : Info   : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
458 : Info   : Webserver: start
460 : Info   : Time set to 6259.000 Time adjusted by 6258541.00 msec. Wander: 1738.48 msec/second
461 : Info   : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
463 : Info   : Local time: 1970-01-01 01:44:19
1808 : Info   : WD   : Uptime 0 ConnectFailures 0 FreeMem 21248 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
2505 : Info   : WiFi : Scan finished, found: 3
2509 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
2510 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #0
2516 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
4563 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1949 ms
4666 : Info   : WIFI : Set WiFi to OFF
4880 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
4882 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
4884 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #1
4988 : Info   : WIFI : Set WiFi to STA
5096 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
5109 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
5111 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #2
5115 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
7651 : Info   : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 2427 ms
7754 : Info   : WIFI : Set WiFi to OFF
7968 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
7970 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
7971 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #3
8075 : Info   : WIFI : Set WiFi to STA
8183 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
8197 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
8198 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #4
8203 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
10234 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 2033 ms
10235 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
10307 : Info   : WIFI : DHCP IP: 192.168.1.23 (ESP-Easy) GW: 192.168.1.254 SN: 255.255.255.0   duration: 67 ms
10309 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
10405 : Info   : firstLoopConnectionsEstablished
19012 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8678 ms
19013 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
19919 : Info   : WiFi : Start network scan all channels
19924 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
20037 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 9691 ms
20038 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
22118 : Info   : WiFi : Scan finished, found: 7
22121 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
22124 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #5
22130 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
24182 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1950 ms
24285 : Info   : WIFI : Set WiFi to OFF
24499 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
24501 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
24502 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #6
24606 : Info   : WIFI : Set WiFi to STA
24814 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
24827 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
24828 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #7
24833 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
26078 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1142 ms
26181 : Info   : WIFI : Set WiFi to OFF
26395 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
26397 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
26398 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #8
26502 : Info   : WIFI : Set WiFi to STA
26610 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
26624 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK
26625 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-71dBm) WPA2/PSK attempt #9
26630 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
27641 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 1010 ms
27641 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
27681 : Info   : WIFI : DHCP IP: 192.168.1.23 (ESP-Easy) GW: 192.168.1.254 SN: 255.255.255.0   duration: 40 ms
27683 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
31799 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19512 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
36395 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8647 ms
