Sonoff DUAL R3 - ESP32
today I received my first Sonoff DUAL R3. I expected that it contains ESP8266 but unfortunately it has ESP32 build in.
Do somebody have experience flashing it with ESPeasy? pads for RX, TX, 3.3V and GND are accessible, for GPIO-0 I assume it is connected to build in button but still searching web for some schematics if exists.
It has 4MB Flash.
BRJ.
It has 4MB Flash.
BRJ.
Re: Sonoff DUAL R3 - ESP32
Ooh, that's nice, to have the ESP32 on a Sonoff.
I will order one myself.
Did you already check the Tasmota documentation?
They really have a nice documentation collection of lots of those devices.
@jgrad: Any news? Did you get a ESPEasy-image to work on it?
not yet, time limitations.
Since this is my first ESP32 device I am a bit more careful. First i was checking which predefined bin I will flash first - I decided that this will be ESP_Easy_mega_20210223_normal_ESP32_4M316k.bin.
For flasher tool - can I use same flasher tool for ESP32 as for ESP8266 - I currently use FlashESP8266.exe
See also the flashing steps described here: https://espeasy.readthedocs.io/en/lates ... html#esp32
For the initial flash (from serial) you need the "factory" bin.
Later OTA updates can be done using the file you mentioned.
I followed instructions above and flashed ESP_Easy_mega_20210223_normal_ESP32_4M316k-factory.bin.
Seems that flashing went OK (similar responses as in instructions).
But after flashing I expected to find wifi network with SSID "ESP Easy" but nothing![Bedroeft :(](./images/smilies/icon_e_sad.gif)
You can also try to send the SSID and WiFi key via serial and then save it.
Maybe you also need to reboot it (recent bug I fixed this week)
wifissid,YourSSID
wifikey,YourWiFiPassword
save
I connected serial terminal and saw following pattern rolling all the time
Then I changed power supply (before it was powered from serial adapter used for programming) and got expected behaviour with "Easy ESP" SSID.
Logged in successfully and was able to switch on/off build in relays (Tools->Command) connected to GPIO14 and GPIO27
I have to check also inputs (S1, S2) which shall be connected to GPIO32, GPIO32.
WIFI status led is GPIO13 (inverted)
Based on info I was able to collect SONOFF DUAL R3 use CSE7761 power metering chip - I dont know if there is support within ESPeasy builds.
INIT : Booting version: (ESP32 SDK v3.2.3-14-gd3e562907)
37 : Info : INIT : Free RAM:290120
38 : Info : INIT : Cold Boot - Restart Reason: CPU0: Vbat power on reset CPU1: for APP CPU, reseted by PRO CPU
39 : Info : FS : Mounting...
82 : Info : CRC : SecuritySettings CRC ...OK
86 ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DOUT, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5816
entry 0x400806ac
▒U37 : Info :
The CSE7766 is supported: https://github.com/letscontrolit/ESPEas ... SE7766.ino
Not sure what differs with the CSE7761
seems that:
* CSE7766 is single channel with UART interface
* CSE7761 is dual channel with SPI interface
Goth the Dual R3 going with the advice from this post - Thank you. Now trying to figure out the CSE7766 (P077), after I installed the Power version of mega-20220328, over the air. Acitvated a CSE7766 device, quite easily. However no readings on V, I and P. Not sure what parameters should be loaded, I used all the defaults. Any advice? Could not really get anything but these posts.
The hardware (GPIO) configuration can be extracted from this Blakadder page (also showing the Tasmota configuration, but that's not usable by ESPEasy, only the GPIO info).
The predefined plugin settings for Sonoff Pow R1 are the first I'd try to see if that returns anything usable. Possibly the calibration values need adjustment too.
Just curious, what exact build are you using?
If using the core 3.x and/or "beta" builds, then I think you're seeing the same issue I experienced here: https://github.com/letscontrolit/ESPEasy/issues/3991
Hi there
I’m using the 22020328 Power version for the ESP32 4M on a Sonoff Dual R3. Your post seems to suggest that perhaps it doesn’t work as before, so perhaps I should go to an earlier release.
Please mention the exact bin file you used, which is shown on the sysinfo page.
And/or the line describing the SDK
Oh overlooked the "ESP32" aspect.
Then it may be a different issue.
Not sure if that plugin was ever tested on ESp32 by the way.
Not sure if this is the exact detail you’re looking for, using mega-20220328 Energy 4M for ESP32. Reverted back to ESP_Easy_mega_20211224_energy_ESP32_4M316k.bin to test, but with same result. Also not sure of settings, maybe the comms to UART should also be setup?
I think this plugin is not going to work with ESP32 right now.
At least not without changing some code.
It is using hard-coded Serial0 for it, without offering to set the GPIO pins for it.
This one should be modified to use the ESPEasySerial wrapper to allow for a transparent configuration of the serial port.
Without it, it will very likely not going to work on your setup.
Thanks much appreciated. That’s a step too far for me right now, although I’ll look at the code to at least have a look at your suggestion.
We will fix it, but this may take some time to do so.
Please keep an eye on the GitHub issue I linked as the needed changes mentioned in there will also make it work on ESP32.
Do you refer to #4020, created today?
Hello shere (again),
if memberlist.php?mode=viewprofile&u=1491 allows it, I'd like to join this thread.
Since yesterday I also have two of the DUALR3 (and also a 4CHPRO... comes later then). Flashing was no problem and the rest works too, except the powermeter-chip...
My two questions:
My two questions:
- Is the ESP_Easy_mega_20230508_energy_ESP32_4M316k May 8 2023 the right version for this? Based on the prefix "energy" I only assumed that.
- Is there somehow now support for the CSE7761?
DLzG
Micha
Micha
Hm, that CSE7761 doesn't seem to be compatible with the quite similar CSE7766 that is supported by EAPEasy. I've ordered one of those units, and will investigate what's different to be able to support it.
... jgrad have investigate that before:
[quote=jgrad post_id=51554 time=1616937997 user_id=1491]
seems that:
[/quote]
If I take a look at Tasmota it sems that GPIO 25 & 26 are used as TX/MOSI & RX/MISO. I think SS are always L (make sense if that the only SPI- device there) and CLK comes hardwired from the ESP somewhere...
OHHH, stop it!
That is the new DUALR3- version 2v0. This version use an other chip: BL0930 is it then on the V2 PCB:
But who can read that datashet??? https://pdf1.alldatasheet.com/datasheet ... L0930.html
seems that:
[/quote]
OHHH, stop it!
DLzG
Micha
Micha
