TM1637 7dt
TM1637 7dt
How to use the 7dt command. At the same time, my display just flashes. At the same time, 7dtext displays the temperature normally. На шине DIO-Pin у меня подключен LED. В автоматическом режиме часы он моргает только при изменении состояния, в ручном режиме моргает постоянно даже если информация не меняется.
Re: TM1637 7dt
And you have not enabled the WiFi led feature? :
Because that will interfere with the display, as you would expect.
Re: TM1637 7dt
WiFi led feature is disabled, it does not prevent the display from displaying information. Only the 7dt function does not work.
Re: TM1637 7dt
I will have to check to see if there is some anomaly in the code, or something else is going on here, and configure a similar hardware setup. That will take some time (probably a few days, busy schedule, only working on ESPEasy in my spare time
Re: TM1637 7dt
Thank you. While I use through dtext. But it seems to me that there is some difference in hardware output between auto and manual mode.
Re: TM1637 7dt
When you enter the command dn, dt, the display only flashes for a fraction of a second.
