[P013](sr04 ultrasonic sensor) plugin hang on HI in state mode when NO_ECHO
F.J.S.
#1 Post by F.J.S. » 10 Sep 2021, 23:41
Hi everyone.
The complement [P013] (ultrasonic sensor sr04) hangs in the state = "HI" working on "state mode" when the sensor ping timeout (NO_ECHO). I think this behavior is not correct since the state remains in "hi" when there is no longer any object in front of the sensor.
I think this will be better understood by looking at the plugin code:
at line 255 of mega/src/_P013_HCSR04.ino
case PLUGIN_TEN_PER_SECOND: // If we select state mode, do more frequent checks and send only state changes
        int16_t operatingMode = PCONFIG(0);
        int16_t threshold = PCONFIG(1);
        if (operatingMode == OPMODE_STATE) {
          uint8_t state = 0;
          float value = Plugin_013_read(event->TaskIndex);
          if (value != NO_ECHO) {
				if (value < threshold) state = 1;
				if (state != switchstate[event->TaskIndex])
				  if (loglevelActiveFor(LOG_LEVEL_INFO)) {log...}
				  switchstate[event->TaskIndex] = state;
				  UserVar[event->BaseVarIndex] = state;
				  event->sensorType = Sensor_VType::SENSOR_TYPE_SWITCH;
				  sendData(event);
          else {
        success = true;
if an object is in front of the sensor at a short distance (value < theshold) then state -> "hi", but if the objets move out of the sensor range, value = "NO_ECHO" (defined as 0) all the code that make changes on state will not run and de state will continue on "hi" when no objet in fron of sensor.
only when the object is again in front of the sensor at a distance such that value> = threshold, we can reach the code that changes state and finally it will go "low"
if (value != NO_ECHO) {...
	if (state != switchstate[event->TaskIndex]) {
        	switchstate[event->TaskIndex] = state;	//---<---here
              	UserVar[event->BaseVarIndex] = state;	//---<--------
I made a dirty patch to the code that only ensures that if there is no object in range, the state goes low.
//	src/_P013_HCSR04.ino @line 255
          uint8_t state = 0;
          //if (value != NO_ECHO)						//---no more
            if ( (value < threshold) && (value != NO_ECHO) ) 	//---add condition
              state = 1;
              if (loglevelActiveFor(LOG_LEVEL_INFO) && (value != NO_ECHO)) {//---add condition
                String log = F("ULTRASONIC : TaskNr: ");
                log += event->TaskIndex +1;
                log += F(" state: ");
                log += state;
                addLog(LOG_LEVEL_INFO,log);
              sendData(event);
          if (value == NO_ECHO) {						//---add condicion
              log += F(" Error: ");
              log += Plugin_013_getErrorStatusString(event->TaskIndex);
        success = true;
I think this part of the program should be reviewed by someone with more knowledge to clean up the code.
When NO-ECHO, is it necessary to log "Error:" 10 times per second?
I'm trying to compile these changes into a copy of the Master branch with the Arduino IDE, but I'm having a headache with libraries. I still couldn't taste the change. I am interested in your opinion about it, thank you very much.
Re: [P013](sr04 ultrasonic sensor) plugin hang on HI in state mode when NO_ECHO
#2 Post by TD-er » 11 Sep 2021, 00:43
Interesting...
too bad I cannot mark a topic as unread to read your code changes with a clear head in the morning.
F.J.S.
#3 Post by F.J.S. » 13 Sep 2021, 21:25
Hello again.
I think this would be a cleaner change in the code to avoid the "frozen-hi-state" issue.
(line 255 of mega/src/_P013_HCSR04.ino 13-sep-2021) new proposed code.
        if (operatingMode == OPMODE_STATE){
			uint8_t state = 0;
			if ( (value != NO_ECHO) && (value < threshold) )
				state = 1;
			if (state != switchstate[event->TaskIndex]){
					if (value != NO_ECHO){
						log += state;
					}else {
				sendData(event);
        success = true;
this is the comparison with the original code (line 255 of mega/src/_P013_HCSR04.ino 13-sep-2021)
ORIGINAL(left)___________________________________________w/changes(right)
I'm still fighting to get the compiler up and running, but this time with Platformio. I am trying to compile a "normal_ESP8266_4M1M_VCC" version to test the changes in the plugin [P013] sr-04
what do you think TD-er? it could work?
F.J.S.
#4 Post by F.J.S. » 14 Sep 2021, 00:42
Finally compiled :D !!! (with platformIO)
RAM:   [=====     ]  52.8% (used 43224 bytes from 81920 bytes)
Flash: [========  ]  81.5% (used 850852 bytes from 1044464 bytes)
Environment              Status    Duration
normal_ESP8266_4M1M_VCC  SUCCESS   00:01:02.324
I tested the changes.
Everything is working fine!
Now when removing the object in front of the SR-04 sensor, the state immediately drops to low. No more problems with maintaining a "false hi state" indefinitely. (this is only valid for "state mode" on the plugin)
I do not know how to propose this change to be considered at GIT.
I hope someone else will find this useful.
Bye.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 34 guests
