Chuango g5 plus rf codes
Post here about devices that are not yet or not fully supported
Kevinvdb
#1 Post by Kevinvdb » 16 Apr 2022, 08:59
Hey, I recently started playing with home assistant. Since I have a chuango alarm system, I bought a rflink.
I managed to get the "on" events on the pir, smoke and window sensors.  Also, the key fob is working. But I fail to receive the arm, disarm, home mode signals coming from the alarm panel itself. (chuango g5 plus). Is there someone who got this working with rflink? Is the alarm panel itself using a different protocol?
Regards Kevin
Stuntteam
Site Beheer
Re: Chuango g5 plus rf codes
#2 Post by Stuntteam » 19 Apr 2022, 09:40
Isnt the panel the base system that mostly receives signals?
It might only be able to send a signal to a siren/alarm light device
Check the debug mode to see if there are missed signals.
Kevinvdb
#3 Post by Kevinvdb » 19 Apr 2022, 19:35
Hey Stuntteam.
The G5 is indeed the main panel. But from what I read, it does sent out his status. I checked debug mode a few days ago. And a lot of debug messages came in from undetected devices. I only have the chuango at my home on 433. But the rflink picks up at least 7 other devices from around the neighborhood. Hard to figure out which debug comes from what. I will give it another try tomorrow evening. And post the log here.
PS. not sure if helpful, but the rtl-433 project do seem to have the G5 working. https://github.com/merbanan/rtl_433/blo ... /chuango.c
Regards Kevin
Kevinvdb
#4 Post by Kevinvdb » 20 Apr 2022, 19:32
Hey, putting debug mode one gives the following.
ARM
20;78;DEBUG;Pulses=50;Pulses(uSec)=1710,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;79;Chuango;ID=1775eb;SWITCH=02;CMD=ON;
20;7A;DEBUG;Pulses=50;Pulses(uSec)=1710,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;7B;DEBUG;Pulses=28;Pulses(uSec)=540,1530,1530,450,450,1530,1530,450,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;7C;DEBUG;Pulses=44;Pulses(uSec)=270,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;7D;DEBUG;Pulses=34;Pulses(uSec)=540,450,450,1530,450,1530,450,1530,1530,450,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;7E;DEBUG;Pulses=40;Pulses(uSec)=390,1530,450,1530,450,1530,1530,450,450,1590,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;7F;DEBUG;Pulses=36;Pulses(uSec)=210,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;80;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;81;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;82;DEBUG;Pulses=38;Pulses(uSec)=540,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;83;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;84;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;85;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,480,6990;
20;86;DEBUG;Pulses=50;Pulses(uSec)=1710,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;87;DEBUG;Pulses=28;Pulses(uSec)=510,1530,1530,420,450,1530,1530,450,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;88;DEBUG;Pulses=44;Pulses(uSec)=270,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;89;DEBUG;Pulses=34;Pulses(uSec)=540,450,450,1530,450,1530,450,1530,1530,450,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;8A;DEBUG;Pulses=40;Pulses(uSec)=390,1530,450,1530,450,1530,1530,450,450,1590,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;8B;DEBUG;Pulses=36;Pulses(uSec)=210,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;8C;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;8D;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;8E;DEBUG;Pulses=38;Pulses(uSec)=540,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;8F;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;90;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;91;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;92;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
UNARM
20;93;DEBUG;Pulses=50;Pulses(uSec)=1680,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;94;Chuango;ID=1775eb;SWITCH=02;CMD=ON;
20;95;DEBUG;Pulses=50;Pulses(uSec)=1710,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;96;DEBUG;Pulses=28;Pulses(uSec)=510,1530,1530,450,450,1530,1530,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;97;DEBUG;Pulses=44;Pulses(uSec)=270,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;98;DEBUG;Pulses=34;Pulses(uSec)=540,450,450,1530,450,1530,450,1530,1530,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;99;DEBUG;Pulses=40;Pulses(uSec)=390,1530,450,1530,450,1530,1530,450,450,1590,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;9A;DEBUG;Pulses=36;Pulses(uSec)=210,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;9B;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;9C;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;9D;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;9E;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;9F;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;A0;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,480,6990;