36396 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37285 : Info   : WiFi : Start network scan all channels
37288 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37401 : Info   : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 9652 ms
37402 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
39484 : Info   : WiFi : Scan finished, found: 4
39487 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK
39489 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-72dBm) WPA2/PSK attempt #10
39495 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
40526 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 1022 ms
40527 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
46456 : Info   : WIFI : DHCP IP: 192.168.1.23 (ESP-Easy) GW: 192.168.1.254 SN: 255.255.255.0   duration: 5938 ms
46458 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
55012 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 14 s
55013 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
55915 : Info   : WiFi : Start network scan all channels
55920 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
56033 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 15 s
56034 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
58114 : Info   : WiFi : Scan finished, found: 5
58116 : Info   : WiFi : Best AP candidate: FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-70dBm) WPA2/PSK
58119 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (-70dBm) WPA2/PSK attempt #11
58125 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
58280 : Info   : WIFI : Connected! AP: FRITZ-Box-5631 (44:4E:6D:F9:0C:BD) Ch: 11 Duration: 142 ms
58281 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
58318 : Info   : WIFI : DHCP IP: 192.168.1.23 (ESP-Easy) GW: 192.168.1.254 SN: 255.255.255.0   duration: 48 ms
58320 : Info   : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
61798 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19512 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
91799 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 19008 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
And here the ping results from my MacBook (192.168.1.24):
ping 192.168.1.23
PING 192.168.1.23 (192.168.1.23): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
Request timeout for icmp_seq 7
ping: sendto: No route to host
Request timeout for icmp_seq 8
ping: sendto: Host is down
Request timeout for icmp_seq 9
Request timeout for icmp_seq 10
Request timeout for icmp_seq 11
Request timeout for icmp_seq 12
Request timeout for icmp_seq 13
Request timeout for icmp_seq 14
Request timeout for icmp_seq 15
Request timeout for icmp_seq 16
Request timeout for icmp_seq 17
Request timeout for icmp_seq 18
Request timeout for icmp_seq 19
Request timeout for icmp_seq 20
Request timeout for icmp_seq 21
Request timeout for icmp_seq 22
Request timeout for icmp_seq 23
Request timeout for icmp_seq 24
Request timeout for icmp_seq 25
Request timeout for icmp_seq 26
Request timeout for icmp_seq 27
Request timeout for icmp_seq 28
Request timeout for icmp_seq 29
Request timeout for icmp_seq 30
Request timeout for icmp_seq 31
Request timeout for icmp_seq 32
Request timeout for icmp_seq 33
Request timeout for icmp_seq 34
Request timeout for icmp_seq 35
Request timeout for icmp_seq 36
Request timeout for icmp_seq 37
Request timeout for icmp_seq 38
Request timeout for icmp_seq 39
Request timeout for icmp_seq 40
Request timeout for icmp_seq 41
Request timeout for icmp_seq 42
Request timeout for icmp_seq 43
Request timeout for icmp_seq 44
Request timeout for icmp_seq 45
Request timeout for icmp_seq 46
Request timeout for icmp_seq 47
Request timeout for icmp_seq 48
Request timeout for icmp_seq 49
Request timeout for icmp_seq 50
Request timeout for icmp_seq 51
Request timeout for icmp_seq 52
Request timeout for icmp_seq 53
Request timeout for icmp_seq 54
Request timeout for icmp_seq 55
Request timeout for icmp_seq 56
Request timeout for icmp_seq 57
Request timeout for icmp_seq 58
Request timeout for icmp_seq 59
Request timeout for icmp_seq 60
Request timeout for icmp_seq 61
Request timeout for icmp_seq 62
Request timeout for icmp_seq 63
Request timeout for icmp_seq 64
Request timeout for icmp_seq 65
Request timeout for icmp_seq 66
Request timeout for icmp_seq 67
Request timeout for icmp_seq 68
Request timeout for icmp_seq 69
Request timeout for icmp_seq 70
Request timeout for icmp_seq 71
