easpeasy and apds9960
I would like to know if the sensor apds9960 is manageable with ESP32 and ESPEASY ?
if yes can you please show me some example
Thx
Thx
Re: easpeasy and apds9960
Have you looked at the documentation for that plugin?
It should work just as fine on an ESP32 as it does on an ESP8266.
Just pick any of the TESTING builds (has 'test' in the bin name).
thx
testing code means it is not tested yet ?
hi again
i noticed this evening that ESP32 has builtin multiple "touch pin"
Do you know if it is possible to use touchpin with espeasy ?
have you got an example ?
thanks
thanks
The testing name is a leftover from the time that the 'normal' build held a set of thoughly tested and accepted plugins, and 'testing' held also a set of plugins that had some lesser 'experience' in actual use. That time has passed, as all available plugins are a) rather stable but b) they don't fit into a single build anymore. (Though since a couple of months there is the 'max' build, only available for ESP32 with 16MB flash, that does contain all plugins that actually work on an ESP32).
For historic reasons the 'test(ing)' name was kept, but even that was split into 4 sets, A..D, as even the larger possible bin size of an ESP32 with 4MB couldn't accommodate all plugins any longer.
If you have a suggestion for a better naming scheme, please provide that, it will be taken into consideration!
hi
maybe you can help here,
i did create a devices "Touch (ESP32) - internal" with the name touch15 .
I plugged a wire on the touch GPIO15.
when i hold the wire with my hand it is working, see the log:
212204 : Info : Touch : ADC2 ch3 (T3): 18
212301 : Info : EVENT: touch15#All=18.00
213201 : Info : EVENT: touch15#Duration=1015
213905 : Info : Touch : ADC2 ch3 (T3): 15
214000 : Info : EVENT: touch15#All=15.00
214702 : Info : EVENT: touch15#Duration=887
215204 : Info : Touch : ADC2 ch3 (T3): 15
215300 : Info : EVENT: touch15#All=15.00
215702 : Info : EVENT: touch15#Duration=588
Now i want to create a rule, when the wire is hold trigger an action, here is my rule
on touch15#Touch
do
logentry,Starting **************** touch15
i tryied again holding the wire, but the rules is not run ?
do you know why ?
Thx
on touch15#Touch
do
do you know why ?
Thx
I don't see an event touch15#touch in your log, so that indeed won't trigger.
Should be like this I guess:
(NB: Don't put the 'do' on a separate line, that might give unexpected results, or no results at all)
(NB2: The logentry I added quotes, as a space is also an argument separator, like a comma, so it would have only logged the word 'Starting' in the way you put it)
In the example rule from the documentation, the task value variable is called Touch, and I assume you named it All?
on touch15#All do
logentry,"touch15 All = %eventvalue1%"
on touch15#Duration do
logentry,"touch15 Duration = %eventvalue1%"
Working very well
Many Thanks
Many Thanks
Many thx
i ordered that kind of switch to be used as a touch switch
https://www.amazon.fr/gp/product/B07BVN ... UTF8&psc=1
You don't need ESP32 Touch support for that, these act just like a regular switch, giving either a 0 or 1 output on active (configurable by soldering the correct pads as documented). And it will only give on/off status, not the duration it was touched that you can have when using the ESP32 built-in touch sensor(s).tchi59 wrote: ↑02 Jul 2021, 09:50 Many thx
You could also use the TTP229-B hardware and the available plugin for that kind of keypad (older documentation available only)