20;A1;DEBUG;Pulses=50;Pulses(uSec)=1680,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;A2;DEBUG;Pulses=28;Pulses(uSec)=510,1530,1530,420,450,1530,1530,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;A3;DEBUG;Pulses=44;Pulses(uSec)=270,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;A4;DEBUG;Pulses=34;Pulses(uSec)=540,450,450,1530,450,1530,450,1530,1530,450,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;A5;DEBUG;Pulses=40;Pulses(uSec)=390,1530,450,1530,450,1530,1530,450,450,1590,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;A6;DEBUG;Pulses=36;Pulses(uSec)=210,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;A7;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;A8;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;A9;DEBUG;Pulses=38;Pulses(uSec)=540,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;AA;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;AB;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;AC;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
20;AD;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,6990;
HOME MODE
20;AE;DEBUG;Pulses=50;Pulses(uSec)=1680,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;AF;Chuango;ID=1775eb;SWITCH=02;CMD=ON;
20;B0;DEBUG;Pulses=50;Pulses(uSec)=1710,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B1;DEBUG;Pulses=28;Pulses(uSec)=540,1530,1530,450,450,1530,1530,450,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B2;DEBUG;Pulses=44;Pulses(uSec)=270,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B3;DEBUG;Pulses=34;Pulses(uSec)=570,450,450,1530,450,1530,450,1530,1530,450,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B4;DEBUG;Pulses=40;Pulses(uSec)=390,1530,450,1530,450,1530,1530,450,450,1590,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B5;DEBUG;Pulses=36;Pulses(uSec)=210,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B6;DEBUG;Pulses=38;Pulses(uSec)=540,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B7;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B8;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;B9;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;BA;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;BB;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,480,6990;
20;BC;DEBUG;Pulses=50;Pulses(uSec)=1680,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;BD;DEBUG;Pulses=28;Pulses(uSec)=540,1530,1530,450,450,1530,1530,450,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;BE;DEBUG;Pulses=44;Pulses(uSec)=270,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;BF;DEBUG;Pulses=34;Pulses(uSec)=570,450,450,1530,450,1530,450,1530,1530,450,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C0;DEBUG;Pulses=40;Pulses(uSec)=390,1530,450,1530,450,1530,1530,450,450,1590,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C1;DEBUG;Pulses=36;Pulses(uSec)=210,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C2;DEBUG;Pulses=38;Pulses(uSec)=540,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C3;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C4;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C5;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C6;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C7;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C8;DEBUG;Pulses=38;Pulses(uSec)=540,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,1620,480,480,1620,480,1620,480,1620,480,6990;
20;C9;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,480,6990;
20;CA;DEBUG;Pulses=50;Pulses(uSec)=1680,480,1620,480,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;CB;DEBUG;Pulses=28;Pulses(uSec)=540,1530,1530,420,450,1530,1530,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;CC;DEBUG;Pulses=44;Pulses(uSec)=270,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;CD;DEBUG;Pulses=34;Pulses(uSec)=540,450,450,1530,450,1530,450,1530,1530,450,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;CE;DEBUG;Pulses=40;Pulses(uSec)=390,1530,450,1530,450,1530,1530,450,450,1590,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;CF;DEBUG;Pulses=36;Pulses(uSec)=210,1530,1530,450,450,1530,450,1530,450,1590,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;D0;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;D1;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;D2;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;D3;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;D4;DEBUG;Pulses=38;Pulses(uSec)=540,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;D5;DEBUG;Pulses=36;Pulses(uSec)=510,1530,1530,450,450,1530,450,1560,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
20;D6;DEBUG;Pulses=38;Pulses(uSec)=510,1530,450,1530,1530,450,450,1530,450,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,1620,480,1620,1620,480,480,1620,1620,480,480,1620,480,1620,480,6990;
The 20;AF;Chuango;ID=1775eb;SWITCH=02;CMD=ON; is picked up everytime you switch state. No idee whats the logic behind it. Hope some of the messages make any sense.
Regards Kevin