Request timeout for icmp_seq 72
Request timeout for icmp_seq 73
Request timeout for icmp_seq 74
Request timeout for icmp_seq 75
Request timeout for icmp_seq 76
Request timeout for icmp_seq 77
Request timeout for icmp_seq 78
Request timeout for icmp_seq 79
Request timeout for icmp_seq 80
Request timeout for icmp_seq 81
Request timeout for icmp_seq 82
Request timeout for icmp_seq 83
Request timeout for icmp_seq 84
Request timeout for icmp_seq 85
Request timeout for icmp_seq 86
Request timeout for icmp_seq 87
Request timeout for icmp_seq 88
Request timeout for icmp_seq 89
Request timeout for icmp_seq 90
Request timeout for icmp_seq 91
Request timeout for icmp_seq 92
Request timeout for icmp_seq 93
Request timeout for icmp_seq 94
Request timeout for icmp_seq 95
Request timeout for icmp_seq 96
Request timeout for icmp_seq 97
Request timeout for icmp_seq 98
Request timeout for icmp_seq 99
Request timeout for icmp_seq 100
Request timeout for icmp_seq 101
Request timeout for icmp_seq 102
Request timeout for icmp_seq 103
Request timeout for icmp_seq 104
Request timeout for icmp_seq 105
Request timeout for icmp_seq 106
Request timeout for icmp_seq 107
Request timeout for icmp_seq 108
Request timeout for icmp_seq 109
Request timeout for icmp_seq 110
Request timeout for icmp_seq 111
Request timeout for icmp_seq 112
Request timeout for icmp_seq 113
Request timeout for icmp_seq 114
Request timeout for icmp_seq 115
Request timeout for icmp_seq 116
Request timeout for icmp_seq 117
Request timeout for icmp_seq 118
Request timeout for icmp_seq 119
Request timeout for icmp_seq 120
Request timeout for icmp_seq 121
Request timeout for icmp_seq 122
Request timeout for icmp_seq 123
Request timeout for icmp_seq 124
Request timeout for icmp_seq 125
Request timeout for icmp_seq 126
Request timeout for icmp_seq 127
Request timeout for icmp_seq 128
Request timeout for icmp_seq 129
Request timeout for icmp_seq 130
Request timeout for icmp_seq 131
Request timeout for icmp_seq 132
Request timeout for icmp_seq 133
Request timeout for icmp_seq 134
Request timeout for icmp_seq 135
Request timeout for icmp_seq 136
Request timeout for icmp_seq 137
Request timeout for icmp_seq 138
Request timeout for icmp_seq 139
Request timeout for icmp_seq 140
Request timeout for icmp_seq 141
Request timeout for icmp_seq 142
Request timeout for icmp_seq 143
Request timeout for icmp_seq 144
Request timeout for icmp_seq 145
Request timeout for icmp_seq 146
Request timeout for icmp_seq 147
Request timeout for icmp_seq 148
Request timeout for icmp_seq 149
Request timeout for icmp_seq 150
Request timeout for icmp_seq 151
Request timeout for icmp_seq 152
Request timeout for icmp_seq 153
Request timeout for icmp_seq 154
Request timeout for icmp_seq 155
Request timeout for icmp_seq 156
Request timeout for icmp_seq 157
Request timeout for icmp_seq 158
Request timeout for icmp_seq 159
Request timeout for icmp_seq 160
Request timeout for icmp_seq 161
Request timeout for icmp_seq 162
Request timeout for icmp_seq 163
Request timeout for icmp_seq 164
Request timeout for icmp_seq 165
Request timeout for icmp_seq 166
Request timeout for icmp_seq 167
Request timeout for icmp_seq 168
Request timeout for icmp_seq 169
Request timeout for icmp_seq 170
Request timeout for icmp_seq 171
Request timeout for icmp_seq 172
Request timeout for icmp_seq 173
Request timeout for icmp_seq 174
Request timeout for icmp_seq 175
Request timeout for icmp_seq 176
Request timeout for icmp_seq 177
Request timeout for icmp_seq 178
Request timeout for icmp_seq 179
Request timeout for icmp_seq 180
Request timeout for icmp_seq 181
Request timeout for icmp_seq 182
Request timeout for icmp_seq 183
Request timeout for icmp_seq 184
Request timeout for icmp_seq 185
Request timeout for icmp_seq 186
Request timeout for icmp_seq 187
Request timeout for icmp_seq 188
Request timeout for icmp_seq 189
Request timeout for icmp_seq 190
Request timeout for icmp_seq 191
Request timeout for icmp_seq 192
Request timeout for icmp_seq 193
Request timeout for icmp_seq 194
Request timeout for icmp_seq 195
Request timeout for icmp_seq 196
Request timeout for icmp_seq 197
Request timeout for icmp_seq 198
Request timeout for icmp_seq 199
Request timeout for icmp_seq 200
Request timeout for icmp_seq 201
Request timeout for icmp_seq 202
Request timeout for icmp_seq 203
Request timeout for icmp_seq 204
Request timeout for icmp_seq 205
Request timeout for icmp_seq 206
Request timeout for icmp_seq 207
Request timeout for icmp_seq 208
Request timeout for icmp_seq 209
Request timeout for icmp_seq 210
Request timeout for icmp_seq 211
Request timeout for icmp_seq 212
Request timeout for icmp_seq 213
Request timeout for icmp_seq 214
Request timeout for icmp_seq 215
Request timeout for icmp_seq 216
Request timeout for icmp_seq 217
Request timeout for icmp_seq 218
Request timeout for icmp_seq 219
Request timeout for icmp_seq 220
Request timeout for icmp_seq 221
Request timeout for icmp_seq 222
Request timeout for icmp_seq 223
Request timeout for icmp_seq 224
Request timeout for icmp_seq 225
Request timeout for icmp_seq 226
Request timeout for icmp_seq 227
Request timeout for icmp_seq 228
Request timeout for icmp_seq 229
Request timeout for icmp_seq 230
Request timeout for icmp_seq 231
Request timeout for icmp_seq 232
Request timeout for icmp_seq 233
Request timeout for icmp_seq 234
Request timeout for icmp_seq 235
Request timeout for icmp_seq 236
Request timeout for icmp_seq 237
Request timeout for icmp_seq 238
Request timeout for icmp_seq 239
Request timeout for icmp_seq 240
Request timeout for icmp_seq 241
Request timeout for icmp_seq 242
Request timeout for icmp_seq 243
Request timeout for icmp_seq 244
Request timeout for icmp_seq 245
Request timeout for icmp_seq 246
Request timeout for icmp_seq 247
Request timeout for icmp_seq 248
Request timeout for icmp_seq 249
Request timeout for icmp_seq 250
Request timeout for icmp_seq 251
Request timeout for icmp_seq 252
Request timeout for icmp_seq 253
Request timeout for icmp_seq 254
Request timeout for icmp_seq 255
Request timeout for icmp_seq 256
Request timeout for icmp_seq 257
Request timeout for icmp_seq 258
Request timeout for icmp_seq 259
Request timeout for icmp_seq 260
Request timeout for icmp_seq 261
Request timeout for icmp_seq 262
Request timeout for icmp_seq 263
Request timeout for icmp_seq 264
Request timeout for icmp_seq 265
Request timeout for icmp_seq 266
Request timeout for icmp_seq 267
Request timeout for icmp_seq 268
Request timeout for icmp_seq 269
Request timeout for icmp_seq 270
Request timeout for icmp_seq 271
Request timeout for icmp_seq 272
Request timeout for icmp_seq 273
Request timeout for icmp_seq 274
Request timeout for icmp_seq 275
Request timeout for icmp_seq 276
Request timeout for icmp_seq 277
Request timeout for icmp_seq 278
Request timeout for icmp_seq 279
Request timeout for icmp_seq 280
Request timeout for icmp_seq 281
Request timeout for icmp_seq 282
Request timeout for icmp_seq 283
Request timeout for icmp_seq 284
Request timeout for icmp_seq 285
Request timeout for icmp_seq 286
Request timeout for icmp_seq 287
Request timeout for icmp_seq 288
Request timeout for icmp_seq 289
Request timeout for icmp_seq 290
Request timeout for icmp_seq 291
Request timeout for icmp_seq 292
Request timeout for icmp_seq 293
Request timeout for icmp_seq 294
Request timeout for icmp_seq 295
Request timeout for icmp_seq 296
Request timeout for icmp_seq 297
^C
--- 192.168.1.23 ping statistics ---
299 packets transmitted, 0 packets received, 100.0% packet loss
When you wait long enough the esp-log suddenly changes in very high speed sending the same message
"Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED". Thats when I quited ping:
121716 : Info   : WD   : Uptime 2 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
151716 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
151717 : Info   : WiFi : Start network scan all channels
181716 : Info   : WD   : Uptime 3 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
211716 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
211717 : Info   : WiFi : Start network scan all channels
241716 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
271716 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
271718 : Info   : WiFi : Start network scan all channels
301716 : Info   : WD   : Uptime 5 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
331716 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
361716 : Info   : WD   : Uptime 6 ConnectFailures 0 FreeMem 19296 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
361717 : Info   : WiFi : Start network scan all channels
383953 : Info   : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 5 m 8 s
383954 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
384102 : Info   : Reset WiFi.
384104 : Info   : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -73 status: STATION_CONNECTING
384217 : Info   : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 6 m 24 s
384218 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
385104 : Info   : WIFI : Connecting FRITZ-Box-5631 44:4E:6D:F9:0C:BD Ch:11 (0dBm) - attempt #0
385205 : Info   : WIFI : Set WiFi to STA
385311 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
385325 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
385338 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
385351 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
385364 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386255 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386268 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386281 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386294 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386307 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386320 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386332 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386344 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386357 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386369 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386382 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386395 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386406 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386419 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386432 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386443 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386456 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386469 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386482 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386494 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386506 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386519 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386531 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386543 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386556 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386569 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386582 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386594 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386606 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386619 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386631 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386643 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386656 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386669 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386682 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386694 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386706 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386719 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386731 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386743 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386756 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386769 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386782 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386794 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386806 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386819 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386831 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386843 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386856 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386869 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386882 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386894 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386906 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386919 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386931 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386943 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386956 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386969 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386981 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
386994 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387006 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387018 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387031 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387043 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387055 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387068 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387081 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387094 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387105 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387118 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387131 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387143 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387155 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387168 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387181 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387194 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387206 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387219 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387231 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387243 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387359 : Info   : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 2151 ms
387462 : Info   : WIFI : Set WiFi to OFF
387676 : Info   : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
387780 : Info   : WIFI : Set WiFi to STA
387883 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387896 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387909 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387922 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387934 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387946 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387959 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387971 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387983 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
387996 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388008 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388021 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388033 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388045 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388058 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388070 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388082 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388095 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388106 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388119 : Info   : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
388132 : Info   : WIFI : Ard
I can ping my router (192.168.1.254), my iPad (192.168.1.25) without any problem...
Tebogo
Re: Latest versions crashes my NodeMCU
#41 Post by Tebogo » 09 Jun 2021, 22:39
I found this thread
Andrew Mamohin wrote: 16 Jun 2020, 13:18 I have now again flashed the old version: mega-20180223. The module works fine. But, this version does not suit me, I want a new one!
in this forum, and as he says, that old dino version mega-20180223, works directly without any problem. So it can't be the hardware...
Also mega-20190225 is working!
#42 Post by TD-er » 09 Jun 2021, 22:52
That old version differs in so many ways.
For example it is running an older core version and making a WiFi connection was at a much slower pace.
This slower pace does put a higher strain on the power supply. So the fact it was working at an older build is not guarantee it isn't a hardware issue.
However it still is very much possible that I made some mistake in the WiFi code which does manifest itself in your setup.
On the other hand I have spent literally many 100's of hours finding bugs in WiFi which later appeared to be caused by flaky hardware.
So forgive me if I keep pushing on making absolutely sure it isn't a power issue, or let you test another unit first to make sure it isn't something caused by a de-tuned WiFi antenna.
Tebogo
#43 Post by Tebogo » 09 Jun 2021, 23:19
TD-er wrote: 09 Jun 2021, 22:52 However it still is very much possible that I made some mistake in the WiFi code which does manifest itself in your setup.
No problem, I can imagine you got a lot of these problems. But I can assure you the ESP8266 is working correct, with other firmwares as Tasmota, ESPHome, Arduino compiled ino's. Also older versions of ESPEasy, like mega-20190225 is working. So I want to solve why the higher versions don't work to get ESPEasy better.
I also used , other NodeMCU's, WEMOS D1 etc as I mentioned earlier, but same result for all the NodeMCU. The Wemos D1 works with the latest version.
And I use a iPad loader as power. Must be enough I think.
So I think: cannot be a hardware issue (works with other flash-versions), cannot be the Wifi (other devices, flash-versions work), cannot be the power supply (works with other flash-versions, devices). Left over, the ESP-versions..
I want to test al kind of thing, but I'm not a programmer. Just tell me what to test to help you figure out what the problem is.
Tebogo
#44 Post by Tebogo » 10 Jun 2021, 08:45
Tebogo wrote: 09 Jun 2021, 22:39 Also mega-20190225 is working!
Build:⋄
20103  - Mega
Libraries:⋄
ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support
GIT version:⋄
mega-20190225
Plugins:⋄
46 [Normal]
Build time:⋄
Feb 25 2019 03:13:36
Binary filename:⋄
ESP_Easy_mega-20190225_normal_ESP8266_4M.bin
Now up for 9 hours, 43 minutes...
Tebogo
#45 Post by Tebogo » 10 Jun 2021, 11:37
Is there any information in this version (mega-20190225) which can indicate why the latest version (mega_20210503) give problems with these NodeMCU's (ESP8266)
Thank you!
Tebogo
#46 Post by Tebogo » 10 Jun 2021, 17:07
Ath wrote: 07 Jun 2021, 16:39 Have you tried:
- A build with 'alt_wifi' in the name? (Uses a different Arduino Wifi setup)
- A build with 'beta' in the name? (Uses a beta release of the Arduino libraries)
Tested:
ESP_Easy_mega_20210503_normal_alt_wifi_ESP8266_4M1M.bin
ESP_Easy_mega_20210503_custom_alt_wifi_ESP8266_4M1M.bin
ESP_Easy_mega_20210503_test_A_alt_wifi_ESP8266_4M1M_VCC.bin
ESP_Easy_mega_20210503_test_B_alt_wifi_ESP8266_4M1M_VCC.bin
ESP_Easy_mega_20210503_custom_beta_ESP8266_4M1M.bin
ESP_Easy_mega_20210503_test_A_beta_ESP8266_4M1M.bin
ESP_Easy_mega_20210503_test_B_beta_ESP8266_4M1M.bin
ESP_Easy_mega_20210503_test_D_beta_ESP8266_4M1M.bin
ESP_Easy_mega_20210503_custom_sdk3_ESP8266_4M1M.bin
All no success, same results...
Tebogo
#47 Post by Tebogo » 10 Jun 2021, 22:49
New info!
Latest working version is ESPEasy_mega-20190226.
When I install ESPEasy_mega-20190227 the problems start. Also the version ESPEasy_mega-20190301 and up...
Back to ESPEasy_mega-20190226 solves the problem.
So that must indicate where the problem starts.
@TD, hope it al these info helps you to find the cause of the wifi problems.
Thank you!
#48 Post by TD-er » 10 Jun 2021, 23:09
Hmm that's a very concrete jump in versions and I just browsed the changes.
They are hardly related to WiFi, except for this one.
In the code there is a number of checks like this one:
  if (!WiFiConnected(10)) {
The change here in those 2 versions is only to change "100" to "10".
This is a timeout value to check if we're connected in msec.
So what I can do is make a test build for you where I make it configurable (or just set it to 100 for the test build)
Just the latest sources with this set to 100 msec.
Will try to make one right now, on my 'couch laptop'.
Tebogo
#49 Post by Tebogo » 10 Jun 2021, 23:22
That would be great.
I found in the releasenotes :
Changes in mega-20190227 (since mega-20190226):
ESPEasy release bot (1):
automatically updated release notes for mega-20190227
Gijs Noorlander (1):
Fix build error
TD-er (6):
[Factory Reset] Make default switch/relay rules more intuitive
[Factory Reset] Change #switch in rules and plugin to #state
[Heap stats] Show heap statistics on core 2.5.0 and newer
[WiFi] Only perform network activity when connected
[Build] Add normal core 2.6.0 SDK2 build
[WiFiClient] Make sure all clients use at least some timeout
Are those two related?
#50 Post by TD-er » 10 Jun 2021, 23:25
Completely untested and was surprised it did compile in one run ;) The changes
https://www.dropbox.com/s/4kqgvun2755p8 ... M.bin?dl=0
Please let me know if this does work for you.
If it does, I will make it a configurable setting.
Users browsing this forum: No registered users and 48 guests
